Results 1 to 5 of 5
Thread: Corsair TWIN2X1024-8500 512*2
Threaded View
    Dec 2004
    Seoul, South Korea
    My friend, OC Windforce, tested my Corsair 8500 1G(512*2) set. I've got DFI 975X/G, which unfortunately doesn't match with my ram. The test system of OC Windforce is following,
    M'd : Intel 975XBX "Bad Axe" (Vcore,Vdimm,VNB,Vfsb,Tcore MOD)
    Bios : 1304
    CPU : 631(3G)
    RAM : Corsair TWIN2X1024-8500 512*2
    (D9XXX? I don't know the exact module info. I got it as soon as it released)
    VGA : 7900GT (GPU,GRAM Voltage MOD)
    Duel PSU : [Main]Antec NEO 480W(3.3V Rail MOD) / [Sub] Antec True 550W
    CPU Cooler : Water
    RAM Cooler : Delta FAN 80mm * 2EA 4000rpm
    HDD : Samsung 250G * 2EA (RAID0)
    O/S : Window XP Pro 32Bit (Sevice Pack2) & 2003
    His modified "Bad Axe" is suitable for bandwidth testing. His previous testing result of GSKill memory is here. OC Windfore, thx for your hard works!
    I said to him that you could let it go as far/high as possible. As he was not so brave, however, he limited Vdimm to 2.75V. More voltage, plz~
    1'st result
    <img src="http://kr.img.blog.yahoo.com/ybi/1/0f/df/anarinsk/folder/754444/img_754444_1105258_0?1153831731.jpg">
    2'nd result
    <img src="http://kr.img.blog.yahoo.com/ybi/1/0f/df/anarinsk/folder/754444/img_754444_1105258_1?1153831731.jpg">
    3'rd result
    <img src="http://kr.img.blog.yahoo.com/ybi/1/0f/df/anarinsk/folder/754444/img_754444_1105258_2?1153831731.jpg">
