Results 1 to 5 of 5
Thread: NVIDIA nTune v5.05.22.00 Released
    Feb 2006
    Download Here
    OS : Windows XP (32-bit),Windows Vista (32-bit) for find more OS look www.nvidia.com
    NVIDIA nTune Release Notes
    Version Number Description:
    5[Major version].05[Release version].00[Beta version].00[Alpha version]
    Version 5.05.22.00
    1. Fixed issue in which the "Game" rule is not handled properly
    Version 5.05.21.00
    2. Added support for Microsoft Vista 64-bit OS
    3. Fixed issue in which auto-tune would not complete with a supported graphics card
    using a driver that is not rel90 or later.
    4. Added access to NVMonitor from the performance category view.
    5. Fixed bug that temperature rule is executed incorrectly.
    6. Fixed bug that tWR and tWTR memory timing values did not match the BIOS
    settings in Intel CPU platforms.
    Version 5.05.20.00
    1. Fixed issue in which the clock readings on the GPU settings page don't get
    updated when a profile is being loaded.
    Version 5.05.19.00
    1. Fixed issue in which temperature and fan RPM data would not refresh on the
    Motherboard and GPU settings pages.
    2. Fixed issue in which the Intel CPU FSB was not shown correctly on some
    motherboards using NVMonitor.
    3. Fixed corrupted text seen in some list box entries on the Dynamic BIOS Access
    page.
    4. Fixed issue in which nTune would exit when accessing certain pages like
    Motherboard Settings when using an OS with a non-US language.
    Version 5.05.18.00
    1. Fixed issue in which CMOS is corrupted after save/restore of a profile.
    Note: Previous profiles will no longer work with this build. Please delete previous
    profiles in the profiles directory, as these will not have been removed from the
    previous uninstall.
    Version 5.05.15.00
    1. Added feature to save/restore the original fan power when switch between Auto
    and manual control.
    2. Fixed issue in which launching NVMonitor takes > 2 minutes when in SLI mode
    and intense graphics are running in the background.
    Version 5.05.14.00
    1. Fixed issue in which autotune would fail to launch on some nForce Intel
    combinations.
    Version 5.05.13.00
    1. Expanded the ranged for FSB for certain nForce chipset and processor
    combinations.
    2. Removed “Memory Clock” displayed text from Motherboard Settings page.
    Version 5.05.12.00
    1. Fixed issue with displaying correct CPU Multiplier value on Kentsfield
    processors.
    Version 5.05.11.00
    1. Updated Dynamic SBIOS Access fields for enabled systems.
    Version 5.05.10.00
    1. Updated voltage control steps for the nForce Intel platforms
    Version 5.05.09.00
    1. Fixed the CPU high usage consumption when running on a system with no
    specific BIOS support but with GPU temp read back.
    2. Added tWTR memory timing control to Motherboard Setting Page.
    3. Fixed bug PCIe bus speed is not showed in correctly on some motherboards.
    4. Fixed issue in which the Intel CPU multiplier and FSB were not shown correctly
    5. Fixed the FSB voltage string on some motherboards.
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    anyone really use it ?
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Coat It with GOOOO
    Aug 2006
    Portland, OR
    Quote Originally Posted by SaFrOuT
    perhaps if they make the interface a tad more user friendly.
    Main-- i7-980x @ 4.5GHZ | Asus P6X58D-E | HD5850 @ 950core 1250mem | 2x160GB intel x25-m G2's |
    Wife-- i7-860 @ 3.5GHz | Gigabyte P55M-UD4 | HD5770 | 80GB Intel x25-m |
    HTPC1-- Q9450 | Asus P5E-VM | HD3450 | 1TB storage
    HTPC2-- QX9750 | Asus P5E-VM | 1TB storage |
    Car-- T7400 | Kontron mini-ITX board | 80GB Intel x25-m | Azunetech X-meridian for sound |
    Apr 2006
    Pleasant Hill, MO
    what does it do?
    Ryan
    "Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
    Abit IP35 Pro
    Intel Core 2 Quad 6600 @ 3200 w/ Tuniq Tower
    2x2gb A-Data DDR2 800
    AMD/ATi HD 4870
    Feb 2006
    Quote Originally Posted by FghtinIrshNvrDi
    what does it do?
    Ryan
    Download complete guide here :
    http://us.download.nvidia.com/Window...user_guide.pdf
    Read it to find out more :
    Overview:
    NVIDIA® nTune is the ultimate utility for accessing, monitoring, and adjusting your system components, including temperature and voltages with clear, user-friendly control panels. Overclock your system for highest performance or underclock it for near silent operation. All changes are performed within the Microsoft® Windows® interface – enabling full functionality without the need to make changes in the BIOS and reboot your system.
    Installation Notes:
    This application package replaces all previous versions of the NVIDIA System Utility or NVIDIA nTune. Earlier versions of the application should be uninstalled and the system rebooted prior to installation of this package.
    Support for the advanced features of the NVIDIA nTune requires vendor specific setup files that are not included with this package. Please contact your motherboard or system vendor for the correct files to enable this functionality.
    Release Notes:
    This is a complete, updated release of the NVIDIA nTune. You are not required to install a previous version of this application before installing the latest version.
    nTune 5.05 adds support for GPU temperature monitoring and overclocking on all motherboards.
    On nForce motherboards where specific BIOS support is not available, only basic functionality will be available.
    Products support for advanced motherboard monitoring features:
    nForce 220, nForce 220D, nForce 415 and nForce 420D
    nForce2 and nForce2 400
    nForce2 Ultra and nForce2 Ultra 400
    nForce2 400R and nForce2 Ultra 400Gb
    nForce3 150 and nForce3 PRO 150
    nForce3 250, nForce3 250Gb and nForce3 PRO 250
    nForce4 Pro 2200, nForce4 Ultra, and nForce4 SLI
    nForce 590 SLI, nForce 570 SLI, nForce 570 Ultra, nForce 550
    nForce 680a SLI, nForce 680i SLI, nForce 650i SLI, nForce 650i Ultra
