Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 181
Thread: stained tubing..
    Dec 2005
    NYC
    stained tubing..
    I've been through about 4-5 loops in my lifetime and it seems that every time I drain the system . I get stained tubes.
    If I was using Hydrx, it would be stained green, or zerex would be purple.
    I know im not using too much, im using the minimum, so im good on that
    But i've always used cheap Masterkleer, is that the problem? so go with Tygon next time? Or is there some sort of additive I can buy to keep the tubes clear? I've also heard that Masterkleer is generally not as clear and non cloudy as premium tubing.
    i5 2500k @ 4.6ghz 1.335v [ASUS P8Z68 Deluxe]
    8gb gskill ripjaws f3-12800cl8-8gbxm
    600gb velociraptor + 1TB black
    MSI N560GTX-TI Twin Frozr II + x-fi xtrememusic
    corsair hx-620w + lian li pc201b + dell 2408fpw
    d-tek fuzion1/ddc2 + petra top/thermochill pa120.3
    Aug 2006
    Makes no difference. Tygon will eventually go cloudy as well.
    Dec 2005
    NYC
    theres no additive or liquid based solution to keep it clean?
    Aug 2006
    Nope. The best way to keep it clean is to use plain distilled water with colorless additive and to change your liquid often.. like every two months. I change 1/2 my loop every month by simply emptying out my reservoir and refilling. So far so good, but it'll cloud up eventually.
    Some people have had success with more dracionian methods such as liquid bleach and toilet bowl cleaner, but I would avoid that if I were you. Hydrochloric acid and acetic acid, no matter how diluted, cannot be good for copper waterblocks and radiators.
    Don't think that using expensive Tygon will eliminate the clouding. It'll prolong the period of clear tubes, but that's about it. In general, I expect to replace all my tubes every year anyway.
    Use 2% Zerex rather than 5% Zerex. Use diluted Hydrx unless you have true algae problems. Diluted additives help. But stay away from Masterkleer.
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    Purely cos I don't know if anyone's done this yet, have just emailed SaintGobain a pile of datasheets for the common additives, and a list of their products that we all tend to use (Tygon R3603, R3400, SM, and their Vincon "Masterkleer" range) requesting one of their guys recommend a specific line of clear tubing that suits our purposes but will minimise any risk of clouding / staining etc... will let you know what they say (if anything)...
    Dec 2005
    NYC
    Quote Originally Posted by Marci
    that would be awesome, thanks
    I know im not the only one tired of replacing tubing all the time
    Aug 2006
    You should get those black or silver tubes.. never see clouding.. peace of mind haha
    Jun 2002
    OK... starting to receive info from SaintGobain's Tech Dept... and word at the moment is that R3603 Tygon is NOT the tubing we should be using... they're still working thru the datasheets to find the perfect tubing for our purposes, but they've already stated that R3603 effectively isn't it, and that with the properties of our typical coolants, yes, it will cloud/stain over time. Adding ANYTHING which contains Glycol will worsen / speed up the staining.
    Bear with me - more info as I get it...
    Aug 2006
    santa cruz, ca
    thanks dude ... marci
    Asus P5W-dh + E6600 + GSKILL 2GB DDR2-800 + Seagate sata2 p-recording + X Fi with front panel + asus 8800gts
    Storm + mcmicro + PA-120 + yate loon + MCP655 + ek 8800 gtx
    currently working on using my wiimote for pc mouse
    Aug 2005
    Subscribed.
    Although I just bought 20 feet of masterkleer (SO CHEAP!) I would welcome any tubing that never clouds so long is it wasn't amazingly overpriced.
    This is my first loop running nothing but distilled and a colourless plast-safe anti-fungal. We'll see how quick it clouds haha.
    Aug 2006
    santa cruz, ca
    maybe insted of remcommending a different tube they might have some ideas on a different additive to the distilled insted of the Glycol based stuff
    Jun 2002
    They're a tubing company, not an additive producer. The folks to ask there would be the guys making the additives, not the guys making the tubing.
    Aug 2006
    santa cruz, ca
    marci... how big is pc watercooling in the tube industry for companys like tygon, small part of the pie for them?
    Jun 2002
    Miniscule - far less than 1% of total sales.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Would be great if we finally found tubing that wouldn't stain or cloud. Thanks for checking this out Marci.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Dec 2005
    Brooklyn, New York
    Quote Originally Posted by IanY
    Or use no zerex, hdryx or anything else because it's completely unnecessary.
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    Aug 2006
    Quote Originally Posted by thunderstruck!
    I'm 100% with you on this.
  18. #18
    Dec 2005
    NYC
    good point but i can imagine the troubles when bleeding your loop esp. with a t-line
  19. #19
    Jun 2002
    Missing my point...
    Additives speed up clouding... even with plain distilled and nothing else, it will still cloud in time... just not as quickly, hence R3603 isn't what folks should really be using. There are formulations which will take MUCH longer to cloud, and this is what we're after... but none that will guarantee no clouding whatsoever.
  20. #20
    Dec 2005
    NYC
    yea but in my experiences (cant speak for anybody else)
    I use a reservoir and I eliminate a lot of the waterfall and sloshing sounds with hydrx. It changes the surface tension getting rid of bubbles.
    It just makes me loop more silent for some odd reason that I cant explain
    but i guess with a t-line it wouldn't even matter
  21. #21
    Aug 2006
    Quote Originally Posted by Aldy402
    I get your point, but has there ever been an instance when the bubbles in a system do not eventually bleed out, even if it takes a few days when using a T-line?
  22. #22
    Dec 2005
    NYC
    good point as well but how long does regular distilled water usually last until you start getting buildup in your loop and I remember reading somewhere that it really clogs your block.
    regular distilled means more maintenance, but i guess thats the trade off
  23. #23
    Jun 2002
    Then you needed more water in the reservoir. Expect sloshing sounds for the first day or two until all tiny encapsulated airbubbles are bled. Once they're gone, as long as reservoir is FULL to capacity there should be no noise from it. No need for additive to achieve this, only to achieve it quicker. Sloshing reoccurs if water-level drops. Again, additive tension reduction merely prevents you hearing it for when you cba to do something about it. In reality, if you hear sloshing again it means something needs bleeding or filling. Do so and noise should go away again.
    S'a matter of convenience vs doing what is necessary to run the rig "correctly"...
    Quick and Easy generally always involves a sacrifice elsewhere... this is the lesson most need to learn along the way in watercooling... patience!
  24. #24
    Jun 2002
    You read wrong. If getting any buildup using nothing but distilled, you have mixed metals somewhere...
    The buildup most report is the additive separating from the distilled water, or other contaminations... distilled on it's own has nothing to separate down into that can become a buildup etc.
    Plain distilled on it's own in a quality loop (no mixedmetals) = less maintenance.
    Distilled + Additive = additive needs refreshing every xx months (differs from additive to additive) without fail to maintain anticorrosive properties.
    Non-Conductive coolants = collect ions over time becoming conductive unless refreshed every xx months also.
  25. #25
    Dec 2005
    NYC
    your absolutely right but I did have the res full. I waited about 2-3 days and it was still noisy, It drove me crazy because there was no explanation for it but ultimately i think it was just the res. It was a 5.25 acrylic. already ordered a swiftech micro res
