Page 44 of 102 FirstFirst ... 34414243444546475494 ... LastLast
Results 1,076 to 1,100 of 2526
Thread: Dothan overclocking thread
  1. #1076
    May 2005
    Denmark
    Quote Originally Posted by nCrusader
    Great results you got there Pressure. What's the max 24/7 100% stable clock for that chip with stock cooler?
    Just run it at 10x250Mhz for a nice and cool 2.50Ghz. Until I get a better cooler (having trouble mounting my Vapo on it...) or a better retention system that will have to do.
    Never Argue With An Idiot. They'll Lower You To Their Level And Then Beat You With Experience!
  2. #1077
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Quote Originally Posted by NoX
    Right out of the box that's what I get:
    http://valid.x86-secret.com/show_oc?id=19401
    If I boot at 200FSB and then overclock with Clockgen, the PC800 runs with the Performance Mode ON but I lose the AGP lock (ATI issue). SuperPi 1M at ~2.6Ghz is 29sec. If FSB>200Mhz in BIOS, the AGP stays locked even if I use Clockgen but the Perf Mode is OFF and SuperPi at 2.6Ghz is 30sec.
    I thought that MACCI said to boot at 201+ then there's a way to enable perf mode thru windows from the desktop???
    C
  3. #1078
    Feb 2005
    OZtralia
    Well after reading this thread again I still cant seem to find if the P4P800-VM can have its FSB adjustable ??
    I have bought an 1.4 Banias with the intention of putting it in my HTPC that only takes micro-ATX but if the -VM is no good to OC it looks like I will have to change my HTPC case to one that takes full ATX
    can anyone please advise
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
  4. #1079
    Mar 2005
    notts uk
    Not in the bios but clockgen or setfsb will both work. I tested this with a 1.6 400fsb no problems. The vm's weak point is ram will only work upto 2.6v and a ddr booster will blow the board at anything above it.
    as long as your not pushing the memory your good for about 168fsb max should be enough for you.
    Good luck
    Quote Originally Posted by alpha0ne
  5. #1080
    Jun 2004
    south of heaven
    Quote Originally Posted by charlie
    C
    Yes, with the 865/875 Tweaker.
    I tried EIST and CPUMSR but with these programs I can raise the vcore to max 1.35V. Is there any other software that allows to go higher?
    Asus P4C800ED P-M 730@2.8 7700Cu
    2X1GB OCZ - ATI X800XT AIW - OCZ PS 520W
  6. #1081
    Oct 2002
    Field of Battle
    The pin mod is REALLY easy and I highly reccommend it!
    C
  7. #1082
    Jun 2004
    Miami Beach
    I have a problems with my set up...
    i cannot go over 2400MHz and even at that speed is unstable , i am using P4C800-E Deluxe (bios 1021) ram is OCZ 3200EL Platinum Rev.2
    2x512MB ,OCZ PowerStream520W i dont know why , but when i am usin clockgen to rise the FSB is freezing after like 1-3 seconds. is it posible tempreture to be so high?
    And CPUz is saying that my SPU is 725 , but at the box and CPU its says 730?
    http://www.bobytt.com/big.JPG
    Charlie , how to do this PIN mode? what i gonna need? i am desperate....
  8. #1083
    Xtreme Recruit
    Sep 2004
    Helsinki Finland
    First test an smooth start. Myh Dotti Honey <3
  9. #1084
    Jun 2004
    south of heaven
    C
    This one?
  10. #1085
    Nov 2004
    DK
    Might be this one?
  11. #1086
    Oct 2002
    Field of Battle
    This one?
    easier to do the wire in the socket trick... but same concept.
    http://www.forumdeluxx.de/forum/show...0&postcount=93
    EDIT: YES, THE ONE STRYG JUST POSTED!!!!!
  12. #1087
    Jun 2004
    south of heaven
    Thx! Where can I find a wire that thin?
  13. #1088
    May 2005
    Denmark
    Quote Originally Posted by BobyTT
    http://www.bobytt.com/2400-1.jpg
    http://www.bobytt.com/Small.jpg
    Download the newest version of CPU-Z.
    It is easier to modify the socket to get higher voltages. See above.
  14. #1089
    Xtreme Cruncher
    Oct 2004
    Germany, near Stuttgart
    take a larger copper-cable and remove the rubber, then take one of the small wires the cable ist made off.
    E2160 @ 360x9, max 390x9 watercooled
    GA-P35-DS3
    Cellshock D9GMH @ 545mhz cl5-5-5-5-15
    Palit 7300gt 500/1000 @ 780/1600 watercooled
  15. #1090
    Jul 2003
    SoCal
    I have yet to determine whether this wire trick can be used in conjuction with setting vcore in the bios to trick these puppies into overvolting a little? I'd like to go maybe 1.7 when the phase is mounted.
    <----- REST IN PEACE, KIT. 1993-2007.
  16. #1091
    Feb 2005
    OZtralia
    Quote Originally Posted by leejsmith
    Good luck
    Many thanks leejsmith its main use is going to be an HTPC so no way do I want to have to fool around with clockgen so it looks like an P4P800-E and a new case that takes full ATX oh well, all in the search for silence
  17. #1092
    Jun 2004
    Miami Beach
    I just did it and gave me 1.5V for the CPU , now i am able to run at 2.6GHz , but i have problem with the heat , actualy i noticed that ASUS fan is not fiting somehow perfect to the CPU... i dont know how to fixed my temps jump up to 58'C under load during 32M SuperPi , and is restarting when i start 3Dmark2005.. does anybody have any soliution for that problem?
  18. #1093
    Mar 2005
    notts uk
    I tried using 2 u-wire mods on the p4p800-e.
    Vid4 to vss to give 1.568v and i think vid1 to vss to bump upto to 1.62v but it never showed any higher than the bios allowed 1.6v.
    Didnt try it in a p4p800 that does not have vcore selection in the bios it could work in that.
    Quote Originally Posted by uclajd
  19. #1094
    Jun 2004
    Miami Beach
    It seems 2.6Ghz to be the limit for me.... at least on air... somebody to have any idea how to mount Vapochill LS on that?
  20. #1095
    Oct 2002
    Field of Battle
    yeah, if you can get the heat issue ironed out a bit you can probably do 2700ish....
    C
  21. #1096
    Jun 2004
    Miami Beach
    10X Charlie , i am still thinking , what i can do to fix that problem... i doubt that another low profile FAN gonna do better then ASUS fan, I am blowing air over the CPU fan with one 120mm paraflow, but , this doesnt realy help i think....
  22. #1097
    Xtreme 3DTeam Member
    Jan 2004
    Cascadia
    This is really frustrating. Seems I have just about the worst clocking 730. For superpi and 3dmark stability, my cpu needs 1.35 volts for 2.4Ghz, 1.45 for 2.5Ghz and 1.55 for 2.6Ghz. The mobo is a p4p800se. So, setting the Vcore to the bios max, (1.6) this cpu's max suprepi stable is 2640Mhz with the stock heatsink and 2680 with a zalman 7000alcu.
    Most seem to be reaching 2.7+, with less voltage and on stock cooler. Under load, Vcore only drops to 1.588v. Temps never go above 39-40c at load.
    I've had a really bad string of cpus lately...
    Official ORB bottom feeder.
  23. #1098
    Dec 2004
    Saskatchewan
    So does TCCD perform better than UTT on while using the P4C800se etc?
    So much divider use, hard to tell what ram speeds people are running, so i cant tell whether utt or tccd is being used, thanks :P
    Team Rufio
  24. #1099
    Jan 2004
    Cascadia
    Quote Originally Posted by justwOo
    With TCCD, I seem to be running about 1 sec. slower in superpi (vs. like clock speeds) than others. Of course, I have been running with 2.5-3-3-7 timings. Good up to 280Mhz on p4p800se.
  25. #1100
    May 2005
    Finland
    Quote Originally Posted by DrJay
    Talking about ty CPU's, using stock cooler my 730 is 24/7 stable@2.4GHz with 1.45v (BIOS setting). 2.47GHz isn't stable even with 1.50v. Above 2.6GHz mine doesn't even post regardless of voltage given. MB is P4P800-E Dx.
