Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: SetFSB for Asus P5W DH Deluxe
    Xtreme Legend
    Dec 2003
    Northern California
    Just an FYI to all Asus P5W DH users. There's now a SetFSB with a slider that goes up to 615FSB! The program says it's for the P5WD2, but it works on the P5W DH. After opening the program for the first time, you may need to reboot one or two times to get it to work properly. I've been using it since last night and it makes life a lot easier for me.
    You can download it here.
    Thank you to Abo, the author of SetFSB. As always, a disclaimer from the author. "Use "SetFSB.EXE" at your own risk."
    I am Xtreme
    Jul 2005
    does it work for the P5WD2-E Prem or just the P5W DH Deluxe??
    [SIGPIC][/SIGPIC]
    Apr 2006
    Belgium
    Quote Originally Posted by Eastcoasthandle
    read first post
    Xtreme Legend
    Dec 2003
    Northern California
    Should work on the P5WD2-E. The program was designed for the P5WD2. Right now, this is the only Windows overclocking program (other than AiBooster) that works properly with the P5W DH.
    Should also mention that you can adjust PCIe frequency too with this program.
    xtreme energy
    Oct 2004
    Europe, Latvia
    So what is the max fsb for this board so far? Can be with lower multi
    Can it do at least 500?
    Xtreme Monster
    May 2006
    United Kingdom
    Quote Originally Posted by sierra_bound
    I use this program for about 1 year and really is the easy FSB way to go.
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by kiwi
    The max FSB is going to depend a lot on your CPU. I have not tried using lower multipliers yet with my E6600. With an E6700 you are probably not going to hit 450FSB unless you're kyosen. He has the best E6700 I've seen. And it helps that he's one of the best benchers in the world with a modded board.
    People keep talking about 500FSB like it's going to be easy to do. It won't be. Only one person, Tarosa in Japan, has done it. Overcrash86 is getting close. That's partly a testament to their overclocking skills.
    I think expectations are starting to become a little more realistic now that some people have the boards. A few weeks ago, people were talking about 550-600FSB. I think they now realize that's just a fantasy.
    Apr 2006
    Belgium
    Just wondering...
    Has the Asus P5W DH Deluxe "CPU Lock Free"? Like the Asus P5WD2.
    :edit:
    Why I think this would be usefull:
    As said before 1:1 should be the best FSB:RAM ratio.
    So imagine you have a E6600 running at 2.4GHz.
    => with a locked multi of x6 you can get 400MHz FSB and 800MHz ram without overclocking cpu
    Xtreme Legend
    Dec 2003
    Northern California
    Yes, there is an AI CPU Lock Free setting. But it may not be in every BIOS version.
    Jul 2005
    ATX
    Thanks a lot for the prog there sierra!!
    Mar 2006
    Hellas
    What's the max fsb you could reach stable sierra_bound?
    Xtreme Monster
    May 2006
    United Kingdom
    Quote Originally Posted by deadlock7
    She got 450.
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    the real question is this:
    have you been able to achieve a higher FSB using that program than you are in the bios ?
    Inquiring minds want to know.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Xtreme Legend
    Dec 2003
    Northern California
    Depends on how you define stable. I can run SuperPi 1M at 450FSB with air cooling. 1M is more of a speed than stability test. I can run 32M at around 440FSB on air. May be able to go a little higher with sub-zero cooling. In order to get really high FSB, you need a lot of MCH (northbridge) voltage. The Asus board only goes up to 1.65v in BIOS. A few people have modded the board so they can run Vmch at 1.9v. That will help a lot.
    I'm not using the board for everyday chores. Mine is strictly an overclock-and-have-fun board.
    Quote Originally Posted by Lestat
    I used SetFSB last night to be able to run at 450. It's probably not going to go any higher than that with 9X multiplier and air cooling. That has more to do with the CPU than the motherboard. With better cooling, I might go higher. I have not tried dropping the multiplier for testing yet.
    Xtreme Monster
    May 2006
    United Kingdom
    [/QUOTE]
    Yes she got 440 .
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    Sierra you can NOT use 450 in the bios ? or you havent tried yet.
    metroid, i know she got 450 with that program, you said this twice now.
    but she never said she did NOT do that in the bios also.
    we are saying 'she' because of the the forum image ? or cuz she's a she ?
    i'd hate to be calling a guy a she,,,
    any ways to save the setting ? and place a short cut in the windows start up ?
    Heat Ebay Feedback
    Sep 2004
    Bah. More people recalculating their budget to move over from 6600 to 6700 for the 10 multi. Big jump in price. Might be worth it if you can run 4ghz 24/7 with just water. Something compelling about big round numbers. Maybe as more boards come out 450x9 will become common. In the meantime ...
    Sourcing parts for a mildly over clocked abacus.
  18. #18
    Mar 2006
    Hellas
    That's what i'm asking for.It would be nice to see what's your max fsb.The only way to find it is to drop your multi as you said.All the mainboards have options of max 500+fsb till now,but it would be useful for us(who looks for buying conroe) to know which is the max stable one(even with the 1.6v that asus has max for chipset).
  19. #19
    Xtreme Legend
    Dec 2003
    Northern California
    Yes, I can. I was using SetFSB last night because the newer version of the program just became available.
    Why do people have this obsession with FSB? If you're worried about FSB, just get a chip with a higher multiplier. Yeah I know, that costs more money. Life just isn't fair. I've gotten a 2.4GHz Conroe up to 4GHz. That's not good enough?
    I eventually plan to get an X6800 because then, I won't have to worry that much about FSB. Coolaler was running at 405 when he set the SuperPi record. He didn't need high FSB because he had a 13-multiplier at his disposal. Personally I would prefer to run FSB in the 350-400 range with tight memory timings. But that's just me.
  20. #20
    xtreme energy
    Oct 2004
    Europe, Latvia
    So you wanna say 600fsb by coolaler is luck or what?
    http://www.xtremesystems.org/forums/...4&postcount=97
    I think as boards and bios become more conroe mature, 500 should be possible
  21. #21
    Xtreme Legend
    Dec 2003
    Northern California
    LOL. I commented on that screenshot awhile ago. There's a big difference between showing a boot screen and actually booting into Windows. I'm sure he would have showed us a Windows screenshot if he could.
    And BTW, I know that some members of Team Japan have already gotten rid of their DFI Infinity boards.
  22. #22
    Sep 2004
    Its fantastic actually. And the vast majority of OCer's with be shooting for that sweet spot on 6600s. I'll be doing the same while I wait to see how things shake out on the mobo side. The Asus mobo should be a good one for those who want to gently acclimate to Intel after a long run with AMD.
  23. #23
    Xtreme Legend
    Dec 2003
    Northern California
    You have to remember though that you can compensate for lower FSB with higher memory speed. I just wish the Asus board ran the 4:5 ratio better.
    Here's an example. First screen is an E6600 at 437X9 and 1:1. Second screen is an E6700 running at 383x10 with 4:5 ratio. As you can see, the E6700 with 100 less MHz nearly makes up for lower FSB, thanks to higher memory speed.
    E6600 @ 1:1
    E6700 @ 4:5
  24. #24
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    the fascination with FSB is simple. a crap load of us got 6600's from andre...
    so...
    plus on an ES chip it allow syou to drop the multi, raise the FSB and increase the memory bandwidth.
    i'll just be happy to get a baord for my chip
    i am still undecided and am goint to wait as long as it takes until the clear winner immerges.
    Heat Ebay Feedback
  25. #25
    Xtreme Legend
    Dec 2003
    Northern California
    Dropping the multiplier on my chip may not increase FSB that much. That's just my guess, though I will probably give it a try at some point. I think the real key is chipset voltage. I'm actually surprised I can do 450FSB with Vmch at just 1.65v. Most of the people doing over 480FSB are using 1.9-1.95v. Unfortunately the Asus board doesn't offer that much, unless it's modded.
    Kyosen has made it up to 475FSB with his modded board.
