The "more voltage is better" version of OCZ EL DDR PC-3200 Platinum Revision 2
The "2.8V to 2.9V is all I need" version of OCZ EL DDR PC-3200 Platinum Revision 2
If you have the newer version that favors voltage, how much VDIMM are you feeding your modules for 24/7 use? I finally had about fifteen minutes to play with my RAM this morning and am curious to explore beyond 3.15V when I return home tonight.
