06-15-2006, 04:57 PM
#1
wtf is fsb termination voltage anyway?
does anyone have a good answer?
in my experience, increasing it prevents the cpu from missing clocks, but i have no idea how it works or anything.
__________________
DFI P965-S/core 2 quad q6600@3.2ghz/4gb gskill ddr2 @ 800mhz cas 4/xfx gtx 260/ silverstone op650/thermaltake xaser 3 case/razer lachesis
06-15-2006, 07:08 PM
#2
o rly i have it set tp 1.5 on mine seemd to make pc more stable when i unlocked multi and ramped up FSB
but yer i dont really have a clue wat it does
__________________
E6600 B2 @ 3.6ghz
P5WDH
X1900XT crossfire
06-15-2006, 07:19 PM
#3
All I know is that I went from an instant BSOD, to a flash of the windows loading screen and then a BSOD after pumping up the FSB Termination voltage...so yeah it seems to do a tad bit of something
__________________
Intel C2D E6600 (L630B015)
TT BigTyphoon || Zalman VF900 Fatal1ty
Abit QuadGT
2GB Corsair Dominator PC2-8500
HIS X1900XT --> XTX
Creative X-Fi Elite Pro
OCZ GameXStream 700w
Feedback:
HEAT --- eBAY
06-15-2006, 08:37 PM
#4
maybe its the voltage of the FSB itself...
__________________
E6600 B2 @ 3.6ghz
P5WDH
X1900XT crossfire
06-15-2006, 08:50 PM
#5
The un-extreme XIP
it doesnt seem to do anything for me
__________________
Q6600@3.6ghz 1.45V ----- 8gb ocz ddr2-1000
XFX 5850@900/1200 1.15V
1TB hitachi+2x30gb OCZ Vertex v1.41 raid 0
520HX corsair power supply ----- half-size shuttle!!
30" 3007wfp-hc 2560*1600 lcd
unicomp clicky keyboard+logitech trackball
06-16-2006, 11:23 AM
#6
Xtreme Mentor
I hardly find it usefull...
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
06-16-2006, 11:31 AM
#7
Banned
source -> line -> component -> short line -> termination
the "lines" in this case are signal traces. works a lot like a SCSI bus. high speed switching operations can cause reflections on the line (in essence, this is resonant noise caused from high-speed switching on the lines as the memory controller gates on and off to place data on the bus, nothing more than rising and falling voltages). clearly enough, the faster the signal switches (higher frequency memory) the more noise.
termination resistors, used in passive termination environments, are exactly matched to the target frequency for operation based largely on trace length, ESR (equivalent series resistance) and the over capactive/inductive nature of the circuit, as well as some other things well out of the scope of this post. problem is that this is often matched for a specific frequency...which as we know is not so cool for overclockers. enter the active termination system. this actually uses a voltage bias to set final line resistance value so that the user can tune for better operation when overclocking.
this method of tuning is largely trial and error as you have no way of know the specification of the circuit or have any idea of the calculations need to find the "perfect" value. so anway, the answer is, strangely enough, whatever works best.
hope this helps.
FCG
06-16-2006, 11:38 AM
#8
I am Xtreme
holy cow now THATS and answer the demands some respect!!
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
08-18-2008, 01:53 PM
#9
Im sorry to bump up this old thread, but is there a limit whichi should stay within, or can i just rape my Wolf with 1.5-1.6V FSB termination voltate?
__________________
E8400 @ 425x9 1.168V
4GB D9MGH Mix (4x1GB) @ 510MHz 5-5-5-15 2.05V
HD4850 @ 730/1070
♥ BFBC2 Beta
Addicted to dog tags!
08-18-2008, 02:06 PM
#10
[XC] Xtreme Cruncher
I believe for the 45nm parts Intel has a safe range of 1.045V < 1.10V <1.155V (higher for 65nm parts) but there are those that are running as high as 1.30V--I am running @ 1.16V for 400FSB. If you go to their sight you should be able to find the data sheet pertaining to your chip that gives the safe limits for both vtt and PLL.
__________________
QX 9650 | Maximus II Formula | G.SKILL 4GB (2 x 2GB) PC2 8500 | Sapphire 4850 X2 2GB| Auzen X-Fi Prelude 7.1 | 3x's WD 150GB Raptors & 2x's 1TB Seagate 7200.11 | Silverstone OP1200 | SilverStone TJ07 | Dell 2707WFP
EK-RES 250 --> Swiftech MCP655 --> Apogee GTZ --> Enzotech Sapphire NB --> Feser X-Changer 360
08-18-2008, 10:24 PM
#11
45nm = 1.15v max, 1.45v absolute max. Going above the max may immediately cause irreparable damage, and the functionality nor reliability of the CPU can no longer be guaranteed. I prefer to stay under the stated 'max' of 1.15v.
08-18-2008, 10:39 PM
#12
1.26v if you are using Intel '4' series chipset - according to Intel: http://download.intel.com/design/pro...hts/318732.pdf
__________________
My 'all air' boxes...
Weird Science: E8400 E0step@4.0GHz - TRUE 'Black' - 8GB OCZ Reaper1066 - ASUS P5Q-E rev. A3 chipset - Visiontek HD4870 - 1.5TB - PCP&C Silencer 750Q - airflow-modded Antec P180B
... a decent E7200: SLAVN/1.0875VID@3.8+ - Zalman 9700 - 8GB OCZ Reaper1066 - ASUS P5Q-E rev. A3 chipset - ASUS HD3650 passive - 1.5TB - PCP&C Silencer 750Q - Antec P182SE
Sneaky 'C' mediabox: E6400@3.14 - TRUE - 4GB OCZ Reaper800CL4 - ASUS P5W-DH - MSI HD2600XT w/massive passive - Aardvark DP 24/96 - 1.62TB - OCZ Powerstream 520 - Antec 300
I tweak cars, bikes, and computers - does this make me a spatial anomaly?
Reason: eta: per thei published 'safe' settings, I stay@1.30 or less
08-19-2008, 01:22 AM
#13
One-Eyed Killing Machine
As far as I'm concerned, the default FSB Termination Voltage by Intel is:
1.1V for the 45nm parts
1.2V for the 65nm parts
As for what's safe and what's not... the maximum voltage of 1.45V doesn't seem to be the real maximum anyways ( at least 3 of my Core 2 Duo's 45nm disagree ) [ and I will be putting even more CPUs to the test, and even higher voltages ]
test thread here = http://www.xtremesystems.org/forums/...d.php?t=198614
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
08-19-2008, 01:38 AM
#14
should 1.2vtt be considered high then? what about a p45 NB whats considered high over 1.3v ??
I am getting 518x8.5 stable on a e8600 and it takes 1.2vtt and 1.26 on the NB.
__________________
i7 860/True 120
GA P55 UD6/4gb Ripjaws
HD5850/Benq G2400WD
XFI Titanium/beyer dt770 pros
Klipsch PM 2.1/WD 640 Black
Corsair 750/HAF 932
HEAT
08-19-2008, 05:18 AM
#15
I really don't see it being necessary to exceed 1.3V on the NB for the p45 chipset. I hit 450FSB using 4x1GB of RAM >1100MHz on a quadcore w/ only 1.24V, so unless you are just seeing how high you can go for benching >1.30V shouldn't be needed. The same also applies to vtt, I don't really see why 1.2V would be necessary for a 24 hour clock IMHO.
__________________
08-19-2008, 11:30 AM
#16
Just remember there is also such a thing as TOO high. Setting the FSB VTT to 1.4 assuming that'll cover you for any kind of overclock is wrong.
There is too low and too high. And I don't think anyone needs 1.4 as I can do 4.25ghz on 1.2V so .. unless you're on LN2, start with 1.2 and work slightly up/down from there
08-19-2008, 11:40 AM
#17
I am Xtreme
thats the reference VTT not the max, the max is usually near the max rating for the core
but intel no longer lists it on their spec sheets
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
