I was wondering if anyone knew anyone else, or is able to build a pair of custom high performance copper GPU blocks for a single 7950GX2.
The only blocks (that I know of) that will fit in a 7950GX2 are:
1) The Aqua-Computer aquagrafx 7950GX2
2) The Thermaltake Tide Water Plus' GPU blocks
In GoriLLakoS 7950GX2 review thread, he measured the space between the two cards and its about 1.5cm.
http://www.xtremesystems.org/forums/...hlight=7950gx2
1.5cm is about 0.59 inches, so 7/16" ID tubing with a small thickness will fit. The greatest challenge is obviously building the block :P
Something like Shamino's custom GPU blocks (but for watercooling of couse) would be nice.
http://sg.vr-zone.com/?i=3743
Im not a expert in waterblocks, but I think this could be a possible solution.
Since water cant be bursted from the top, it has to be from the side to fit in between the cards.
The water busts from one side, the resistance from the pins and the L shape takes off the heat, and then exits from the other side.
Waterblock experts: what would the best design be?
) would be nice.
