I am building a custom case (see sig for details) and thought i would add a watercooled drive bay for the hard drives. I thought the DangerDen effort was the trick-->
So have modeled my attempt on their fine looking unit, However with room for 6 hard drives. :-)
I was given half a dozen sheets of 3mm copper plate, this will be used for the base of the unit, 20mm acrylic plexi will be the other half-->
Click here for full size pics
Took me a good 40 minutes to mill the plexi on my drill press. Shall tackle the second one after the football this arvo.
This setup will be run on its own separate loop with ford lazer heatercore -->
I was formerly using to cool a E6600 conroe and 1800gto gfx card. will be using a swiftech mcp-655 pump ;-)
Back with some updates soon ;-)
