Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: New Benchmark: SuperPrime 0.14beta
    Oct 2005
    Milton Keynes, UK
    Smile New Benchmark: SuperPrime 0.4beta
    Hey guys,
    New release:
    Version 0.4beta
    28-Sept-2006
    - Modified the way results are presented to have a more professional (and intuitive) look.
    - Changed startup code to change the default run parameters depending upon the system configuration (processor count.)
    - Added a option where user can copy forum quote text directly.
    - Included a high resolution timer to provide much more accurate results.
    - Changed version number to 0.4beta
    Thanks to RiO for convincing me to go for the tabular based view and for the various UI tips. Thanks a ton to TE admins for making www.techenclave.com/forums/superprime/ a reality
    http://www.techenclave.com/forums/su...me-0.4beta.zip
    Regards,
    Karan Misra
    ps: slowly but surely i am chugging away towards 1.0
    original thread: http://www.techenclave.com/forums/ha...ime-79345.html
    My work and bench rig:
    i7 920 D0 3939B303 @ 4.2Ghz + ASUS P6T Deluxe V2 w/ 0006 BIOS + 6GB Corsair Dominators CL7 @ DDR3-1600 7-7-7-20-1T + Intel X25-M 80GB SSD G2 + Powercolor HD5870 1GB @ 900/1300 + Dell U2410 H-IPS 24" Screen (pics and more)
    My review site: Erodov
    Mar 2005
    Quote Originally Posted by kidoman
    requirement: .Net 2.0
    No thanks
    Oct 2005
    Milton Keynes, UK
    Quote Originally Posted by [timko]
    No thanks
    o common.... u install a 650 MB os from the beast, afraid of a 20 MB framework? :P waiting for results.
    Mar 2006
    .NET bloatware
    Write it in a proper language like C/C++, Borland do a great IDE.
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by Durzel
    .NET bloatware
    alright i will keep ur SUGGESTION in mind, but for the while mind to try it?
    i will get you guys started:
    ps: and imagine when vista comes, every damn GUY will be running the same bloatware you are dissing now
    xtreme energy
    Oct 2004
    Europe, Latvia
    Conroe @ 3.6Ghz
    http://www.xtremesystems.org/forums/...1&d=1158450654
    Attached Images Attached Images
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by kiwi
    so i guess with a quad core chip, we should see sub 20secs? if they scale that well i.e.
    (*dont even wanna imagine clover town pwnage*)
    Xtreme Cruncher
    Mar 2005
    Houston
    Here you go.
    Kentsfield @ 3.255GHz
    2 x 512 @ 976MHz (4-4-4-12)
    312 Xeon Threads + GTX 1080 + GTX 1070 + BFL Monarch 700
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by KaptainBlaZzed
    Here you go.
    neat result... i will do a 5E8 run to see how it compares with ur mighty kents....
    pls do a highest + 5E7 run.... with 4 threads. i wanna see sub 20 secs on it (i get around 37 sec average)
    edit: can you do a 2 thread run please? cuz i want to see the scaling from 2 threads to 4 threads.
    Jun 2006
    Canada
    SuperPrime 0.13beta @ www.techenclave.com
    Total number of threads: 1
    Calculating with resultset: 5E7
    Total primes reported: 3001134 (VALID RESULT)
    Calculations took: 0 h 3:7:93
    Validation url = http://www.techenclave.com/sprime/vl...3&c=A064B09822
    http://valid.x86-secret.com/show_oc?id=122153
    Something's wrong I think.. or maybe its just the netburst.. lol.
    edit: re-run it with 2 threads... but I dont have HT and its around the same result so I guess it wasnt an error.
    Total number of threads: 2
    Calculations took: 0 h 3:6:812
    Validation url = http://www.techenclave.com/sprime/vl...2&c=C2657F23D4
    Prescott 2.4 @ 3.6 air, stock vcore under a Thermaltake Big Typhoon
    Asus P4P800-E deluxe no mods
    BFG 6800gt 256mb @ 420-1100
    4x512mb (2cvs, 1corsair c2, 1kvr)
    RAID 0 + bunch of storage totaling about 2TB
    Enermax Liberty 620w [since 2006-06-21]
    Antec SLK3800B
    36.031s SPI 1m @ 3971mhz
    No need for a faster pc, im always on my laptop anyway.
    Xtreme Cruncher
    Mar 2005
    Houston
    Kentsfield @ 3.255
    Ram 976MHZ 4-4-4-12
    Total number of threads: 4
    Calculations took: 0 h 0:25:484
    Calculations took: 0 h 0:37:359
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Allendale at 7 x 500
    1 gig of ram, cas 4-3-2-8
    Feb 2004
    Wr for the moment -_-
    this was really long ;p
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    omg 8hrs hehehe
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Oct 2005
    Milton Keynes, UK
    Hmm, after seeing the results of quad-core runs via peeps over @ XS (thread here)..... i saw that the algorithm was not scaling as well as I would have liked. Hence I implemented a new dynamic load balancing algorithm, and hence this new beta. Test it for me guys:
    Version 0.14beta
    17-Sept-2006
    - Improved the dynamic load balancing algorithm so that it scales well with > 2 physical cores.
    - Characterized the different working set sizes based on their intended purposes.
    - Changed version number to 0.14beta
    Regards,
    Karan
    Attached Files Attached Files
    Oct 2005
    Milton Keynes, UK
    updated first post with new beta.....
    Oct 2005
    Mumbai, India
    SuperPrime 1E7 2 Threads @ 3915 Ghz.. - 2.625
    SuperPrime 5E7 2 Threads @ 3915 Ghz.. - 31.15 s
    Sorry for Sloppy Shots.. Was in a hurry.
    CPU : E8400
    Motherboard : Abit IP-35 Pro
    Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
    Graphics Card : Palit HD4870 Dual Sonic
    Display : Dell E228WFP
    Storage & OS : 1TB | Windows 7 64bit
    Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
    Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
    Case : Coolermaster ATCS 840
    PSU : OCZ GamerXtreme 700W
  18. #18
    Jun 2006
    I stopped reading when you mentioned .Net
    Seriously, ditch that framework, it's pure junk!
  19. #19
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by Ehwaz001
    have you heard of something called "Vista" ?????????? or head burried in sand still? cmon man.... why are you being such a hypocrite :P
    neways, major updates:
    Quote Originally Posted by ChangeLog
    Version 0.3beta
    23-Sept-2006
    - Added a concept icon to the benchmark. I think it goes well with the theme :P
    - Made number of threads a drop down menu.
    - Added tool tips to the controls.
    - Added a popup just before launching the benchmark.
    - Bunched the various misc functions under Tools.
    - Changed the benchmark test labels to use "and" instead of "cum."
    - Added a popup message on successful completion of the benchmark.
    - Implemented "take screenshot" and save feature in the program (shortcut = Alt + S) and in right click
    - Added a "Legend" mini section to the main form to make the results more intuitive.
    - Working on Publishing and validation.
    - Added result save and restore to file.
    - Changed version number to 0.3beta
    Thanks to Funky for helping me beta test this release. Also many thanks to RiO for giving invalueable suggestions and ideas which were mostly implemented (he knows what i mean ^_^)
    I am sure you will like where this bench is heading :P
    Regards,
    K
  20. #20
    Sep 2005
    Switzerland
    Question about stress test.. is it check error during it?
  21. #21
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by Lane-k
    Yes.... + this is one of the easiest way to load up as many cores you might possibly have (upper limit 16 ) If you get a "Green" result, that implies your CPU was SuperPrime "what-is-the-working-set-size" stable.
    Regards,
    K
  22. #22
    May 2005
    Camping your spawn :)
    Will give it a shot soon..
    Rig in sig
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
  23. #23
    Banned
    Jun 2003
    Broomfield, CO
    second system in signature:
    Calculations took: 0 h 0:33:421
    Validation url = http://www.techenclave.com/sprime/vl...1&c=2BD421BBA5
  24. #24
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by freecableguy
    hey fcg... thanks for the post but major changes have happened.... do check them out :P
    New release:
    Version 0.4beta
    28-Sept-2006
    Regards,
    Karan Misra
  25. #25
    Oct 2005
    Milton Keynes, UK
    Smile
    Quote Originally Posted by Philosophy
    Rig in sig
    thanks mate.... waiting for your results in the new version (0.4beta)
