Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 115
Thread: MemSet for A64
    Xtreme Legend
    Mar 2006
    France
    MemSet for AMD
    MemSet is a memory tweaker for:
    -INTEL 815 845 855 865 875 915 925 945 946 955 965 975 P35 P45 X38 & X48.
    -AMD K8 ddr&ddr2.
    -AMD K10 ddr2&ddr3.
    -NVIDIA NForce2, NForce 650i & 680i.
    -VIA KT266/333/400/600.
    Here is the 3.5 version (for 2000 /XP /Vista 32&64 bits):MemSet.exe
    And here is a little soft which allow to access PCI registers on all boards,
    Extended PCI registers on K10 and MCHBAR on Intel chipsets: BarEdit.exe
    You can read and write with it,and save the reading in a text.
    (see datasheet before use)
    You can find some timings explication here: www.tweakers.fr
    If you find a bug,Reporte me please.
    Screens are welcome.
    May 2005
    Paris (France)
    very nice work Felix.
    i'll try this as soon as i can
    Apr 2006
    Russia
    Quote Originally Posted by FELIX
    Tell me if you have (possible) problem or bug with this version...
    i have . when i tried to set ram freq at 166 mhz win stopped working. reboot helped.
    Sorry for my bad English
    Xtreme Legend
    Mar 2006
    France
    is freq working with A64tweaker or SysTool?
    Possible that I'm make a mistake for change it...
    Apr 2006
    Russia
    as u see A64Tweaker doesn't work, too. i chose "166" then pressed "Set", but neither A64Tweaker nor Cpu-z shows 166 mhz. but bios can change frequency.
    may be my ram isn't supported?
    Attached Images Attached Images
    Sep 2005
    Switzerland
    no.. i think if you use A64 info and open the read me text, you will see it can have too an issue to change the speed of DDR in windows..
    This type of tweaker is for change the latencies, timings of DDR, for change the speed of DDR it's more safe do this in bios..
    But it can be too a CPU-Z issue, try perhaps verifiy then with another soft..
    Da Goose
    Oct 2005
    Chicago
    Great Job Felix...
    i7-860 Farm with nVidia GPU's
    Apr 2006
    Russia
    Lane-k, ok, i'll use bios for changing timings/freq-cy if it would be necessary.
    Xtreme Legend
    Mar 2006
    France
    Thank...
    for freq,probably I remove it in the next version and replace by another...
    Frequency info is already in panel.
    Xtreme Legend
    Mar 2006
    France
    ...I remove "Frequency" and replace it by "Bypass max" on this version:
    MemSet22beta.zip
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    MemSet22beta.zip
    link doesnt work?
    Mar 2004
    UK
    Quote Originally Posted by L'enFer
    Thats Tref not the DDR speed. You need to look at the other side of A64 tweaker on the memclk frequency tab
    ASUS P5K-E/WIFI-AP, Q6600 @ 3.4GHz 1.3v, Tuniq Tower 120, 4Gb OCZ PC2 8500 Reaper HPC, Asus HD5870, 320Gb Seagate 7200.10 SATAII, 500Gb Sammy F1, NEC ND4550A DVD burner, Corsair TX 750w PSU, Antec P182.
    Xtreme Cruncher
    Jun 2006
    Felix,linkie no worky .Pls fix it soon
    Xtreme Legend
    Mar 2006
    France
    I updated MemSet for 3.0 version:
    MemSet3.0.zip
    If I resume changes between 2.1:
    -add support for Intel 965 ,AMD A64 ddr&ddr2;
    -not necessary to install/uninstall driver;
    -Save function was simplified.
    -finally all the code was changed...
    May 2006
    MemSet3.0.zip
    thanks keep going.
    Xtreme Monster
    May 2006
    United Kingdom
    MemSet3.0.zip
    You saved my life
    Xtreme Legend
    Mar 2006
    France
    Here is a version for xp 64bit(with installer):
    MemSet.zip (64 bit)
  18. #18
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    hey felix...awesome work porting this over to the AMD ring, i love memset for screenshots because of the width and small amount of space it takes.
    can i suggest that you update your first post with the latest version though...makes it much easier to grab the newest version. thanx for the great work, keep it up.
  19. #19
    Xtreme Legend
    Mar 2006
    France
    Updated!
  20. #20
    Fused
    Dec 2003
    Malaysia
    many thanks
    work very well on my system
  21. #21
    Xtreme Legend
    Mar 2006
    France
    Here is a beta version of memset:
    MemSet31
    -add support for 680i chipset
    -add reading frequency for all chipsets and A64,(except for 680i),
    but possible bug with this fonction.
    -Changing reading memory size
    -some bugs corrected.
    Report me bugs or problem...
  22. #22
    Xtreme Cruncher
    Mar 2006
    Netherlands
    Thank you very much If only I could create things like this
  23. #23
    Fused
    Dec 2003
    Malaysia
    Many thanks
  24. #24
    Xtreme Legend
    Mar 2006
    France
    Here is the final version:
    MemSet31
  25. #25
    Xtreme Legend
    Mar 2006
    France
    Here is the 3.2 version:
    MemSet32
    -Work on 2000 /XP 32&64 /Vista 32.
    -Add "olds" chipsets:
    Intel 815
    NForce2
    Via KT266/333/400
    -Some bug fixed.
    Tell me if you find bug with this version...
