Page 1 of 3 123 LastLast
Results 1 to 25 of 72
Thread: P5B Deluxe timings 4-4-4 > 4-4-3 > 3-3-3 ?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Question P5B Deluxe timings 4-4-4 > 4-4-3 > 3-3-3 ?
    I just bought my first 965P chipset based board, Asus P5B Deluxe and playing around with E6600 B1 and 9x400fsb 1:1 boot from bios just to get a feel for the board.
    I read that 4-4-4 is faster than 3-3-3 timings ????
    I just tested 32M
    400mhz 4-4-4-4 ~14min 39s untweaked and ~14min 32s memset tweaked
    400mhz 4-4-3-4 ~14min 38s untweaked
    400mhz 3-3-3-8 running right now but at half way mark is already 30 seconds slower than either 4-4-4-4 or 4-4-3-4 tests ????
    I'm using 0804 bios.... anyone get to the bottom of this yet as to why 3-3-3-8 is so slow ?
    thanks
    xtreme energy
    Oct 2004
    Europe, Latvia
    3-3-3 is slow for me too but 4-4-3 is better than 4-4-4. I am using 711 bios. Can you show your subtimings?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Haven't uploaded all my results yet as still running 3-3-3-8 32M right now
    but here's for 4-4-4-4 and 4-4-3-4 with untweaked OS and just bios set changes in timings NO memset changes at all
    VS
    looks like when i set tRP = 3, bios automatically changed All Precharge to Activate and All Precharge to Refresh delay from 4 to 3.
    then tried 4-4-4-4 with memset tweak changed RAS to CAS Write delay from 4 to 2
    Xtreme X.I.P.
    Dec 2003
    Yep, welcome to the world of P5B Deluxe wackiness Useless of 3-3-3 is one of them I have done a little comparison somewhere a while ago - past "straight-booted" 400MHz FSB, 3-3-3 becomes faster than 4-4-4 but that's mainly due to chipset latencies being loosened up (or strap change, depending on who you ask ), which super-oddly does not affect 3-3-3 at all, only 4-4-4 or 4-3-4-4 or 4-4-3
    http://www.xtremesystems.org/forums/...6&postcount=28
    Xtremely Addicted
    Dec 2004
    NL
    I thought ras to cas 3 is the problem. 3-4-3-4 is faster for me then 3-3-3-4 but about the same as 4-4-4-4
    May 2006
    Belgium
    Happens for me too, but found out that putting that one setting on 4 and rest to 3 fixed it indeed.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks guys for the education! very weird stuff indeed
    Quote Originally Posted by bachus_anonym
    knew I could count on you to have comparison results handy
    so would the reverse be true ? if i was to set 3-3-3-8 in bios and boot at 401+ fsb, the use clockgen to downclock to 400fsb and I should get times faster than boot at 400fsb 3-3-3-8 ?
    Jul 2005
    Memory speeds
    Am testing now my new rig BFG 680i 2x8800 GTX now that RAM speeds can be set really high I'm wondering will I benefit more running my TWIN2X-6400C4 @ 4-4-4-12 @ 900? Or so far I have been able to get 5-5-5-15 2.2v @ 1090 maybe 1100 depending on room temp ambient.
    Basically I'm looking for better overall gaming / performance on the system either way.
    PC1 EVGA Nvidia 790i Ultra | E8400 Retail @ 4.05GHz 1.35v | 8GB Mushkin Ascent @ DDR3-1680 | 2xBFG GTX 280 SLI @ stock | 30" Dell 3008WFP @ 2560x1600 XHD | XFI Fatality | 3x256GB Corsair(Samsung) SSD Raid0 & 1TB Samsung Backup | LG DVD / CDRW | NEC DVD DL 16x | CoolerMaster Stacker 830 8x120mm high 110 CFM per fan| 1000w Corsair SLI certified | Scythe Infinity (dremel mod to avoid caps on board)
    PC2 (Wife) ASUS P5WDH Bios 1101 | E6400 Retail @ 3.2 | 4GB Corsair 6400C4 | 1xBFG GTX 260 @ stock | 24" Dell 2405FPW @ 1920x1200 XHD | XFI Xtrememusic | 2x150G Raptor Raid0 & 1TB WD Backup | Pioneer DVD | CoolerMaster Stacker 830 | 850w PCP&C | Stock HSF
    Jan 2003
    Knoxville, TN
    i think if you boot at 401 then you're on the 1333/1600 strap.
    if you boot at 400, you're on the 1066 strap.
    my guess would be 400 clockgen'ed down from 401 would be slower than straight boot at 400.
    i get this board soon as well (today or tomorrow).
    Main Rig:
    CPU Intel i5 2500K @ 4500mhz
    Mobo Gigabyte GA-Z68X-UD3H-B3
    Memory 4x4GB Corsair Vengeance DDR3 1600
    Video Cards Sapphire 5850
    PSU Silverstone ST75F Strider 750W
    Hard Drive OCZ Solid 3 60GB | OCZ Vertex 2 60GB | Samsung 103SJ's 4TB
    Cooling Thermalright Ultra 120 | 1 Yate Loon D12SM 120MM
    Memory Addict
    Aug 2002
    Brisbane, Australia
    pentium777 only way to know is test it for yourself i
    so far my tests concur with bachus and other folks findings
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 400
    DRAM Frequency: DRR2-800Mhz
    PCI Express Frequency: 100
    PCI Clock Synchronization Mode: 33.33Mhz
    Spread Spectrum: Disabled
    Memory Voltage: 2.1v
    CPU Vcore Voltage: 1.4375v (1.384v)
    FSB Termination Voltage: AUTO
    NB Vcore: AUTO
    SB Vcore (SATA/PCIE): AUTO
    ICH Chipset Voltage: AUTO
    Straight boot from bios
    @400mhz 4-4-4-4 2-20-3-9-7-9
    Memory Remap Feature: Disabled
    Configure DRAM Timing by SPD: Disabled
    DDRAM CAS# Latency: 4
    DRAM RAS# to CAS# Delay: 4
    DRAM RAS# Precharge: 4
    DRAM RAS# Activate to Precharge: 4
    DRAM Write Recovery Time: 2
    DRAM TRFC: 20
    DRAM TRRD: 3
    Rank Write to Read Delay: 9
    Read to Precharge Delay: 7
    Write to Precharge Delay: 9
    Static Read Control: Disabled
    Memset tweak change RAS TO CAS Write Delay from 4 to 2
    DRAM TRFC: 20
    DRAM TRRD: 3
    @400mhz 4-4-3-4 2-20-3-9-7-9
    DRAM RAS# Precharge: 3
    DRAM TRFC: 20
    DRAM TRRD: 3
    @400mhz 3-3-3-8 6-42-10-10-10-10
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 400
    Memory Voltage: 2.25v
    NB Vcore: AUTO
    DDRAM CAS# Latency: 3
    DRAM RAS# to CAS# Delay: 3
    DRAM RAS# Activate to Precharge: 8
    DRAM Write Recovery Time: 6
    DRAM TRFC: 42
    DRAM TRRD: 10
    Rank Write to Read Delay: 10
    Read to Precharge Delay: 10
    Write to Precharge Delay: 10
    @400mhz 3-3-3-8 2-20-3-9-7-9
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 400
    NB Vcore: AUTO
    DRAM TRFC: 20
    DRAM TRRD: 3
    @402mhz 3-3-3-8 2-20-3-9-7-9
    Clockgen down to 400mhz 3-3-3-8
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 402
    DRAM Frequency: DRR2-804Mhz
    NB Vcore: AUTO
    DRAM TRFC: 20
    DRAM TRRD: 3
    @400mhz 3-4-3-4 2-20-3-9-7-9
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 400
    NB Vcore: AUTO
    DRAM TRFC: 20
    DRAM TRRD: 3
    Bio Settings:
    AI Tuning: Manual
    CPU Frequency: 400
    NB Vcore: AUTO
    DRAM TRFC: 20
    DRAM TRRD: 3
    Really weird behaviour going on here! Seems below 400FSB 4-4-4 and 4-4-3 timings are faster than 3-3-3 and the culprit is tRCD value, but above 401FSB, tRCD 3 (i.e. 3-3-3) picks up performance like expected it seems if you read http://www.xtremesystems.org/forums/...6&postcount=28 and http://www.xtremesystems.org/forums/...d.php?t=123284
    Jan 2003
    Knoxville, TN
    WHOA
    interesting...
    straight boot 400 vs. boot up at 402 and clockgen down is interesting indeed!
    at cas 3 it's faster when you clockgen down. that is definitely a surprise!
    thanks for the results.
    Main Rig:
    Xtreme X.I.P.
    Dec 2003
    Nice work
    If you want to play more, boot @ 400 8-4-4-4.0 and run e.g. 32M. Then after it's done, use MemSet to "tighten" to 8-3-3-4.0 (or anything else with TRCD=3) and run 32M again... Watch how 32M result face-plants. I tried it few times and this what happened - i might have a screen somewhere... Funny, 3-3-3 slower than 4-4-4, eh That's pretty much the only beef I have with ASUS and this board...
    Your example of boot @ 402 and down to 400 is quite interesting... I never tried that. Though, it's still slower than boot @ 400 4-4-4...
    May 2006
    Belgium
    Great job again, wow
    Come to think of it, I'll have to be carefull to post results with cas 3 in my upcoming reviews...
    "The light at the end of the tunnel is the headlight of an oncoming train" (Murphy)
    Reviewing for Madshrimps
    May 2006
    Philippines ^_^
    nice.. really thinking about geting this board..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks guys
    Nice work
    not sure i follow ? you mean setting timings using memset is slower than straight boot from bios set timings ?
    Oct 2006
    Quote Originally Posted by shimmishim
    Let us know if your chipset is c1 or c2. I've heard there differences with memory timings.
    Thanks.
    Apr 2005
    Melbourne, Australia
    Can someone please try 3-2-2-4 @ 400Mhz, probably only those with Vdimm mods or extremely nice DDR2 !
    I know exactly what everyones talking about with P965 chipset & 32Mb SuperPi... and I thought my board or hardware combo was crap...
    Signature? are you kidding? with new stuff coming out every day, why bother ?
  18. #18
    Sep 2006
    I dont think trying those timings are necessary. 3-3-3-x didn't do so well so what would setting it tighter do? We will see the same trend.
  19. #19
    Aug 2006
    Europe/Germany/Bavaria/Munich
    Nice Tests
    And what's when you boot from 400 or 402 and go then on overclocking? Are then the lower timings better?
    Q6600 | 8800 GTS 512 | 4GB 800er MDT | Abit IP35 Pro | Corsair HX520W | Seagate Barracuda
  20. #20
    Champion
    Nov 2004
    Hungary
    Thank you great test eva!
    "We are competing, competing to win. And the main motivation is to compete for victory" - Ayrton Senna
  21. #21
    Xtreme 3DTeam Member
    Oct 2006
    good job
    E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
    QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
    Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
  22. #22
    Mar 2006
    Hellas
    Actually ther best timings is 4-4-2 for 1066 strap.Even 3-2-2 is worst..
  23. #23
    I am Xtreme
    Dec 2002
    man ram clocks so nice in the P5B it's too bad they don't give us proper control of the timings.
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by deadlock7
    interesting haven't tried 4-4-2 yet
  25. #25
    Apr 2005
    Quote Originally Posted by Will Eatforfood
    It could be logical to presume that, but it does'nt mean that will be the case. Has someone tried this yet ?
