thought we could start one here because the other one got closed
make this a sticky?
Posting rules
RULE 1: you must post the following data for each OC submission:
Post it in the following format please:
User Name:
Stability: (Example: 4hours+ Prime95, orthos)
CPU name (Example: E6600)
OC: (Example: 3403MHz)
Stepping: (Example: 6 B2)
Week: (Example: L623)
Code: (Example: A790)
Vcore: (Example: 1.425) "Stock" is not acceptable. It is not the same on different motherboards.
Cooling: (Example: Water)
Cooler brand/model: (Example: Scythe Infinity)
Motherboard: (Example: Asus P5B Dlx)
Bios Version: (Example: F4E)
Operating System: (Examples: XP 32, XP 64, Vista, OS X)
RAM brand: (Example: Crucial)
RAM rated speed: (Example: PC8000)
RAM actual speed: (Example: 950)
Latency: (Example: 3-3-3-12)
RULE 2: A screenshot of CPU-Z, CPU-ID or a CPU-Z validation link.
RULE 3: Overclock entries must be submitted with a screenshot of at least a 8 hours Prime95, Orthos (small FFTs or Blend test) or SP2004 run (all cores) to be included in the main database.
Conroe Stepping Info---Conroe Week------Conroe Code (The Week and Code are found on the CPU box and on the CPU itself.)
A-1 = stepping 1-------------In form of L6##----In form of A###
B-0 = stepping 4-------------Example: L617A846= Week L617 Code A846
B-1 = stepping 5
B-2 = stepping 6
The Screenshot must have orthos/Prime running.. Idle or crashed results will not be included from now on.
Must have atleast 8 hours of Orthos, (small FFTs or Blend) or Prime. Initially several 4-6 hours were added but from now only 8 hours or more will be added.
I will try and update this asoften as I can
Blue* official results (with all columns filled proven stable)
Grey* not offical (but proven stable)
keep them comming
