Results 1 to 15 of 15
Thread: G.skill F2-6400cl4d-2gbhk
    Champion
    May 2006
    Bangkok, Thailand
    Brand-new from G.SKILL on F2-6400CL4D-2GBHK
    Stock 800MHz CL 4-4-3-5 Voltage 2.0-2.1
    new heatspreader design
    6 layer PCB
    under heatspreader ......
    Some results with test on X6800 , ASUS P5B-E Plus (non Vmod)
    SuperPI 1M@1200MHz CL5-5-5-5 Vdimm 2.45
    with success on PI 32M @1100MHz CL 5-5-4-5 Vdimm 2.45
    MAX Stability on stock latency (4-4-3-5) @ 1000MHz Vdimm 2.35
    Sorry For My English
    OverclockZone Team
    THAILAND
    Sep 2006
    Edit: NM: Can someone help fix the pictures, or is it just me?
    Will these replace the HZ, or is it a new line of ram?
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Intel i7 3770k
    ░░░░░░▄▄▄▄▀▀▀▀▀▀▀▀▄▄▄▄▄▄░░░░░░░░░ ASUS GTX680
    ░░░░░░█░░░░▒▒▒▒▒▒▒▒▒▒▒▒░░▀▀▄░░░░░ ASUS Maximun V Gene
    ░░░░░█░░░▒▒▒▒▒▒░░░░░░░░▒▒▒░░█░░░░ Mushkin 8GB Blackline
    ░░░░█░░░░░░▄██▀▄▄░░░░░▄▄▄░░░█░░░░ Crucial M4 256GB
    ░░░▀▒▄▄▄▒░█▀▀▀▀▄▄█░░░██▄▄█░░░█░░░ Hitachi Deskstar 2TB x2
    ░░█▒█▒▄░▀▄▄▄▀░░░░░░░░█░░░▒▒▒▒▒█░░ FSP 750W Gold
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Fractal Arc Mini
    Jun 2006
    Belgium - Brussel
    ratio 4:5 is not the best for testing the ram
    Nov 2005
    The Netherlands
    looks good so far?
    are these D9GMH ?
    Sep 2006
    Well it looks like it is at the Egg now.
    http://www.newegg.com/Product/Produc...82E16820231114
    Sep 2006
    The Netherlands
    Quote Originally Posted by TaPaKaH
    are these D9GMH ?
    The dot in the bottomleft corner indicates it's a Hynix IC, but it is Promos.
    May 2006
    Hannover, Germany
    those look real nice! price tag is also quite pretty for the results you have, good stuff!
    CPU: Core 2 Duo T7250 2.0GHz
    RAM: 2x2GB OCZ PC2-5400 CL5
    GFX: Intel GMA X3100
    HDD: 160GB
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by Quentin
    ^^^^ he's right ^^^^^
    Team.AU
    Got tube?
    GIGABYTE Australia
    Champion
    May 2006
    Bangkok, Thailand
    Quote Originally Posted by dinos22
    yep.... i'll try again on other ratio and update to next time
    OverclockZone Team
    THAILAND
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by ZoLKoRn
    600Mhz at 2.45vdimm is nice man
    Team.AU
    Got tube?
    GIGABYTE Australia
    Feb 2006
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    Champion
    Dec 2005
    Budapest, Hungary
    but how they like higher voltages, 2.5++?
    Quote Originally Posted by AndreYang View Post
    I think mine is better.
    Jun 2006
    These seem like great 24/7 ram, but as Achill3us points out, Promos doesn't scale with voltage. If you just need ram for a 24/7 OC rig, I have absolutely no qualms recommending these kits, but for benching D9 is still where it's at.
    Champion
    Dec 2005
    Budapest, Hungary
    Quote Originally Posted by Stapler
    thanks, It seems to be Promos is a good budget overclocker ic, and for ~250$ you cant buy better, but as an other point that you told, 250$ for a memory that you cant use for extreme oc, not so good. +50$ and you can buy Team Xtreem 6400, G.Skill HZ, or something with D9GMH.
    Feb 2006
    but Promos produce amount of heat!!
