4 gig sets of ram have been around for awhile now, but so far theres been no real high performance 4 gig set of ram.
well, Mushkin Changed all that recently with thier new 4 gig sets of PC 6400 and PC 8500.
this is a preview of the 2 x 2 gig set of Mushkins PC8500.
testing is just 1 days worth, and initial impressions.
ram is rated for cas 5-4-4-12 at 2.3 volts and 1066 mhz.
the ram is binned using the P5B deluxe.
I do not yet know what type of chip is on this set.
tests were done all so far at 2.30 - 2.32 volts.
P5B deluxe. Bios 1004.
Initial Results so far, are with 32 bit version of windows and only sees 2.93 gigs of ram. I still have about 50 gigs of stuff to back up before installing Vista or XP64.
can't make up my mind which one I hate the least... so I dont know what to try first haha...![]()
(ok I dont hate vista, I just wish drivers were better for it)
1 thing, dont ask me to push 2.6 volts or something into this stuff.
given how expensive this ram is, I really dont want to take any chances at killing it. 2.45 is about my limit for being comfortable.
you wanna see high voltages, do it yourself.
Observations.
theres literally no difference in stability from cas 4 to 5 or 6.
if it can do cas 5-6-6 at 1.1 ghz, it will do cas 5-4-4 just fine.
Ram is very very sensitive to Tras.
low tras always = no boot.
low tras for this ram, is below 12 when above 1 ghz on the ram.
around 900 mhz or less, low tras would be 8.
Write speeds are best set to 11, not 10.
write to precharge delayed- 11, and write to read delayed - 11, will do alot better for stability, then 10 will.
the P5B deluxe defaults to 10-10-10-11.
with this ram, 10-11-10-11 works best.
the combination of Writes at 11, and slightly higher tras (15 versus 12) can easily get you well above 1.1 ghz, stable at cas 5-4-4 at 2.3 to 2.35 volts.
the ram really doesnt seem to need extra voltage to OC high, and is exceptionally stable so far.
the "OC limits" are very very sudden.
for instance. for cas 3-3-3 overclocking 366 = prime stable. 370 = benchable. 375 = boots but no loading windows.
total leway from stable, to unstable - 9 mhz.
anyways, later today, I will have something 64 bit installed...
god I dont want to do that.
I am just gonna scavenge a spare hard drive from one of my other PC's.
hate to wipe out a good solid OS.
