Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: new Clock Generator @Intel D975XBX 304?!
    Apr 2006
    Taiwan
    old
    new
    we must update clockgen now
    Slovenian OC Master
    Nov 2004
    Slovenia
    new revision?
    better or worse?
    OC-Lab.si!!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    ooooooooooh rev 305 ?
    Apr 2006
    Taiwan
    Quote Originally Posted by zbogorgon
    new revision?
    better or worse?
    when u option host burn in 50%
    just got 30%
    Apr 2006
    My 955 board used the same PLL as the normal Bad axe clockgen ICS9541. The new one, the CV115 is what I use in my current 945G Intel board, all I can tell you is that my 945G can't clock for .
    ***Main System ***
    Intel Core 2 Duo E6400 2.13 Ghz @ 3.6 Ghz
    Abit IP35-E
    4GB DDR2 RAM
    XFX HD 5770
    3x 120 GB HD
    2x 160 GB HD
    Antec Trueblue 2.0 480 Watt
    Memory Addict
    Aug 2002
    Brisbane, Australia
    maybe intel dumbing down rev 305 badaxe, so they can use the better PLL for badaxe 2 ?
    Jan 2003
    S.W. Florida
    They wouldn't do that, would they?
    Apr 2006
    I use this
    http://www13.plala.or.jp/setfsb/down...15a4_IG-80.zip
    to overclock, setfsb. It probably won't work on the badaxe tho.
    ***Main System ***
    Abit IP35-E
    4GB DDR2 RAM
    XFX HD 5770
    3x 120 GB HD
    2x 160 GB HD
    Xtreme Mentor
    Jan 2005
    Does that clock generator generate alot of heat?...is it nesscary to heatsink it?
    Mar 2005
    NYC (LAMF)
    that zip file sets off my anti virus immediately when i try to install. it says it has tr/killwin.c.20 trojan horse.
    very truly yours,
    politenessman
    I7 920 @ 4400 TRUE......Q9550 @ 4000
    evga X58.....................DFI LP UT P45 T2R
    Patriot ddr3 1600..........Super Talent 4gb
    HD4890 CF...................9800GX2
    Zalman 1KW.................Corsair 750
    Lian LI V1000B Plus 2.....Lian LI A05b
    Boot Drives are 80gb Velociraptors
    all os vista64 ultimate
    Apr 2006
    Quote Originally Posted by politenessman
    very truly yours,
    politenessman
    It does for me too. I have to turn mine off than use it. For some reason all my anti viruses pick it up as a trojan even though it isnt...
    I got the file from
    ***Main System ***
    Abit IP35-E
    4GB DDR2 RAM
    XFX HD 5770
    3x 120 GB HD
    2x 160 GB HD
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    New board from Frys has ICS.
    Nice find, looking forward to seeing clocks from that version.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Dec 2004
    Santiago, Chile
    Rev. 305?
    Jun 2002
    Las Vegas
    New boards from Fry's now have IDT, clock gen been made yet?
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Xtreme Recruit
    Jul 2006
    I can confirm that the new retail Rev 304 I just received from Scan here in the UK has the IDT chip as well.
    Xtreme Recruit
    Jul 2006
    SysTool works for me on increasing the FSB beyond 30% on a D975xbx with the IDT clockgen.
    Xtreme Mentor
    May 2005
    San Diego, California
    Thanks a ton Charleski! I have the IDT and i've been stuck at 30%
    Was stuck at 3.46 Ghz, currently priming away at 3.65 Ghz, yay.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
  18. #18
    Xtreme Recruit
    Jul 2006
    Let us know how it goes. Even with watercooling I've been having probs with the temps (62degC @Vcore 1.488 fsb 380MHz, didn't push the volts beyond that). I think I need to fix the airflow over my radiator though, and probably reseat the water block.
    [edit]temp measured with CoreTemp, Vcore is that reported in HWmonitor in BIOS
  19. #19
    Jun 2002
    Las Vegas
    Please test the 1333FSB, if your board fails to post with 1333 enabled we need the numbers off the white sticker between the CPU and memory slots.
    Post the numbers in this thread.
    Nice find on the clockgen, lets see what this IDT can do.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  20. #20
    Xtreme Recruit
    Jul 2006
    My sticker reads:
    BQBX62702258 AA D27094-304
    I'm using the 1334 BIOS and have the OC DEBUG mod. I tried altering the fsb strap to 1333 in BIOS and it did nothing to the fsb, but the board still POSTed.
  21. #21
    Xtreme Mentor
    May 2005
    I have heard that 1334 BIOS doesn't work with 1333 strap.
    I was using 1304 bios and couldn't use 1333 strap anyway tho.
    Intel Rig
  22. #22
    Xtreme Recruit
    Jul 2006
    Yes, I should really try reflashing to 1304 again. I had a load of problems on getting the board to POST at all initially that I described here. I initially flashed to 1304 after getting the board to reset, but that gave me no OC options at all (just the warning text, no modifications), and flashing to 1334 fixed that.
  23. #23
    Jan 2006
    France
    I have 2 D975XBX rev 305, one among it has a chip ICS and the other a IDT. The ICS goes up to 444 MHz to super pi 1M, the IDT holds about 432 MHz. I do not know if it is the chip which makes this difference.
    Systool blocks to 399 MHz, after I must use Set FSB.
    >charleski: I have same the problems that you, I had the rev 305 flashed with the bios 1304 and I was obliged to flash to 1334 to have the option of overclocking. Some people say that the 1034 are worse than the 1334 but we can't flash rev 305 with bios 1034. It was similar with my old rev 304, obliged to flash the motherboard.
  24. #24
    Jan 2005
    any word on when the bad axe II will be out?
  25. #25
    May 2006
    Spokane, WA
    rev 305 went to distributers (if they place orders from intel) on 08/01/2006. Here are the changes:
    http://intel.pcnalert.com/content/eo...N106391-00.pdf
    "Description of Change to the Customer:
    1. Updating BIOS to version 1304.
    2. Adding new SPI BIOS chip vendor option for ATMEL.
    3. Updating the lead-free label."
    AA = D27094-305
    Retail Box = BOXD975XBXLKR
