Test Configuration:
CPU: Intel Conroe Core 2 Duo E6300 1.86G
Memory: CORSAIR CMX1024-9600C5
GeIL PC2-6400 GX22GB6400PDC
H/W changes: High FSB needs high Chipset core voltage
Decrease the resistor value will increase Chipset core voltage.
For example:
To get above voltages, you should select the “NB Vcore” item to “1.65V” in BIOS Setup Utility.
BIOS setting recommendation :
Over-Voltage Recommendation
CPU-Z information
Super PI 2M finished
Thanks your reading.![]()
