Results 1 to 24 of 24
Thread: Gskill 6400 @ 1200..?
Threaded View
    Champion
    Dec 2005
    Seoul,korea
    Gskill 6400(D9GMH) @ 4-4-4-8 1200..?
    Test System
    M'd : Intel 975XBX "Bad Axe" (Vcore,Vdimm,VNB,Vfsb,Tcore MOD)
    Bios : 1304
    CPU : 631(3G)
    RAM : F2-6400PHU2-1GBHZ (Micron D9GMH)
    VGA : 7900GT (GPU,GRAM Voltage MOD)
    Duel PSU : [Main]Antec NEO 480W(3.3V Rail MOD) / [Sub] Antec True 550W
    CPU Cooler : Water
    RAM Cooler : Delta FAN 80mm * 2EA 4000rpm
    HDD : Samsung 250G * 2EA (RAID0)
    O/S : Window XP Pro 32Bit (Sevice Pack2) & 2003
    2G Set Test Result : http://www.xtremesystems.org/forums/...d.php?t=106447
    Test System form
    http://blog.empas.com/freeman2580/25132216_1024x768.jpg
    http://blog.empas.com/freeman2580/25132217_1024x768.jpg
    http://blog.empas.com/freeman2580/25132218_1024x768.jpg
    Vdimm=2.72V Clock & Timing= 472Mhz 3-4-3-2 O/S: XP
    <img src="http://blog.empas.com/freeman2580/25214440_1024x819.jpg">
    Vdimm=2.32V Clock & Timing= 544Mhz 4-4-3-4 O/S: XP
    <img src="http://blog.empas.com/freeman2580/25214441_1024x819.jpg">
    Vdimm=2.72V Clock & Timing= 587Mhz 4-4-4-8 O/S: 2003
    <img src="http://blog.empas.com/freeman2580/25214442_1024x819.jpg">
    Vdimm=2.85V Clock & Timing= 602Mhz 4-4-4-8 O/S: 2003
    <img src="http://blog.empas.com/freeman2580/25214443_1024x819.jpg">
    Last edited by OC_Windforce; 07-23-2006 at 03:25 PM. Reason: Gskill 6400(D9GMH) @ 4-4-4-8 1200..?
