Results 1 to 22 of 22
Thread: D975XBX stuck in configure mode -- UPDATE fixed!
Threaded View
    Xtreme Recruit
    Jul 2006
    Just put together my new Conroe system, and for some reason the BIOS is stuck in configure mode. Every time I turn it on it puts up the Intel splash screen, then the Silicon Image configure prompt, then the screen goes black, it flashes a few more POST codes in the bottom right corner and then dumps me into BIOS setup. On exiting that I get the message 'Turn off power and reinstall the jumper in the Normal position'. But the BIOS config jumper *is* in the normal position! On powering off then on, the result is the same. I've tried changing it to configure, I've tried removing it, I've tried taking out the battery (which resets the time in the BIOS, but doesn't clear the event log), but it behaves the same.
    Any ideas?
    Specs:
    Seasonic 600W PSU
    Intel D975XBX
    Core 2 Duo E6600
    2Gb G.Skill ZX RAM
    7300GS PCIe video card
    UPDATE
    I'd tried removing the battery for 5 mins or so with no joy. Since everything else had failed, I left the battery out overnight. Fired it up this afternoon (bit of a lie-in, heh) and bingo! the CMOS had finally reset!
    Managed to flash it to 1304 and I'm now partitioning the RAID.
    I had tried shorting the 'Clear CMOS' pads, which did absolutely nothing, it looks like letting the charge die over several hours was the only option. Why Intel did not put a proper CMOS clear function on this board is beyond me. I should send them a bill for the amount of my time they've wasted.
    Thanks to mdzcpa for suggesting I leave the battery out for a long time - saved me the huge hassle of RMAing the board.
