check your contacts on all your cables that plug into the motherboard, someone had a simialr issue and it turned out their 12v cable (you know, the one with 4 connectors) was loose
jjcom
jjcom
well, at least i´m feeling much better now.![]()
All that stuff and thats not even the worst part, I 'm not going to say whats thats been like lol
I triple triple checked all connectors, heat transfer paste, lapped all heatsinks, then truple checked the whole system thrice. lol
it has got to be this motherboard
weirdest damn thing is the whole system running 1-1 passes amm memtest86 tests @ 10.5 cpu @ 440 fsb @ 11 2 2 2.0 @ 2.88
overnight not a single error
i'm stumped
got no idea, nothing to test pfffffff
done lost my mind.
have had multiple cpu's , ddr stix, video cards in this motherboard, it's quite possable something has been damaged.
I have taken it out a few times and cleaned it with a dry tooth brush
but its rock solid @ 400 11 2 2 2.0 @ 2.77 v ddr and 1.675 for the cpu @ around 2100 mhz
ok check this out
droped cpu fsb to 133
cpu multiplier to 16x
changed ddr ratio to hit 450 and timings to 8 44 3.0 @ 2.9v
ran completly stable
so to narrow it down to the cpu or the chipset's fsb
the later of the 2 i would bet is not the problem
i'm betting on it being the cpu...
its a amd 2500 + 333 fsb default cpu
that test was for the ddr
i also ran the reverse test , to test the cpu's fsb max
came to about 215 then would fail
but in the 1-1 mode it's unstable at 202 fsb
wtf
faulty chipset ???????
damaged ????
no other signs
currently running
cpu 2.4 ghz ww/ 1.875 v
ddr @ 400 fsb 11 2 2 2.0 2.77 v
ddr ratio 6/6
chipset 1.6
agp 1.5
totaly stable
chipset temp never exceeds 90 F.
wtf lol
the only thing i notice odd is the + 12 power rail is dipping slightly under 12.00 but not more than .3 of a drop
3.3 rock solid @ 3.30
and all others are fine also
cpu chipset temps are pretty low even at 100 % usage ( gamming )
well any ideas
picky motherboard, not the first.
All along the watchtower the watchmen watch the eternal return.
This is why I left the AMD world for over a year.
To be honest I've never heard of one PCPower&Cooling PSU being DOA, let alone two. I doubt VERY much that the PSU's were ever a problem. I've also never heard of anyone returning three pairs of Corsair unless you were strictly trying to overclock them, this has happened to me with one kit out of 20, but their memory almost always runs at spec. So here's what I think.
You should be testing your house current. With the amount of problems your having it seems like your getting serious voltage spikes through the wall socket which is damaging your hardware. Remember your basically converting large amounts of Alternating Current into high amperes Direct Current. Semiconductors/microchips are susceptable to spikes, and without any power conditioning your asking for trouble. Are you using any kind of overload protection? How are you plugged in, is anything else sharing the wall socket? You don't have an extension cord feeding five more extension cords do ya? No insult intended just trying to help. With so many thjings going wrong if it weren't current I'd think your inundated with static charges. Do have deep shag, or wool wall to wall carpeting? I'd use your mutli-meter to check the AC outlets. These may sound crazy, but so do the amount of things going wrong with hardware in your system drawing the most amperes.
I know the latter nForce ultra motherboards are problematic, and nForce chipsets are memory speciifc.
Q6600 (8x401FSB 1.28Vcore)
2x FX-74
Gigabyte P35C-DS3R
Asus L1N64-SLI
Corsair DDR3-1800 2GB
Geil DDR2-800 4x1GB
BFG 8800Ultra
Leadtek 7950GX2 DD GX2
Tuniq 1200W
NZXT 1200W
Storm WB 775
2x Swiftech Microdrive Socket-L
yeah, I would be wondering the same thing. But from what you'll said I would say its a motherboard issue. But if I were you I would be checking my house outlets. Try plugging the computer into another outlet on a different braker.
jjcom
i just moved 2 weeks ago, that would rule out ac because the problem still exists at the new residence.
received ddr form newegg
installed slot 1-3 2.77v @ 400 failed memtest86
ram back to new egg
received new set
imediatly test and it faled about 50 % threw test
rma this time dircet to corsair for testing and now have working ddr
I realize pcpwr and cool have a good reputation but.....
like i said, the first one was doa
would not power on
the second lasted about less than one day
turned psu off at night
woke up flipped switch on back of psu, hit power botton on case
and loud pop and white flash lol
dead
also after removal there was something loose inside rolling around
sounded like a round small rock or bearing or hard plastic lol
now for another pain, the psu had a delta fan that rattled terrably, girl fried said what the **** ship it back NOW, so I ended up swapping the fan out for a enermax dual bearing adjustable fan, worked like a champ and still have warranty in tact.
woo ha
i am betting it is the cpu itself
if the ddr will do 472 and play games, then it must be the damn cpu right ?
should i try a 2500 - m ?
mobile
let me know what you guys think
thanx
Time to go A64 maybe?
I would guess the MB. Seems like if your having that many troubles, I would guess the MB...maybe a bad chipset
jjcom
i flashed to D22 A1BK R2 TURBO EDITION
and managed to get 205 stable
i noticed my + 12 and 3.3 are a bit low
however i do not have a multimeter/potentciometer
i do hoever have adjustable rails
what should i do first ?
get ramsinks and southbrige coolers ?
or go straight to rail adjustments ?
can some one link me to a good voltage testing tool please
just go to your local radioshack, Menardes, Lowes, etc and get yourself a multimeter. There about 10bucks or so and they'll be very nice to have. DO NOT adjust your rails without a multimeter
jjcom
Try the Manta 26 BIOS. It worked best when I was using the NF7-S.
Dell 2405FPW
Lian Li PC-75B
PCP&C 510 ASL
DFI LP UT NF4 SLI-DR Expert
Opteron 180
Chilly1 SS Phase Change
2x512MB Mushkin Redline XP4000
BFG 7800 GTX 256MB PCI-E
2xWD 740GD RAID 0
Maxtor 6B300S0
Plextor PX-716SA
Audigy 2 ZS
Klipsch Promedia Ultra 5.1
ok i purchased a commercial electric hdm4100 multimeter
here are the results
PSU
3.3 is 3.36 idle
3.35 load
+12 is 12.11 idle
12.10 load
+ 5.0 is 5.14 idle
same under load
ALL MEASURED AT THE 20 PIN SOCKET AND TESTED ALL MOLEX ENDS.
MOTHERBOARD
currently wiht d22 turbo bios
i am stable @ the following
cpu 205x10.5 =2153 mhz @ 1.675 v
chipset 1.5 v @ the above speed
ddr ratio is 6/6
ddr 410 fsb @ 2.77v @ 11 2 2 2.0
STILL NOT EVEN ACHIVING 3200 MBPS OF BANDWIDTH
TESTED USING EVEREST HOME ADITION ( NEWEST )
i have cleaned this cpu many timeS with solvent and the heatsink with the same solvent
i just baught QD contact cleaner electrical grade cleaning spray
quick drying formula
leaves no residue, plastic safe
i will be cleaning the cpu and hsf
I noticed alot of dirt in the ddr slots
can i clean them with this stuff ?
let me know what u guys think
thanks again
IT WAS THE CHIPSET
droped chipset voltage to 1.5 and ddr to 11 3 3 2.5
boom running 460 fsb @ 11 3 3 2.5
over 3400 mbps bandwidth
muaahahahahahaha
scored finnaly
i knew it was possable
i will continue to push up from stock voltages
stay tuned
480 fsb @ 11 3 3 2.5
3513 bandwidth
this is amazing\
stand by
gunna top it off
muahahahaha
cpu 2400 mhz 10x240
fsb 480
11 3 3 2.5 @ 2.88 v
chipset 1.5 lol wtf is up with that lol
3600 mbps everest read bandwidth
not to bad after all hu ?
Ok here it is
cpu 2353
ddr 235
11 3 3 2.5
chipset 1.5 lol wtf
THIS DDR SEEMS TO TOP OUT BETWEEN 234 AND 240 FSB NO MATTER WHAT VOLTAGE OR TIMMINGS
ANyway it all works
over 3500 mbps everest read bandwidth
thank you all for helping me so much, you guys succeed where others fail
XTREMESYSTEMS.ORG
SETS THE STARNDARDS FOR ALL OTHERS TO BE MEASURED
THANKS AGAIN
well i figured it out. it seems i was wrong, its the bios mod i flashed to and setting 1.5 on chipset voltage, for some rason that is the sweet spot on my nf7-s rev 2.0
D22 A1BK R2-TURBO bios is the bomb
works like a champ
now attaining 470 fsb @ 11 3 3 2.5 @ 2.7v
cpu @ 2450
3500 everest read bandwidth
then
set cpc to 2t
attained over 500 fsb stable
well i can get the desktop stable @ 470 fsb @ 11 3 3 2.5 but games are not stable
anything over 420 is not stable long term and any voltage or timming
kind of bums me out
Originally Posted by mjs1231
seems the voltages of the cpu are very sensative
to much cpu voltage and it becomes unstable, could be a flash heat issue witht he core but average tempatures are well within specs of the cpu.
currently doom 3 runs fine @ 230 fsb 11 3 3 2.5 with a cpu of 2250 @ 1,725 in bios but more like 1.7 v
after all the attemps at overclocking
i have resinged from the ocing arena
nothing is 100 % stable while over 400
set my cpu to a 3200 + with a 400 fsb
i'm done...............
HAVE YOU TRIED CPC OFF? (2T)????? You RMA your other stuff that much, yet not RMA your board. You prob got a dodgy board.
check this out
i been useing a zalman copper/aluminum heat sink for a long time now, the round one with 92 mm fan.
I recently took it out and cleaned it all up
I heard that some times oil and such sink in to the metal base.
and I had noticed that my cpu temps we rising above normal for the last 6 months or so.
So turned on a burner on top my oven to the high setting and let it get red hot.
So grabbed a pair or vice grips and sat the heatsink on the hot burner.
after about 2-5 minutes and after the hs was very hot I saw the most amazing thing happen.
in the middle of the hs where you apply the thermal past.
a trickle of smoke then.... a pool of clear liquid the size of a nickle come right out of the metal before my eyes , bubbled for a few seconds and totaly evaporated leaving no trace of anything but bare metal.
I thought it might have been water but the hs was super hot by then, and water would have evaporated long before that point.
I let it cool reapplied arctic ceramique and shazam my temps were like it was brand new and 10-15 degrees F lower than before.
this is so far, a unknown effect. I have researched this but have found nothing on this event.
I speculate that the liquid was some type of oil that had soaked into the base of the heatsink, but from where it came from or exactly what it was is still unknown.
I have since super heated all heatsinks in my posession and had similar results with 75 % of them.
and my system runs alot cooler all around.
cpu chipset gpu hard disks all have lower temps now.
note..
the gpu and chipset heat sinks were completely clean before heating. both trickled smoke after 3-5 minutes and performed cooler after reinstalling them.
