05-22-2006, 11:05 PM
#1
Overclocking Guru
AM2 FX62 Overclocking Action!
I found that this FX62 was a pretty good overclocker. I haven’t had a chance to overclock it on water yet.
First I tested it on my -95C cascade, it lasted all of about 20 seconds, yes it has a cold bug, froze up around -40C
I then put it on my -30C cooler and it ran well. Nice stable speed of 3636MHz. I had to keep my HTT down because of the cold bug so I used the 18 multi, basically 202x18 using 1.58V.
The memory was running at 808MHz.
Hardware used:
FX62
Foxconn NF5 motherboard
2x1024MB Corsair 8500C5
2x 7900GTX
OCZ 700W PSU
PCIce -30C CPU cooler
The Foxconn mobo is a pretty good board, very stable, easy to overclock, and very forgiving. I like this AM2 stuff. The CPU needs very little voltage, must be that there is no stress on the chip with the High Latency DDR2
OPP
05-22-2006, 11:08 PM
#2
Xtreme X.I.P.
any benchs?
steping?
__________________
05-22-2006, 11:09 PM
#3
Xtreme Idiot
nice work! can we see some 1m results?
__________________
merom t7200
aopen ydg 975x
2x1gb patriot pc6400
ati x1800xt
x-fi xtreme music
wafflepot+ dice
Conroe...
The conroe uses 4mb's of L2, it is a SSE monster. 2 cores, extra 64 bit line. About it. Will be a great multi-tasker. But its really not that impressave.
05-22-2006, 11:10 PM
#4
Originally Posted by metro.cl
any benchs?
steping?
step u can see it on cpuz,u should ask him ,which week
#5
is this a handpicked one?
__________________
05-22-2006, 11:13 PM
#6
INTEL inside
nice OPP !
conroe on the way...to compare  ?
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
05-22-2006, 11:15 PM
#7
Xtreme X.I.P.
then complete stepping please
try cpu brain identifier it lets you adjunts latencies and reads vcore correctly
__________________
#8
Overclocking Guru
1M I was geting in the 23s.
OPP
05-22-2006, 11:16 PM
#9
INTEL inside
what's the Tcasemax ?
__________________
05-22-2006, 11:17 PM
#10
Overclocking Guru
The cool thing about this motherboard is the PCIe clocks. The two x16 buses default at 125MHz as apposed to 100MHz. If you have 7900GTX cards you will find you can overclock the core on those cards a lot higher with this feature. I gained 100MHz overclock on my 7900 cards running in SLI.
OPP
05-22-2006, 11:19 PM
#11
INTEL inside
cards on air, water ?
__________________
05-22-2006, 11:20 PM
#12
XS_THE_MACHINE
 just from raising PCIE bus mhz?
__________________
naked X2 3800+ Toledo LCBIE 0618EPMW ]3020mhz@1.554v]
TT BigTyphoon
DFI LP UT NF4 Sli-D - 4/06 BT mod
PCP&C Silencer 750w
2x1GB Mushkin XP4000 Samsung C-UCCC @253mhz 3,4,3,8 1T @ 2.65v
eVGA 8800GT 512MB@ 787/1944/2244
#13
nice, both results on top10
05-22-2006, 11:23 PM
#14
Overclocking Guru
Opp
05-22-2006, 11:26 PM
#15
INTEL inside
is it an ES ?
__________________
05-22-2006, 11:31 PM
#16
Overclocking Guru
05-22-2006, 11:34 PM
#17
Phenom™
Originally Posted by Supertim0r
is it an ES ?
No it's not....ES cpu's are marked as such  . This one's a pre-release sample.
Nice work there OPP! Got any more left in the cpu?
05-22-2006, 11:37 PM
#18
Overclocking Guru
is it an ES ?
It's from AMD but it's far from a engineering sample.
It's just what you'd call bare instead of retail box.
Trust me, I have much better luck when I buy a retail box compared to the Bare chips I get from AMD
OPP
#19
INTEL inside
Do you think DDR2 beat the DDR here ?
__________________
05-22-2006, 11:44 PM
#20
Overclocking Guru
Not at my particular settings. I looked at either Shamino or Visionarys 3D06 CPU score. Theirs was done at about the same CPU MHz only they used a FX60 and 2-2-2 memory timings. Their CPU outscored mine by a little.
OPP
05-22-2006, 11:54 PM
#21
Overclocking Guru
By the way. You have to have new cpu mounting unless your just useing a heatsink.
I made up some make shift brackets for my Vapo mounting kit.
The new boards have 4 holes, pretty good for even pressure on the core.
OPP
05-23-2006, 12:26 AM
#22
Master of nebulah frost
Another CBugged FX
Bad news for AMD, I think that the people that have try FX-60, will not buy the FX-62.
What a sad, I think that AMD must adjust this problem, otherwise many people will boicot this chip.
05-23-2006, 01:13 AM
#23
Banned
insane speed at that voltage
nice one oppainter
does it overclock wel on air??
05-23-2006, 01:26 AM
#24
OPP doesn't do air, as far as I remember.
__________________
Use in a cool dry place away from direct sunlight. Keep out of reach of n00bs. Overclock within 24 hours of opening.
Do not read instructions before proceeding, do not use only as directed. May cause frustration, late nights and empty wallets.
If symptoms persist please consult your hardware professional.
-AgentVX-
05-23-2006, 01:32 AM
#25
Hardware addict
You can say that again!
Didnt expect too much form AM2 but this looks pretty good.
Can you please go to 1.7v OPP?
__________________
Antec P180 Mini - DFI JR X58 T3H6 - Xeon W3570 - 6GB G.Skill 1333C7 - TRUE120 lapped & modded - GTX285 - Intel X25-M (G2) & Samsung F1 640GB
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
