I make one stronger unit on request for one guy. Here are some pics of the unit: Compressor is Electrolux MP14FB 1/2HP and r402a gas.
Edge protection:
Brazed and cleaned evap:
Vacuuming time:
Golden Froster connection:
Almost finished:
tnx
Edge protection:
Vacuuming time:
Almost finished:
tnx
My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LNē Pots, LD GFX-R1 Dice/LNē Pots,
LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
LD PC-V8 Watercooling Cases: LINK
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
www.ldcooling.com
Find US on Facebook
very clean
do they make a condenser like that but larger in size??
i7 6700K @4.8 ghz
XSPC RayStorm (very nice block)
Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
XFX-7970 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
Crossfire 30" decent monitor for IPS too bad SED tech died![]()
Docsis2.0
Docsis3.0
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
very good looking, as usual.
I like it, but why are you painting the stems of the schraeders?
.:MeltedDuron:.
Aurora - i5 7600K@4.2GHz- Zotac GTX1070 Mini - 16gb Corsair Vengeance DDR3-3000 - Asus Prime Z270M - Fusion ioDrive Duo 1.2TB - 2x512GB Samsung Evo 970 Plus - Seagate FireCuda 2TB - HGST 4TB - Fractal Design Define Mini - Win7 and OSX 10.12
Lenore - Xeon L5430 - Gigabyte G33M-DS2R - 2x2GB HyperX 6400 - Sapphire Radeon HD5450 - M-Audio Delta 1010 - Adaptec SCSI - 256GB Firestorm SSD - 1TB Samsung F1 - 2U rack mounted - WinXP and OSX 10.6
Delilah - Pentium E5800 @ 4.2GHZ (VID mod) - Asrock Conroe865PE - Radeon 9800 Pro - 2x512MB GeiL Blue PC3200 - 30GB OCZ Vertex - 160GB Seagate - 2U rack mounted - Win98SE and Win2k
Jezabel - Athlon XP 2800+ Barton @ 2100 (200*10.5) - ATi FireGL X1 256MB - Asus A7N8X-E Dlx - 2x512MB OCZ EL PC3200 - OG Antec Case - Win98SE and Win2k
Mysti (WIP) - Pentium II 350MHz - Abit BX6 Rev2 - 4x256MB PC100 SDRAM - ATi Rage Fury Maxx - Diamond Monster 3D Voodoo2 8MB - 20GB IBM DeathStar - Still looking for the right case...
Actually I think that looks good with the stems painted
Do you use any kind of accumulator?
I just wonder as it seems like it may have liquid return issues when fully charged for higher loads. That is if you're charging and testing at higher (200 to 210w) loads.
It's just that the suction run is fairly short, and the captube exits long before the U-bend.
Cheers
Gray
[SIGPIC][/SIGPIC]
i think the builder takes pride in his units..attention to detail rules..
it's a bit like a fine italian hand made suit or a one off special built car.. little details make some feel good.
looks really clean and err... nice![]()
Fantastic work there mate, so so clean![]()
compressor looks pretty small for a 1/2 hp recip
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
Here is nice blue display![]()
tnx
www.ldcooling.com
Find US on Facebook
Here are pics of finished unit.
tnx
www.ldcooling.com
Find US on Facebook
That's AWESOME work! Looks great)
...currently under construction...
Nice unit
any difference on temps compared to nl11f?
What did you use for edge shielding? It looks very nice.
Man i just love the looks of your machines great work.
Great job, as usual![]()
Forget the size of the compressor, the size of that condensor is awefully small for a 1/2hp (6000btu) comp. Standard condensor size for a 1/2hp system is about 3 times larger than the one hes using and im not talking about physical size but in the # of fins and length of tubing.Originally Posted by MarioMaster
Have you taken a head pressure reading yet?
My Rig:
Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
ATI X1950XTX 512mb DDR4
MSI 975X Platinum PowerUp Edition
2gb Kingston Hyper-X DDR2 667
Sound Blaster Audigy2
2 IDE HDD, 2 SATA HDD
LG DL16XDVD Writer,52X CDROM
OCZ 520Watt PSU 33Amp +12v
Thermaltake Xaser III case
Logitech Z560 4.1 400watt Surround Sound
3Dmark03-21112
3Dmark05-12154
3Dmark06-8054
Mmm.. Interesting.. LittleDevil, check up your mail..
C2D E4300@3300Mhz 1.465v
Patriot 2*1024 667@730 5-5-5-15 2.1v
ASUS P5B@366
MSI 8800GTS 320Mb@ 701/2214Mhz + Vantec Spectrum
Cooler Master RP PRO 1KW
Thermaltake Xazer III black/window
_HL4E_HalfLife_ here is picture just for you...
Dаvidoff done![]()
tnx
www.ldcooling.com
Find US on Facebook
Very beautiful unit, any bench with this?
Battlefield 3: Nachthymnen666
The condensor seems well specced for that compressor. 3 times the size???Originally Posted by _HL4E_HalfLife_
As for the MP14FB compressor, its very good indeed although I did not find a very big gain over NL11F atall using straigth R402a. I did however find the extra capacity comes in handy when playing with higher pressure stuff. In General R404a/R507a compressors is not perfectly suited for our application, the motors tend to be overpowered for the displacement generating alot of unnecesary heat. The GP14 R134a compressor will yield a better result.
What is load results in comparison to your NL11F systems? I found very small improvement if any?
You need to fit heat load from the proc plus 30% usually for size the condensor, what you are saying is because you are looking at some condensing units that comes ready for AC or comercial use, where you are looking for a lot more BTU's than we use in our application.Originally Posted by _HL4E_HalfLife_
I don't understand what ur gauges are reading over here in Nova Scotia we use Psi. Can you convert? Math isn't one of my strong points.Originally Posted by LittleDevil
My Rig:
3Dmark03-21112
3Dmark05-12154
3Dmark06-8054
It's on the gauges. 1 MPa = 145psi
So it's 1.25 MPa, that's around 181psi.
Is that idle, load, if so what load?
Cheers
Gray
[SIGPIC][/SIGPIC]
No big difference, on 1/2Hp mybe 2,3c better temps on load...What is load results in comparison to your NL11F systems? I found very small improvement if any?
tnx
www.ldcooling.com
Find US on Facebook
i believe it s the HP gaugeOriginally Posted by _HL4E_HalfLife_
1.25 Mpa => 12.5 bar
Signature removed.
Links in signatures to unapproved and/or unaffiliated sites is not allowed.
Re-read the Forums Policies & Guidelines.
Signature edited by IFMU
