Page 18 of 18 FirstFirst ... 815161718
Results 426 to 444 of 444
Thread: OPPAINTERs early G70 watercooled results!
  1. #426
    XS News
    Jul 2004
    Quote Originally Posted by sysfailur
    Post of reference for anyone wanting to know....
    Just did my first BASELINE test to work from... nothing overclocked.
    3500+, 1gig hyperx, a8n-sli prem, 7800GTX
    3dmark2k1 == 23402
    Again, no oc'ing what-so-ever. Now... time to have some fun! MWHAHAHA!
    only 23402?
    my x700 is doing better than that with a mild overclock..... and its 8 pipe 128 bit, $120..... 23k is very low...
    AMD Athlon 64 3700+ @ 300x10________15" Macbook Pro
    2x 512mb Mushkin DDR _______________2x 1Gb DDR2
    Sapphire X850XT____________________X1600M
    DFI Ultra-D_________________________2.16Ghz Merom C2D
    Lian-Li PC7A________________________OS X/XP
    PCP&C 610w Silencer
  2. #427
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    *shrug* I dunno why it's low--I hit 26696 as my best now. I do know that my system is being held back by the processor though
    #'s of 01 test.
    314
    107
    433
    226
    279
    127
    360 <---only really impressive bit :P
    I'll keep toying with it.
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
  3. #428
    Admin
    Feb 2005
    Ann Arbor, MI
    I know this is slightly off topic, but for the cold bug/throttling issue, I've heard that keeping the fan connector in use helps somewhat. Can anybody confirm this (with a regular BIOS, not the special ones with the deactivated throttling)?
    Oh, and sysfailur...just tweak a little bit and those scores should come up....what are your 03 and 05 scores?
  4. #429
    Jun 2002
    Haven't run em yet vapor... been working on high 1:1 FSB. I think I know what the problem was....
    My timings were messed up before and because of that I couldn't run high 1:1. So I was running the mem slightly lower during benching (other than the base bench which was 1:1).
    In any case, I just messed with the timings and air cooled (and the chipset PASSIVE cooled) I just hit 300mhz screenable 1:1. 290 benchable 1:1
    I do declare, a voltage mod is in order!
    EDIT: Not trying to hijack the thread btw :P I'll try and stick to the topic at hand.
  5. #430
    Oct 2002
    London UK
    Quote Originally Posted by Troman
    Xtremeresources what the
    its seems you have not been here for very long
  6. #431
    Admin
    Feb 2005
    Ann Arbor, MI
    Not trying to prolong the hijack, but is it still possible to do the BIOS vmod (I know, not xtreme, but it's wicked easy)?
  7. #432
    Jun 2002
    Update: 9103 in 3d05 for me--a little more in the right direction.
    281 1:1 @ 2.533ghz.
    7800gtx @ 525/1335
    I think my 01 skills are just lacking :P
  8. #433
    Jan 2004
    Arlington, Texas
    yeah man your 01 seems super low, i got near your stock with a 9800np and nf2 rig!! not to great for a card 2 gens ahead... not bad with 05 though, great stuff opp keep up the great work! cant wait to see some phase cooling results!
    "each driver release plays whack-a-mole with a few more annoyances" -inq
  9. #434
    INTEL inside
    Oct 2004
    Québec, Canada
    281 1:1 @ 2.533ghz.
    7800gtx @ 525/1335
    a little OT... how is the A8N SLI "premium" compared to the old A8N SLI DX ?
    1T solved ?
    retired computer enthusiast
  10. #435
    Jun 2005
    Could I get similar results with a Prometia Mach II GT? What ya think oh omnipotent overclocking guru you!?
    A64 3400+ Newcastle (754) - 2600 Ghz (260X10) - DFI Lanparty 250Gb - Zalman Cu-7700 +AS5 - Idle: 39 Load: 63 - Voltage: 1.50 + 110% - 512MB OCZ Gold PC4000 @ 260 CS 3.0 - Voltage: 2.90V - BFG 6800Ultra OC+AS5 435/1.10 - Idle: 50 Load: 69 - Maxtor 80 GB IDE Drive (Storage) - Maxtor 160 GB IDE Drive (Storage) - WD 37 GB Raptor Drive - Audigy 2 ZS - 2X Altec Lansing 641 (2X200W Woofers)+(8X50W Sattelites) - 420 Watt Enermax Noisetaker
  11. #436
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    Just saw this thread. Just wanted to again tell you you are doing an amazing job. Gratz!
    And Durandal, OPP Is one of the most renamed overclocker in the world. He is very talented with his hardware and knows what he does. Additionaly, his cooling is way better then a Prommy GT... He has some cascades.... some -90C capable cooling. Plus, he currently uses some hardware that no one can afford, and he got them even before they were out so he could play with them.... But I said that many times, the OCer makes the OC, not the Hardware. And thats why OPP is often on the top
  12. #437
    XS News
    Jul 2004
    Quote Originally Posted by skate2snow
    g70 has been in stock since hours after NDA release
    PCP&C 610w Silencer
  13. #438
    Jul 2002
    Belgium
    Quote Originally Posted by No_Name
    my config:
    Galaxy 2*7800 GTX on Water, Gskill 4800 gblb,
    FX 57 MPMW @ 3.6 Ghz, DFI SLI, cooled bei Mach 2GT
    12*300@2,5/3/3/7/ 2,8 Volt, FX 57@1,61V
    78er@530/715
    who needs cascade to reach 3.6 ghz
    Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
    EVGA E762 4Way SLI Classified - 980X @ 6Ghz Ln² 6GB Dominator - MSI 5870 Lightning
    WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
  14. #439
    Jun 2002
    Quote Originally Posted by Supertim0r
    1T solved ?
    I can't run 1T really I don't understand what the prob is.. I've hit 349mhz fsb on it w/ passive cooling.
    Just doesn't wanna do 1T.
  15. #440
    Jul 2004
    Own little planet.
    these cards got the cold bug? i think mine is throttling back under water, temp is 34.
    ive slowed my fans down but i dont wish to hinder cpu temps. is there a fix about for this?
    X2 4400 @ 2706mhz
    7800 @ 515/1300
    2 x 512 Mushkin redline 4000
  16. #441
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    Quote Originally Posted by Usurper
    http://www.xtremesystems.org/forums/...ad.php?t=67249
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
  17. #442
    Jul 2004
    Own little planet.
    sorry, got alittle worked up and didnt use the search properly, many apologies.
    X2 4400 @ 2706mhz
    7800 @ 515/1300
  18. #443
    Nov 2004
    New Jersey
    Quote Originally Posted by LenniZ
    Yea, but its only the SLI thats giving a good nature score, all other scores are beaten by a single x800! try a single G70 and show us the 01 performance
    you going to run the games in 01 with your x800 anytime soon? didnt think so....
  19. #444
    Jun 2005
    I just have to say that this thread inspired me to get a 7800GTX...loving it and even though I can't compare with those benchies by OPP, etc (mine=8702 in '05, 18307 in '03, 29606 in '01 - stock cooling), I love the card and I know it was worth getting rid of my old 6800GT
    Thanks guys
    Intel Xeon 3070 @ 3600MHz Stable, 4GHz Max
    Abit IP35 Pro
    MSI 8800GTX
    Custom and blinged out water cooling
    Project <<|Black3d|>>
    Logitech G5/Saitek Eclipse
    Dell 2405FPW 24" TFT
    Tagan 1100w
