Results 1 to 24 of 24
Thread: For those who cannot OC their DS3...
    Feb 2005
    CrazyJohn and I have been scratching our heads trying to figure out why some have amazing results with this board and some have absolutely no overclocking success.
    After trying 3 bioses and changing every setting in bios, I've found that my board WILL not overclock even 1mhz while "Legacy USB storage detect" is enabled in bios. It is located in the "Integrated Peripherals" section of the bios. If you're having a problem where you change a setting located in M.I.B. Intelligent Overclocking, then DISABLE this setting and it should fix it. Hope that helps.
    -Collin-
    I am like an alcoholic, but with motherboards.
    May 2006
    Poland, know where it is? :>
    this doesn't work for me ;(
    check your PM...
    E6300 [4oo x 7] 1.15V, DS3 F5 50mm@5V, 2x512 GoodRam PRO D9, Ninja+ 120mm auto
    This MB does not like my graphic card had to cheat it with a VGA PCI 1MB...
    || nVidia 76ooGS Galaxy Zalman Edition 1.2ns - [64o/815]
    || Creative Audigy2 @ Audigy4 + T6o6o // DVD-RW Pioneer DVR-11oD // 25oGB Hitachi
    || Sharkoon SilentStorm SHA48o-9A 48oW // MX61o, ImageQuest Q91o...
    GigaByte DS3 FAQ by CrazyJohn
    GigaByte DS3, DS4, DQ6 MEMORY thread by CrazyJohn
    Apr 2006
    Gonna bookmark this. I should be gettin mine in next week. Well tell of how it does. Thanks for the tip.
    May 2006
    I'll try this. Does this mean I won't have USB support?
    Feb 2005
    Quote Originally Posted by Brahmzy
    No usb still works fine, but I'm not really sure what legacy usb storage is??? USB hard drives or something?
    -Collin-
    May 2006
    OK, I tried disabling this. Didn't make a lick of difference.
    Jul 2006
    well brahmzy ne news,
    u try it yet
    Dec 2005
    No improvement on my overclock here
    I7 920 DO 3.3Ghz 1.09V (Still clocking) 3910A313
    TRUE Black 2*Xilence 120 Push Pull
    Gigabyte UD5 F8 Bios
    6GB Patriot Viper 1600 7-7-7-24-1T
    Saphire HD4850
    Enermax Noisetaker 600W
    Coolermaster ATCS 840
    Aug 2006
    I don't think this is the problem as I can OC my e6300 to 450+ with this option ENABLED.
    Aug 2006
    For more weird overclocking limitations. If I have a DVI LCD screen plugged in on my 6600GT during startup, changing any MIT settings will cause a restart. So I plug my secondary LCD in as the BIOS finishes and just before WinXP boots (so it shows the screen in Windows).
    Aug 2006
    this is getting weirder by the day...
    first the USB thing, second the graphic card, and now...LCD?
    Jan 2006
    Hong Kong Island
    doesn't help , e6700 + ds3 still crappy, I'll try Clockgen tonite.....
    Apr 2005
    Orange County, CA
    is the DS4 having these same issues? Maybe I will wait a bit longer for those to hit the shelfs more. I cannot find any where online that sells it right now.
    Current Setup:
    -9850 GX2's in Quad SLI config
    -Asus P5N32-SLI MB
    -2x512mb of PC2-5300 DDR2
    -Intel Celeron D OC'd to 3.2Ghz
    -Windows Me with XP theme
    -WD Caviar 20GB Hard Drive
    -Zip drive
    -Jazz drive
    -3.5" floppy drive
    -5.25" floppy drive
    Aug 2006
    dave,
    the issues that's bugging the ds4 is quite isolated though...some can achieve results with flying colours while others, like myself, stuck at not being able to OC at all...
    Apr 2005
    Orange County, CA
    Quote Originally Posted by dualshock
    dave,
    So the DS4 also has issues with OC'ing?
    Current Setup:
    -Asus P5N32-SLI MB
    -Zip drive
    -Jazz drive
    -3.5" floppy drive
    -5.25" floppy drive
    Aug 2006
    i wouldn't use that general statement as it doesn't affect all boards...only certain small number of boards are affected...
    Aug 2005
    Melbourne, Australia
    try a different graphics card.. that fixed it for me
    Q9550 || DFI P45 Jr || 4x 2G generic ram || 4870X2 || Aerocool M40 case || 3TB storage
  18. #18
    Jul 2006
    I had to put the PCI Express Frequency to Auto. I have the USB Legacy thing disabled also. So far on this 805D & DS3 it is prime stable & no Cold boot resets for 3 times in a row now (knock on wood). This is easily the most finicky board I have had in 16 years of building systems.... This is my second board & it has not been any easier to setup on an overclock. Stock is fine.
    Intel Q9550 YorkField @ 8.5X400 3.4Ghz
    Gigabyte GA-EP45-DS3R
    Corsair XMS2 DDR2 800 2x2gb
    2x300gb Seagate Sata II Raid 0
    1x500gb Seagate Sata II
    Visiontek 4870 512mb DDR5
    Antec Nine Hundred
    OCZ GameXstream 700W PS
  19. #19
    Oct 2002
    Wisconsin
    Mine overclocks just fine with it enabled.
    eVga 780i SLI
    E8400@4.2ghz(483x9)@1.44v Cooled by Coolit Elite
    2xXFX Alpha Dog Edition 8800GT's 702/1890/2000 on stock cooling.
    2x1GB OCZ pc8500 4,4,4,12 1T@2.75v
    2xWD 150GB Raptor-X in Raid-0
    PC Power & Cooling 750Watt Quad Silencer
    Creative X-Fi ExtremeMusic
    Samsung 244t 24" Widescreen LCD
    20,001 3DMark06 WinXP SP2
    http://valid.x86-secret.com/show_oc.php?id=302461
  20. #20
    Aug 2006
    as i've posted in the other thread, i now can confirm that by changing gfx from 7600gt to other pcie such as the x550, you can start to OC...
    should be some incompatibility problem...
  21. #21
    May 2006
    Maybe effects systems with nvidia cards? Can someone refute this?
    E6300 @ 3.15Ghz / GSkill HZ 6400 (0606 batch)
    Gigabyte DS3 F9 Bios/ X1900XT
  22. #22
    Aug 2005
    Quote Originally Posted by oohms
    I think it has something to do with that some video cards are not compatible with some undocumented pci-e bus acceleration the DS3 does when you enable cpu clock control
    http://www.xtremesystems.org/forums/...d.php?t=109741
  23. #23
    Xtreme Recruit
    Aug 2006
    I just want to add a "me too".
    I have a Celeron D 2.5 ghz that really wants to be overclocked. I've tried two different brands of memory (PQI and Patriot) and it doesn't make a difference.
    The most frustrating this is that I got it to work ONCE after a lot of persistence. My measly 2.5 ghz CPU ran completely stable at 3.9 ghz making a nice 56% overlock. I benchmarked and tested and all was stable. But it stopped after I opened my case and added another stick of RAM, and I haven't gotten the OC to succeed again since. (I removed the 2nd RAM and it still doesn't work) That fact that it "occasionally" works randomly may make some of the reports misleading, because people might think they did something specific and it worked, but really it was just random.
    I hope a solution is found soon, this motherboard could be awesome but right now frustrating as hell!
    Oh yeah, the Windows OC utility works somewhat for me, but it doesn't help much because I spend 90% of my time in Linux...
  24. #24
    Dec 2004
    MA, US
    I've got an E6600 / DS3 and the no-oc'ing problem as well. Disabling legacy USB support hasn't worked for me. I'll go try some things I read in other threads and post back my success/failure.
    edit: ok I was mistaken - my problem is fsb wall, not being unable to OC at all - I was just trying to start off too high. over/underclocking by a couple mhz works fine as does changing just the multiplier (u/c).. so I guess I am no help here...
