when under the same task and condition, how faster quad-core will win over dual core?
platform1
M/B :ASUS P5B Deluxe
MEM :G.SKILL 2GB Dual Channel
HDD :Seagate 250g SATAII 16Mb Cache
VGA CARD :winfast 6200TC
POWER: Zippy 600WG1
OS :WIN SEVER 2003
CPU COOLER:Tower 120
CPU :Intel Core 2 Duo Conroe E6600 S6 4mb cache
platform2
MEM :ChannelG.SKILL 2GB + XTREEM 2GB Dual Dual Channel
VGA CARD :6600GT
POWER: Zippy 850WG1
OS :WIN SEVER 2003
CPU :Intel Core 2 Quad QX6700 S7 ES 8mb cache
test info
400*9=3.6g
DDRII800 3-3-3-4-5-7-10-5-9
1.Dual spi1M
C2D@3.6Ghz
C2Q@3.6Ghz
See even though the two processors are under same speed, however, quad-core
still got space todeal with super pi 1m, that's why it is faster than dual core 2 seconds.
2.Dual spi32M
C2D@3.6Ghz
C2Q@3.6Ghz
no need to say about 32m, it even fastern than dual core about 30 seconds.
3.Cinebench9.5
C2D@3.6Ghz
C2Q@3.6Ghz
here we can check that out with 3D calculation mode under single core, they both
scaled the same results; but if we use multi-cores to do that, apparently, quad-core would faster than dual-core about 100%.
How about Sandra some benchmarks?
CPU Test1 ; C2D @3.6ghz:
C2Q@3.6Ghz
CPU Test1 ,the score from quad core is 100% off dual core
CPU Test 2
C2D@3.6Ghz
C2Q@3.6Ghz
CPU Test 2,Quad-Core is still about 100% off dual core
how about Memory Bandwidth?
C2D@3.6Ghz
C2Q@3.6Ghz
Dual Core 2DIMM seems larger than quad-core 4DIMM about 100MB/S
L2 Cache
C2D@3.6Ghz
C2Q@3.6Ghz
L2 Cache quad-core 8mb cache under the additional 63% of bandwidth, the speed
is also 100% off dual core.
5.File compression
C2D@3.6Ghz
C2Q@3.6Ghz
5.File Compression
C2D@3.6Ghz
C2Q@3.6Ghz
WinRAR seems like doesn't support multi-tasking, but under the same condition for compressing
32mb folder, quad-core still won over about 7 seconds.
6.3DMARK06 CPU TEST
C2D@3.6Ghz
C2Q@3.6Ghz
C2D 3000pts C2Q 5271pts
7.Encode
C2D@3.6Ghz
C2Q@3.6Ghz
TMPEG supports Multi-Tasking, for the same work of converting 2 files, Quad-Core certainly won over dual core without any problem.
8.SUPERPIRME
C2D@3.6Ghz
C2Q@3.6Ghz
wow!33s VS 17s![]()
9.PCMARK05
C2D@3.6Ghz
C2Q@3.6Ghz
C2Q 11445pts
C2D 9082pts
excellent, thanks coolaler
Wow - one of the best tests I've ever seen - nice work. I vote for
, E6750 es
