how do i get it off?????
Asus P5B-Deluxe 0614
Conroe E6400 @ 2.56ghz
Team Xtreem DDR2 2x1GB @ 900
ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
Hitachi 80gb | Hitachi 80gb | Seagate 320gb
Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
Corsair Hx620
Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
trying priming it awhile to get it hot? Blow dryer? Email them?
Sorry to hear that red.sky but maybe this is the best reason to not change from Arctic Silver....
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
Dynamite.............
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
well....
i need to get it off because i need to remove the cpu and block... i have no other parts in the case
Corsair Hx620
...i'm so sorry...
Originally Posted by Bloody_Sorcerer
Originally Posted by MaxxxRacer
Im sure you tried to twist it right? I remember AS5 not wanting to come off either.
intel i7 3770k 4.40GHz
ASUS Maximus V Extreme
EVGA GTX 680 FTW
16GB GSKill 2400MHz
(1) OCZ Vertex 3 60GB SSD
(1) Samsung 840 Pro 256GB SSD
(1) 1.5 TB WD Caviar Green SATA
Sound Blaster X-Fi Titanium Fatal1ty Professional
Corsair 700D
Corsair AX850
Water Cooled (EK blocks on CPU and GPU, TA 120.4, DDC-1+ with XSPC ResTop)
that stuff is ato get off
i had it on my opteron for a while. it tends to dry up and then ur stuck
i just twisted it, made a pretty loud crack when it came off though the cpu still works
i vote for twist n pull action
Apple Macbook Pro º 2.4GHz Intel Core 2 Duo º GeForce 8600M GT 256MB º 2GB 667MHz DDR2 º 15" TFT LED backlit display // Dell 2407WFPHC // Xbox360 // Ek + Swiftech blocks in storage
r3vo+PC Fall_06 Build
Spring Customer Build
pulling it will just yank it out the socket if it's bonded tegether well. Dnottis has probably the best idea, Dual prime/cpu burn for a few hours to really heat it, then instantly kill the power (so it doesn't cool down) and proceed to twist the block with the cpu in the socket.
Approach number 2) does the catharG4 have any plastic parts on it or is it entirely metal? If metal then you could clamp the cpu in a vice with the IHS sticking out and wedge in a strong metal bar/s of sorts (the longer the bar/s the better leverage and hasteloy or similar strong steel is probably best), heat the cpu block with a blow torch or something similar to heat it up and keep a constant large amount of weight hanging on the bars (or you could put your own bodyweight on it but it may be hot, it should just flick the block off. Although that's the xtreme (and my) way and it would have to be bonded together pretty strong to withstand it but your unlikely to kill anything that way, my guess would be if the bond was that strong the block would just rip the IHS off the cpu. Personally I think approach one will work though![]()
definitely use twist-n-pull :O
my gawd... well, this is xtremesystems, exactly the place for people like mel...
Slaper on ebay and buy a new one! Or try a very thin blade run under it.
Got an Xtreme System? Bring it here! <----
woohoo G4 and opty 165 combo fs... who's in?
well... i will try to just run the pump and heat the rad a little to heat up the loop (i have a 200w psu atm)
if only i could remove the cpu from the socket with the block still attached
if the cpu is off, how much heat can it handle?
Corsair Hx620
get one of those thin razorblades, the flexible ones.
thats what i used.. I had my 754 athlon stuck on a CM hsf with liquid pro. Took me a while but I got there. I just kept on shoving the flexi razor in all sides, did a little twist and pull action and eventually it came off. I wouldnt use a regular razor blade though,wouldnt wanna ruin your g4
i5 2500k @ 4.6ghz 1.335v [ASUS P8Z68 Deluxe]
8gb gskill ripjaws f3-12800cl8-8gbxm
600gb velociraptor + 1TB black
MSI N560GTX-TI Twin Frozr II + x-fi xtrememusic
corsair hx-620w + lian li pc201b + dell 2408fpw
d-tek fuzion1/ddc2 + petra top/thermochill pa120.3
just turn on pc keep the pump off wait a few sec turn off and the remove...
if anything goes bad its not my fault
Incoming new computer after 5 long years
YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
That's what I do and I haven't broken anything yet....Originally Posted by leviathan18
e8400@4Ghz w/Fuzion V2|DFI p35 T2R|4x1Gb Ballistix D9GMH|Sapphire 4870|2x150WD Raptors|LianLI PC-A77|Nec 20WMGX2 x2|SB xfi Titanium
Lol how bout a wee hammer & chisel???
Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
-monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
-monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
vote for buying a new one...
the surgical knife, razor very sharp on all sides...
Garrotte it with a thin guitar/piano wire or fishing line?Originally Posted by ReD.SkY
You don't.
Dual prime per core, then flip the switch at the back of the pc and give it a mighty yank.
AMD 64 have a thermal cutoff in case you happen to have it on too long w/o heatsink properly attached. Usually it will cut off in 7 to 10 seconds after a cold unit if powered up. Have to remember that it takes several seconds for that IHS to get to 70C.Originally Posted by ReD.SkY
C300
Abit IP-35 Pro
If you don't care for your motherboard you could leave the CPU attached to it while pulling as hard as you can on the the G4.![]()
Next time, A...........S...........5
"It was a bright cold day in April, and the clocks were stiking thirteen..."
Originally Posted by Xeon th MG Pony
I really love the fact that people seem more concerned about the waterblock then the processor or board........ just heat it and twist it off
twisting while dual priming, and no luck
i emailed coollabs...
Corsair Hx620
Let us know what they say.
Meh, they prolly wont even respond.Originally Posted by InTheFlow
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
