What's new?
Yeah! Where's the changelog?
MB: Asus Crosshair VI Hero / Bios ver:6102 / Cpu:Ryzen 2700x @ 4.2Ghz (24/7) (1.373), FSB 100x42
Ram: GSkill PC4-25600 2x8Gb @ 3200MHz, 14-14-14-14-34-1T, 1.352v
Gfx: EVGa 1080Ti GTX FTW DT
SSD: Samsung 960 M2 Evo 500 GB
PSU: Corsair HX1000W
Cooling: EKWB L360 Kit
Temps: Cpu: 30c Ambient / 28c @ Idle / 65c @ 100% Load
wow that's fast where did you get this?
E6600 @ 3.2ghz (400x8), P5B Deluxe, 2GB Ballistix DDR2-1000 @ 600mhz 5-5-5-15, X1950 Pro, Antec Neo HE 500w
Support 1333Mhz FSB Processors
P5B-E 0904
P5B-E PLUS 0504
P5B
P5B-E
P5B-E PLUS
P5B Deluxe
P5B Deluxe Wifi-AP
All Support 1333Mhz FSB Processors
Ok, got it from asus website
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
lol where i can never seem to find new bios on their website. They are so unorganized.
I'm on 1004 as well, no problem so far.
I hosted the firmware so you guys can get it faster than asus tw site.
www.tonysmod.netfirms.com/downloads/P5BD1004.zip
thanks will try it soon![]()
Thanks T07N, I'll flash later today and see how it is compared to 804Originally Posted by T07N
lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
I got this 1004 bios, and it didnt seem to help my OC at all, but my ram is much more stable now.
previously, I had been running cas 5-5-5-12-5-42-10-10-10-11.
8 x 450 quad core, at 4:5. 2.25 volts.
now the same speed and ratio, still 1125 mhz, but now its doing the same thing, with a slightly lower cas.
cas 5-4-4-12-4-35-10-10-10-11.
same voltage and all.
the underlined, is where things I managed to get alittle tighter and stable with this bios.
Ok, I just got another p5b deluxe but I'm having trouble with this one. Seems like there are different flash roms on every motherboard. I don't know if this is a flash rom problem or what but I can't seem to flash my board through ez flash with usb stick anymore.
Here's my thread, please read, thx: http://www.xtremesystems.org/forums/...d.php?t=131413
I'm currently running 0804, and it's working fine. You got any results with 1004 yet?Originally Posted by alpha0ne
I flashed earlier tonite and it seems to be working fine but I have not done any comprehensive testing as yet though Kunaak /\ seems to be having positive resultsOriginally Posted by CHRING
I just posted my results:
http://www.xtremesystems.org/forums/...postcount=3128
MainPC():
Q6600 + 8GB RAM + 160GB SSD + 1.5TB HDD + Visiontek HD4850 + Gigabyte P965-DS3 rev3.3
HTPC():
E4200 + 4GB RAM + 160GB SSD + Samsung F1 2x1TB RAID-0 + Asus EAH 3450 + Asus P5E-VM HDMI + KWorld ATSC-110 HDTV
Laptop():
CR-48
Will test it soon
P5B Deluxe Release BIOS 1004
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**Do not use AsusUpdate to downgrade BIOS. For such need, please use EZFlash or AFUDOS instead**
I cant boot from my ide optical drive anymore since flashing to 1004![]()
someone tell Anus to stoping around and just fix the 4:5 ratio and make RAM MHz OCs the same as 1:2 and other ratios
what are your MAX RAM MHz clocks with 1:2 and 4:5 ratios.......Originally Posted by Kunaak
I found its my new POS LG burnerOriginally Posted by alpha0ne
1007??? four days for 1004 and asus give us a new one??? o what? 1007 is oficial? Repàir some problem important or 1004??? or what!
Read the thread!
Sorry :d jejeje 1007 P5B and 1004 P5B Deluxe.. sorry.. i was dpoing a lot of thing and i've read bad!!!
Please help me where can i get 0910 BIOs for P5b Deluxe?
^^check asus sitego easy on the weed lol
http://dlsvr01.asus.com/pub/ASUS/mb/...P/P5BD0910.zip
