OCN2
Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: I Need Xtreme Asistance
    Dec 2004
    MY SYSTEM
    ABIT NF7-S REV 2.0 MANTA RAY D26 CPC 1T XT BIOS
    AMD 2500+ PRE WEEK 34 FULLY UNLOCKED
    PC POWER AND COOLING 510 DELUXE ATX-PFC WITH FAN MOD
    CORSAIR PC3200 XL 2X512 SLOT 1 AND 3
    sata raptors x 2 only no cd drives and pata controller disabled
    I AM HAVING THE WEIRDEST PROBLEM
    I set the ddr to 9-2-2-2.0 @ 2.88 v
    cpu multiplier @ 10 = 2000 mhz @ 400 fsb
    set fsb to 220 @ 9 2 2 2.0 and ran memtest86 3.2
    passed no problems
    now
    any fsb higher than 400 makes games and apps crash
    no bsod's but just app crashing
    even at 402 fsb they crash
    wtf is going on ?????????????????????????
    all temps are very low
    cpu 96 f idle 114 max @ full usage
    cpu to 1.675
    chipset to 1.7
    agp to 1.7
    cpu disconnect enabled
    no bios shadowing
    no sata curruption at all
    spent alot of cash on this system
    spacificly for overclocking
    please some one help me PLEASE.....
    i have tried every multiplier
    every fsb
    every ddr timming
    CPU WILL DO 2.4 GHZ ALL DAY LONG NO PROBLEM
    at 402 fsb starts comming apart at the semes
    what is happining ?
    am I missing something
    xtreme energy
    Oct 2004
    Europe, Latvia
    well, maybe try testing how much fsb can cpu handle. Lower memory frequency and lower cpu multiplier and see if you have problems then. And always update all blocks when updating bios.
    Jan 2005
    Athens,Hellas
    Try 1.6 chipset voltage. You definately dont need 1.7 volts for 200 FSB. I managed to do 215 fully stable and 220 benchable at 1.6 volts
    Leave AGP voltage at default ... you wont really gain anything by increasing it. Or at least leave it at 1.6
    Sink your mosfets and some other chips on that board. Checkout Tictac site about this matter
    Your timings should be 2-2-2-11 for an amd system . Better performance.
    Try using a 10.5 multi and above. Will probably yield better results
    You must disable APIC. And if you've installed windows with APIC enabled you must do a re-format and reinstall wilth APIC disabled
    Also, check your PSU rails ... with that fine PSU you've got I think you can adjust them right? Try giving 3.4 volts for the 3.3 rail, 5.1 for the 5.0 rail and 12.2 for the 12.00 volts rail
    Hope I've helped in some way
    Mar 2003
    Denmark
    OT: MY GOD THAT AVATAR
    "M-I-A"
    Jan 2004
    Frankfurt, Germany
    lol you don't know the thong lady ?
    Err are the SATA ports locked on the nf7 ??
    Mar 2003
    Denmark
    Sai = no I dont ? Could you plz PM me something to show for
    The SATA port should be locked on the NF7 - Say have you tried another bios than that manta?
    "M-I-A"
    Jan 2004
    Frankfurt, Germany
    There's a site with about 100 pics of her showing her ass
    But i don't know the adress, but I'll bet enough guys here know
    Mar 2003
    Denmark
    Madgamer already sent it to mee - thx anyway
    "M-I-A"
    XS Intel News & D²OL enhanced
    Nov 2003
    Netherlands
    haveing lots of fans doesnt mean your northbridge is cool. what heatsink do you have on it?
    Dec 2004
    fsb
    the cpu cooler is the zalman cu????? big round copper one with 90 mm fan
    lol
    and i use artic ceramique
    also
    the 420 thing did not work not stable back to 400
    this is weird, I will be ordering the mosfet coolers soon but i dought that is the issue
    I check the rails on the psu with a multimeter and all are fine
    i just dont understand, I am guessing this motherboard is a lemon for overclocking.
    will be upgrading the motherboard and cpu this summer but am un sure what to get
    need some feed back from you guys please, here is what i looking into
    i want a amd fx cpu not sure which one yet
    which one is unlocked and gives good fsb overclocks ?
    maybe nforce3 or 4 or socket 939 or abit fatality 1
    just dont know yet
    what do you guys think ???????
    thanks again for all the support from the OC community
    ur the bomb
    lol
    peeeeec
    M.Stevens
    Jan 2005
    All FX cpus are unlocked. They are enthusiast parts.
    Sep 2004
    I had the same problem as you... err.. I still have the same problem... but on another nForce2 Ultra400 board... The FSB refuces to be stable above ~ 210MHz or VDD > 1.6V... Even though I was able to benchmark at 250FSB @ 2.0V VDD, the system was really unstable with VDD above 1.6V and even though I cooled my mosfets and had proper cooling on the chipset, the problem remained...
    Try relaxing CAS and getting those voltages up.
    You need POWER to overclock.
    (Sheesh, I thought was Xtreme overclocking !)
    Jan 2005
    Athens,Hellas
    Try 1.5 chipset ... old stories of NF7-S boards had to set the chipset voltage to 1.5 volts for 230 + FSB ...
    Dec 2004
    fsb
    ok tried the 1.5 chipset setting but just made the problem worse
    seems like the chipset is not getting enough voltage
    what rail on psu modifies chipset voltage ?
    my psu is a pc power and cooling and has adjustable rails
    c[_]
    Nov 2002
    Alberta, Canada
    run ram timings of 2.5-3-3-x or 2-3-3-x. Your memory uses TCCD chips if i'm not mistaken which cannot do above 220mhz with tight timings very easily or very often..
    1T will limit you also since you have 1gb ram, but I stay with 1T (CPC on) since the performance hit of 2T (CPC off) is not worth it to me.
    To raise chipset voltage you need to do the VDD mod.
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Dec 2004
    fab update
    i just flashed back to the d24 bios and now at desktop @ 420 fsb @ and seems a bit more stable with ddr @ 11 2 2 2.0 @ 2.9 v
    now about the amd 2500 + i'm running
    does the following apply ?
    drop multiplier to 10 or 10.5 with a fsb of 220 or higher
    do i need to raise the voltage going to the cpu to support the higher fsb or is the voltage based on clock speed alone ?
    thanks
  18. #18
    Dec 2004
    nope did not work, still crashes games lol
    fakkkkkkkkkkk
  19. #19
    Dec 2004
    fsb update
    no matter what i do this system is not stable over 400 fsb
    any voltage
    and ddr timmings
    i dont get it
    got every part for overclocking and will not do 402 fsb with out crashing
    510 deluxe atx pfc
    nf7-s rev 2
    amd 2500 +
    corsair pc3200 XL
    albatron 5900 xt
    agp locked @ 66
    what a joke
    could have saved 500 dollars
    and got a value system that performs the same lol
    and no i'm not going to do the L12 mod or the chipset mod
    k7 platform is aging and will soon be a legacy platform if not allready
    I noticed in everest the memroy bandwidth is doubled on the same ddr when going to amd 64 system
    w t f is that about
    tells me the k7 platform memory controllers s u c k
    hint hint ( legacy )
    I think its best to wait for the nforce 4 full desktop platform, that way just upgrade cpu , motherboard and maybe video card
    anyone want a cpu,motherboard and video card
    they all run perfect @ 400 fsb lol and I have taken good care of all parts, nice and clean, allways use arctic ceramique. Never ran overclocked lol it wont do it lol
    I will give a great price with a bundle deal to who ever wants it
    say 250.00 for all 3 devices not bad considering new would be 180 vc, 80 cpu, 80 mb.
    and i'll pay for the shipping to make it that much easier on you.
    yahoo IM is mjs1231
    god help us all
    cuz u know bush won't
  20. #20
    c[_]
    Nov 2002
    Alberta, Canada
    Did you try 2.5-3-3-8 with 2.6v?
  21. #21
    Dec 2004
    fsb update
    yes I tried that setting and lots more
    this is very weird
    I did notice one thing my + 12 volt is below 12 volts allmost all the time, on occasion it jumps above 12 .00 but not often
    is that a issue ?
    I dont get it , others hitting 225 and 250 with the same ddr as me .
    i have tried all the tictac mod bios's , mantaray ect
    no difference on any of them
    every bios works exactly the same. lol
    going out today to get a new multimeter.
    funny thing also is , when i overclock the ddr to far, bank1 one returns errors
    allways bank 1
  22. #22
    Mar 2003
    Denmark
    Say have you tried other modules?
    "M-I-A"
  23. #23
    c[_]
    Nov 2002
    Alberta, Canada
    tried moving ram to different slots? Give trats or merlin's D26/D27 a try, tictac's bioses are tuned for tight timings so your RAM might not be doing well since TCCD cant get above 220 with tight timings very easily.
  24. #24
    Dec 2004
    lol fsb
    funny you ask
    I purchased the corsair pc 3200 XL 2x512 from newegg, had to return them twice to new egg, then after receiving 3 sets of bad memory i went dircetly to corsiar and had them replace with tested sticks.
    took over 1.5 months and spent way over 400 dollars, loosing time at work and paying for all that shipping , and if thats not bad enough i paid for overnight service the first time i purchased.
    I just cant win
    check this out
    baught the pc power and cooling 510 deluxe atx pfc
    directly from the manufacturer
    first one was d o A
    second one lasted only one evening
    woke up at 5 am to go to work
    turn power on and there was a loud pop and bright flash
    second one was dead
    got a new one but lol it had a delta fan in it , so loud i could not even run it in my living room
    so I figured to take things into my own habnds at this poing
    now check it
    took the psu apart
    without cutting any wires or voiding my waranty
    I swapped in a enermax dual bearing speed adjustable 80 mm fan and used the extra molex connecto to connect up to the psu's 2 pin fan power connector
    used wire cutters to clip the 3 leg from the 3 pin and boom
    totaly silent and runs like a champ
    and still got a warranty
    now to the video card
    lol
    got from new egg
    sent it back 3 times for a swap
    to this day this vc goes into autobreak mode durring games, i however once again took things into my own hands
    scored a pci fan card and modded with same enermax fan
    so it flows directly on the heatsink and ramsinks
    also
    i ordered a vga silencer nv3 for 5900 xt cards
    found out my vc pcb only has 2 holes and the cooler has 4 legs lol , to make things worse, i can not get the ramsinks off, tried the freezer trick overnight but with no luck
    even grabbed them with wire cutters but damn things would not pull off.
    they must use some new type of glue when installed at manufacturer
    I must have the worst luck of anyone i know
    been a IT consultant for many years
    highly reguarded by many
    I'm the guy that resolves all the really hard problems that techs can not resolve.
    degrees listed below
    MIS
    minor in Business and MBA
    mcse certified win2k platform
    cna certifeid
    oracle certified
    and now i trim trees for a living lol
    no jobs anywhere lol can not even buy a interview lol
    big bush economy lol
    mr. big spender
    daddy outsourcer
    THE GREAT DECEIVER
    just my take on things
    anyway can you beleive the problems i have had with this system ?
    i post in corsair forums and the ramguy asked me if i wanted the modules replaced lol
    after all that what a joke
  25. #25
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by mjs1231
    funny you ask
    I just cant win
    check this out
    first one was d o A
    second one was dead
    now check it
    took the psu apart
    lol
    got from new egg
    also
    MIS
    cna certifeid
    oracle certified
    mr. big spender
    daddy outsourcer
    THE GREAT DECEIVER
    wow... theres something wrong with your karma account, lol , prepair for a huge karma refund
