Conroe E6700es B1
Gigabyte 965p-DQ6 C1 stepping
Micron DDR2_667 1G*2 with ECC
RaptorX 150G/Zippy PSL-6701P
Gigabyte Dq6 is sux, max vcore=2.3v in bios, can boot up with 1.7v or maybe more.
but...you cannot set a high clk in bios and made the mobo start as normal.
the worst thing is, I can only overclk Dq6 with Easytune5, clkgen 1.05 don't work.
but ET5 seems won't let u get vcore=1.58v+, or system will crash!
Even if the mobo has 2bios as giga claimed as a good feature, I found it very very hard to recover when overclk failed. but in fact, I do not overclk too much. 3.6Ghz may even have a "non-recoverable problem".
Have to take the battery out 'coz there is no CLRCMOS pin on the mobo. made me feel really bad.
I bet it's a WR E6700 if I make this DI journey on Asus.
1.58v set in ET5, actual vcore=1.56v(read by melemeter)
DI cooling, temp= -45c idle. ( DI's quality in Shanghai always bad, I've get used to that. )
4.64G pi_1m, should break 11sec if on asus with higher ram clk, but... never imagine that on Giga
max cpu clk I've reached on the mobo. 4800mhz
1.7v 4.75G ? benchable or just saw a cpuz screen ?
, E6750 es
