Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: DFI Infinity 975X/G FSB 500 MHz
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    Playing again with my old DFI 975X. vMCH and vFSB mod...
    Super PI 32M pass FSB 500 MHz....vMCH @ 1.98 volt (2.09 at BIOS)
    Jan 2007
    Denmark, Copenhagen
    Now infinity too - those 975X is coming back
    What cooling?
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    Quote Originally Posted by da_h00k
    What cooling?
    NB cooled by Thermaltake Extreme Spirit II.
    Aug 2005
    Romania, Transylvania crazyp.ro
    What CPU?
    3Dmark2006 Score Calculator
    "Frequency Unlimit -Enabled'' by DFI
    Mar 2006
    Indonesia
    wow... greatz for om Benny
    Just Me, My Self, and My PC
    Oct 2006
    Very Nice...
    Im just cant pass 360FSB, and its not stable on 360, sucks.
    can u come to my Messenger?
    hilik_o@netvision.net.il
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    3DMARK 2001SE bench @ FSB 500 MHz
    CPU-Z Validation : http://valid.x86-secret.com/show_oc?id=168385
    Jan 2003
    MA
    nice results IM playin with the same board right now...Can you show me a link on the mods you did and what bios are you using?
    I am at 408fsb now with the ram running at 510 with the nb voltage maxed in the bios at 1.75
    either way I am gettting to the max with this chip because I am stuck with the stock multy.My goal is 3700mhz
    I cant believe I got this board for 135 bucks...
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    Quote Originally Posted by Skratch
    I see FSB 408 Mhz not 480 Mhz on your screenshot.
    Jan 2003
    MA
    Quote Originally Posted by Benny Lodewijk
    I did say I'm at 408 lol and My screen shot shows 408...My ram is running at 500+
    My chip wont ever see 480 with the air cooling that I'm using
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    sorry my mistake ....try changing the NB cooling first.
    Jun 2004
    I am playing with this board also.
    Stock nb cooling+fan
    E6600 28B @1,55v vcore TTBT cooled
    2x1gb Gskill HZ 1:1 4-4-4-4
    DFI infinity 975x vmch mod 1,84v
    X1900GT
    I already seen 460mhz fsb on multi 8.
    Gigabyte P35C-DS3--E6600 L628B123--2x1GB Gskill Pc6400HZ+1GB D9GMH OEM--Sapphire x1900XTX--Tagan 580w--GFX Watercooled--Cpu Cooled By Mach2 GT modded by Jort
    Aug 2006
    Indonesia
    nice 480...! can i make the same mod @ my P5WDH-Dlx to hit 500 also?
    | i7 2600K | GA P67A-UD4 | Team Xtreem PC1600 DDR3 16Gb | DA GTX 570 | Team S1 120Gb SSD | Corsair 650W |
    | X-Fi Xtreme Music | Altec Lansing CS21 | Dell U2711 | Samsung 32"A550 | Armor Silver with 25cm fan |
    Old Celly L 430
    E4300
    E6300
    Q6600
    symphy
    Guest
    Of course, there's a Vmch Mod for the P5W... Helped me a lot with watercooled northbridge...
    Look here: http://www.xtremesystems.org/forums/...light=vmch+p5w
    Jul 2006
    WA & VA, Rep' both Coasts
    Nice, this tempts me to try and find an infinity lying around on some B/S/T forum and try my hand at volt modding. Never have before but it looks like if I'm going to ever try it this board would lend a nice price/performance/gratification ratio.
    I am Xtreme
    Feb 2003
    Netherlands
    Quote Originally Posted by symphy
    What FSB does it reach after the mod and what voltage does your DMM measure?
    I measure only 1.3V at the mosfet's leg if i set 1.65V in bios.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    symphy
    Guest
    Hm, i think you did something wrong. I did this mod more than 5 times... Functions very well. I reached about 475-485 MHz with 2,1 V and watercooling.
    http://hardwarextreme.de/upload/revi...s/vMCH_Mod.jpg
    Look at this picture, "VMCH Messpunkt" = "Vmch Readout"
  18. #18
    I am Xtreme
    Feb 2003
    Netherlands
    Tried that point, still only 1.3V
    I used the DC setting on my DMM, that the right one no?
    The DMM must be ok, reads Vgpu just fine.
  19. #19
    symphy
    Guest
    Yeah, DC is right...
    Hm, no clue what happend to your board. It works fine i assume (beside the 1,3V problem)?
    Recheck your soldering work, the error has to be somewhere at the soldered points i think...
  20. #20
    I am Xtreme
    Feb 2003
    Netherlands
    I will PM you, not to furher hijack this thread, sorry for doing so.
  21. #21
    Jun 2004
    I did run 1m @ 483mhz fsb, this is less then 500mhz fsb and your's is 32m, but mine is at multi 9 and with just 1,9v vmch, no vfsb mod yet
    My Setup:
    E6600@ 1,58v vcore Single stage cooled
    DFI Infinity 975X met Vmch mod @1,9v (NB air cooled)
    2x1gb Gskill pc6400HZ @2,35v
    Sapphire X1900XTX
  22. #22
    -100c Club Member
    Dec 2004
    Europe
    Not bad guys, any pics of setup?
    regards
    My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LNē Pots, LD GFX-R1 Dice/LNē Pots,
    LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
    LD PC-V8 Watercooling Cases:
    LINK
    LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
    www.ldcooling.com
    Find US on Facebook
  23. #23
    May 2006
    Philippines ^_^
    Quote Originally Posted by El Snorro View Post
    My Setup:
    Sapphire X1900XTX
    very nice.. can you link the mod and what bios have you use??
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  24. #24
    Jun 2004
    Quote Originally Posted by erwinz View Post
    Mods: http://www.xtremesystems.org/forums/...light=infinity
    And the 12/01 bios:
    http://www.lejabeach.com/DFI/dfiinfi...x/97TIDC01.zip
    Here is also rest of the biosses:
    http://www.lejabeach.com/DFI/dfiinfi...inity975x.html
  25. #25
    Aug 2005
    Germany; Niedersachsen; Schaumburg; Bad Eilsen
    i tried the 12/01/06 Bios and was able to boot with 400mhz fsb and 1,75. But only one time. Now the screens stay black and the pc doesnt boot ...
    Now i am at sth about 380mhz ...
    I know my english isnīt the best ...
    my pc
    oVerkill.OC - Technic3D
