Results 1 to 25 of 76
Thread: Modified alphacool top performance
Threaded View
    Feb 2006
    Sweden
    The original inlet hole was 7mm and off center, after my modifications it's 12mm, dead center and a bit tapered.
    Unmodified (7mm)
    Modified (12mm)
    Max flow test single pump
    This test was performed at 12.3V with EK nipples, top mounted inlet and 1 feet 12mm ID tubing at each end.
    I repeated 3-4 times for accuracy.
    • Alphacool data: 600LPH
    • Single unmodified: 900LPH
    • Single modified: 1000LPH (11% higher max flow)
    Max flow test two parallell pumps
    This test was performed at 12.3V with EK nipples, top mounted inlets, 12mm ID Y-connections and 1.5 feet 12mm ID tubing at each end. I repeated the test three times for accuracy.
    • Dual modified: 1350LPH (35% higher max flow)
    Max head test
    All tests were performed at 12.3V with EK nipples, top mounted inlet, 1 feet 12mm ID tubing at one end and 7m+ at the other.
    I repeated a couple of times as air in the pump made a huge difference.
    • Alphacool data: 4.7m
    • Single unmodified: 6.6m
    • Single modified: 6m (11% lower max head)
