Page 28 of 43 FirstFirst ... 182526272829303138 ... LastLast
Results 676 to 700 of 1072
Thread: The Venice OC DISCUSSION Thread
  1. #676
    Jun 2005
    Hey guys
    Just thought I'd post my OC in here. Hope its the right place
    I got 2800 @ 280 x 10
    RAM: Divider 9/10 @ 2.5-3-3-6 @ 2.9v + 1T (2.7 and 2.8v errors like a mofo)
    BIOS 5/10-3 on a LANPARTY SLI-D
    The RAM is sposed to be TCCD but I aint checked (n00b I know) and as it won't run whatever I try (apart from trying CAS 3/2T) then I am checking this weekend just in case it is TCC5
    I used kakaroto's guide: here
    so thanks to him and |3ourne who helped a lot.
    Quick CPU-Z screenie:
    Validation:
    http://valid.x86-secret.com/show_oc?id=22942
    Thinking of either X2 or perhaps SD 4000+ as future upgrades, but I'm happy with my little OC on air on this Venice
    Intel Xeon 3070 @ 3600MHz Stable, 4GHz Max
    Abit IP35 Pro
    MSI 8800GTX
    Custom and blinged out water cooling
    Project <<|Black3d|>>
    Logitech G5/Saitek Eclipse
    Dell 2405FPW 24" TFT
    Tagan 1100w
  2. #677
    Apr 2005
    what week is your 3200 kempez? mine is an 0516 LBBLE and it can't oc fo schizzle . max out at 2.75. i'm also running tccd and dfi sli-d. i've tried everything that was recommended to me.
  3. #678
    May 2005
    Quote Originally Posted by cpulloverclock
    310
    vdimm mod made now
    cpumark ok at 294.7 1.5-7-12-2-2-5 but superpi 1M and more doesnt like that
    16 ok at 293 and 0.203 for 2633MHz
    I must test on wc again
    310 = 2005 03(month) 10(day) ?
    official 2005 05 10 is worse?
  4. #679
    May 2005
    Sweden
    Quote Originally Posted by dng29
    2.75 isn't that bad for a 0516.
    [DFI nF4 Ultra-D @ 6/15 BIOS] // [Venice 3000+ @ 2.8GHz @ 1.472v] // [2x512MB SP BH-5 @ 2-2-2-8 200 MHz 2.63v... for the moment] // [Sapphire X800XL Ultimate] // [OCZ Powerstream 520W]
    Super PI 1M record: 29.969 // Suicide screen record: 3 GHz // LBBLE 0517 DPMW batch ~300 on air // Stable enough?
    TB 900 + Venice 2800 folding 24/7, TB 1200 folding whenever it's on, profile
  5. #680
    Nov 2002
    North America
    Quote Originally Posted by lehmin
    I'll try again with but I must test the last 610 bios
    I can bench Spi 1M at 289.3 1.5-7-12-2-2-5
    cpumark at 294.7 and spi 16k at 300.1 1.5-7-12-2-2-5
    I love XS
    Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
    I want a Penryn 3.33G 12MB & quad sli Nvidia G92
  6. #681
    Jun 2005
    Damn me if mine aint exactly the same week as that fecker. Apparently we're one week off the good ones
    Mine can get to 2800 but only with the divider
    Abit IP35 Pro
    MSI 8800GTX
    Tagan 1100w
  7. #682
    May 2005
    Sweden
    Woot! I finally broke into 29.x in super pi, see sig.
    This CPU is a bit weird though I gotta say, 2700 @ 1.44v is 100% stable, yet 2850 is barely benchable at any voltage (tried up to 1.67v in smartguardian). Won't try to break this one for a while.
  8. #683
    Nov 2002
    North America
    my 3000+ is burnin at 2710 1.35v
    38-39C
    room temp about 31C
    WC
    I love XS
  9. #684
    May 2003
    Edmonton Alberta
    Here is my 3000 lbble, im so impressed with it so far. THis is on the stock HSF.
    edit
    Well it does 300x9 at the same vcore too, im really really impressed considering its stock cooling. gonna try for 2.8 with the stock cooler later tonight
  10. #685
    -100c Club Member
    Apr 2003
    Riverside, California
    Interesting find. I've found what was causing my 4 sticks not to run and repaired the problem (some timing issue) and back in game at 2T. I grabbed another venice yesterday which SUCKED hard... however, one thing I noticed between this sucky 0518GPxx vs my magical 0515APAW is that for same volt and same overclock... my 0515 reports temp 10c higher than this 0518.... Could it be just a quirk or is it really that much hotter? I've always wondered why my temps are about 10c north of what other people says under same v-core... right now running 1.57 v-core 2.8ghz 100% stable on everything (including prime) but prime temp reads... 62c with ambient temp of 26c. (now most people report around 52c with big typhoon for similar v-core and speed)... Wierd in deed.
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
  11. #686
    Apr 2005
    Denmark
    I have just resived my 5th 939 cpu (my 3rd venice). Last time i ordered a 3200+ (0517 GPFW) which only ran 2400 stable, on stock heatsinks and voltage.
    This time i tried a 3000+ (0520 CPAW), cause I have had good experiance with the winchester 3000+. But once again I was let down. This only runs 2,3 GHz stable on stock voltage, and i can't force it over 2,6 stable, even at 1,7 v-core
    Even my old mans winchester runs faster then this
    I consider the idea, to let go of my 939 dreams, and return to my good old 1700+.
  12. #687
    Jan 2005
    another stepping that rocks ..at least for Me
    ADA3000DAA4BP
    0517GPIW
    stock 1.3v
    at 1.5v 9x290
    gonna let her burn alil before I try more
    msi-k8n neo2 plat1.8 bios
    xms twinx1024-4400c25pt 1T
    amd 64 winnie 3200+
    xp90c panaflo
    neo480w
    seagate7200.7 160gb sata
    9800xt w/silencer3
    lianli
  13. #688
    Feb 2005
    Anyone have near a 3200+ venice 0518APFW? Closest I've seen is week 17 which still seem to be doing good....I have the new DFI Nf3 socket 939 board so right now the BIOS isn't much to be desired as the voltages are completely innacurate and so are temps for that matter as well as a few other things when dealing with RAM.
    I can get the CPU to 2.6GHz but it fails prime95 within 15 minutes which is at 1.50 + .5 which only reads at like 1.7 in CPU-Z....and as of yet, no ones really sure where to test with a multi to find the true reading....assuming 1.7v is correct......for 2.6GHz to not be stable at that Vcore pisses me off a tad.
    I've only had this CPU running for 5 days so it does need to get some more burn in time, and I'm running it 2.4GHz stable for right now until it burns in + DFI releases a new BIOS revision.....
    I surely hope I'm not limited to 2.4 or 2.5GHz OC honestly After seeing all these ridiculous OC's with the venice on air no less, it'd suck if that's as high as mine will go with watercooling although yes I realize OC'ing is all luck of the draw.....it seems I needed before week18 apparently.....who knows, maybe it'll shine here within a month after the BIOS is released
    DFI nf4 Ultra-D 704-2bta BIOS
    PREVIOUS SYSTEM
    (3200+ Venice LBBLE 0518APFW @ 2.565GHz - Water Cooled by DangerDen TDX
    1gb PC3200 PDP SYS XBL Ram @ DDR466 2-3-3-6)
    NOW RUNNING/TESTING
    Opty 165 CCBWE 0551WPMW @ 2.7GHz (Still in Testing Stage)
    Thermaltake 560w PSU
    eVGA 6800GT PCI-E 450/1200 - Water Cooled by DangerDen MAZE4
    Self-Modded 2-302 heatercore
    D4 Pump
  14. #689
    Feb 2005
    OZtralia
    Check out this at eva2000 I4mem page (GREAT WEB PAGE ) re your week 18 chip
    http://i4memory.com/showthread.php?t=707
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
  15. #690
    May 2005
    Sweden
    I'm still having temperature problems...
    27-28C in the room at all times, unfortunately...
    These temperatures are all MAX temperatures, "average load" is a bit lower.
    1800 @ 0.97v - 33C max load (32 avg)
    2700 @ 1.392v - 48C max load (46-47 avg)
    2800 @ 1.5v - 59C max load (55-57 avg) - until it hangs
    How do you people manage to run at 1.6v? It goes way past 60C even when I'm only running Super PI to 1M digits at 1.6v, which doesn't generate half as much heat as prime95 for 15 minutes does.
    Edit: I guess I wrote too fast, fixed a couple of spelling errors
  16. #691
    Apr 2005
    feeling hot hot hot ... . j/k, that's pretty hot bro. my 3200 venice is running at 2700Mhz with vcore at 1.7. i got an xp-120 with a silverstone 12mm fan that pushes 110cfm of airflow. i ran 32M superpi and the max load gets to around 46-50. room temp is 30 and above because is the hottest spot in the house . the room is super hot during the summer and super cold in winter. i use mbm and smartguardian to monitor temps. they both show the same temp readings.
  17. #692
    May 2005
    Sweden
    110 cfm is way too noisy to me. If I get an XP-120, I'd get a fan that pushes around 50-70CFM. You think that would be worth the upgrade? Seeing your temps, I suppose mine would drop a lot, though.
  18. #693
    May 2005
    110 cfm 120mm fans are really not that noisy. If you get a fan controller, you can have the best of both worlds. Crank it up when you're gaming, and throttle it down when you're not. I get about 37 C load with my XP-120 and 100 cfm sunon fan.
    Building an Intel rig soon...
  19. #694
    Apr 2005
    actually it's not that loud pushing 110cfm of air. its max rpm is between 2400-2500 and a dba of 35. i love this fan, it has 9 blades and lite. i'm planning on getting more to use as front and rear exhaust fans. all these cooling and my cpu can't reach 2800Mhz . i guess i'll never be able to find a cpu that will run 2800Mhz on air stably for 24/7 usage . if anyone wanna sell me their 3200 venice that can do 2800Mhz on air stably, please don't hesitate . thanks in advance.
  20. #695
    Aug 2004
    Sweden
    What do you guys say about pretested CPU's, guaranteed to work stable at a certain overclock? Yeah, you don't get that exciting moment when trying to overclock for the first moment, and it will cost you more. But on the other hand you'll have a decent CPU from the beginning.
    I'm wondering (well, don't we all?), what are the chances that you'll get a CPU running at 2.8 GHz stable? 10 %? 15 %?
    I'm looking for a 3000+ now and the reports about those made week 20 makes me worried. So I dunno...
    Should I go for stock 3000+, pretested 3000+ or even a stock 3200+? Tell me what you think, thanks!
  21. #696
    -100c Club Member
    Apr 2003
    Quote Originally Posted by Mats
    I would love to grab pre-tested one warrantied to run at that speed :P That usually saves about 50-100% from the CPU price I try to buy at as long as it's retail. (15% restocking for avg and than about 4-6 chips to find one that you actually like out of them)
    heatware: jinu117
  22. #697
    Aug 2004
    Sweden
    Well, pretested with 9 x 315 is very tempting, but it is not retail...
    Whatever I get, I will not buy another one if it's not a fast one, that's for sure.
  23. #698
    Feb 2005
    Thanks for the link Just now got around to checking this thread again because I forgot I had posted my question hehe
    PREVIOUS SYSTEM
    NOW RUNNING/TESTING
    D4 Pump
  24. #699
    Mar 2005
    Chicago, IL
    Which venice\stepping hast the best on-die memory controller that can handle 330+ HTT
    Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
    AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
    Long Live DFI.
  25. #700
    Dec 2004
    Atlanta
    My guess would be either the CBBLE 0512s or LBBLE 0517s. DPMW and EPAW seem to be doing very well for the 0517s. While the 0515s are monster clockers they are known to have a some what weak mem controller.
