DS3 Cant do more than 350 x 9 ? Take a Look plz :)
Hey Guys,
Im having a hard time with my Rev 1 DS3 Bios F10 with my E4300 and Buffalo Firestix 2GB
i can boot 350 x 9 @ stock volts orthos stable
http://img506.imageshack.us/img506/3023/untitleddt0.png
but after that i cant do nothing.
I didn't change any settings except the ones that need to be disable to stop the multi dropping.
i would really like to run my ram higher with lower multi i prefer 400 x 8 but i cant see to get it. i tried 400 x 7 that didnt work.
what exactly can i change to get this to boot. my northbright has a 40mm on it and have a 120mm fan blowing onto it.
any ideas would be awesome
i can post exactly what i have in bios if you need it.
everything is bascially on normal / auto except
Ram is +3v
and i have ram running 1:1 350 x 9 1.325v stock
- You may not post replies
- You may not edit your posts
Forum Rules
