Page 143 of 209 FirstFirst ... 4393133140141142143144145146153193 ... LastLast
Results 3,551 to 3,575 of 5204
Thread: The Official Opteron 939 Overclocking Thread
  1. #3551
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    You were not supposed to see this.
  2. #3552
    Mar 2005
    Belgium
    Quote Originally Posted by Primoz78
    Here are one of CABYE 0540 APMW....it seems really cold even with VCORE of 1.53V...in the picture there is a qucik setup...I will burn it and will try to push it further...
    http://img384.imageshack.us/img384/6218/clip32fv.jpg
    Idle temps: 20 - 22°C
    Full load temps: 35 - 37°C
    This is with HS on, under water cooling room temperature is between 18-20°C!
    Maxtcase is 59°C.
    Will report if I can get further...for now is Super_PI stable but not prime stable
    Regards,
    Primoz
    My ampw runs hot !! Like 50-52°C on 1.55V at 2.9-3ghz.
    This with WC and IHS on.
    MAxTcase is 57°C and 44.1Watt
    Full stepping:
    OSA146DAA5BN
    CABYE 0540 APMW
    1330174550076
    Now what is my batchnumber again because i forgot which numbers the batch was.
    E6400@3.2GHZ | P5B deluxe |8800GTS 512MB | 2*250GB Hitachi + 500GB WD|
    Aerocool masstige | Seasonic 600W |
    MX510@450HZ | 24" LG 245WP
    Cooled by: Swiftech storm - MCP 655 - Maze4/EK vodni block - Nexxos Dual Extreme
    A64 3000+@2.9ghz // XP M 2500+@2.5ghz // XP M 2600+@2.6ghz benchable at 2.9ghz superpi 35s //
    AMD opteron 146@3GHZ CABYE APMW batch 0076
  3. #3553
    Jul 2005
    Stragne...I have never reached 40°C with this APMW...even under 1.586V...this is really cool...
    Lp Primoz
    p.s. Maxtcase is 59°C and 50watt...
    CPU: Q2C 6600 @ 3712mhz 1.456V
    MOBO: DFI LT P35
    MEMORY: Gskill F2-6400PHU2-2GBHZ
    GPU: ASUS 8800GTS 320mb
    PSU: Enermax Infinity 650W
    CASE: CM Stacker 01 rev. 2.0 balck
    COOLING: MCP355+Alphacool moded TOP, AQ MP-05 SP LE, Cooltech DUAL, EK RES 200
  4. #3554
    Xtreme Mentor
    Nov 2004
    Elma, NY
    Quote Originally Posted by GoThr3k
    havent i explained in the other thread what the problem was??
    anywayz, i switched the ram back to slot 1&2 and everything works nicely
    Not really, this was your post -
    problem is solved thoug
    it is 1000000% stable @ 2.8GHz @ 1.45V stock cooler
    stock cooler => TT BT
    would be nice
    which grid do you need for lapping??
    You never stated what the problem was....
    But thats cool that you got it fixed.
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
  5. #3555
    Jan 2003
    Knoxville, TN
    anyone using the dfi board notice if they get more stability when they are NOT using the 4volt vdimm jumper?
    i was trying to figure out why my chip wouldn't do 3 ghz anymore after switching from 2x1 gig crucial to 2x512 bh-5. set jumper so i could get 3.4 volts to my ram. then noticed chip wouldnt do 3 ghz anymore.
    figured it might be the instability caused by the jumper.
    switched the jumper back and now the chip ran 10 hours of small fft prime with no error.
    anyone else do any testing of this sort?
    Main Rig:
    CPU Intel i5 2500K @ 4500mhz
    Mobo Gigabyte GA-Z68X-UD3H-B3
    Memory 4x4GB Corsair Vengeance DDR3 1600
    Video Cards Sapphire 5850
    PSU Silverstone ST75F Strider 750W
    Hard Drive OCZ Solid 3 60GB | OCZ Vertex 2 60GB | Samsung 103SJ's 4TB
    Cooling Thermalright Ultra 120 | 1 Yate Loon D12SM 120MM
  6. #3556
    Banned
    May 2005
    Belgium, Dendermonde
    Quote Originally Posted by dnottis
    would be nice
    my problem was instability
    but not anymore, had to switch the rams to other slots
  7. #3557
    Mar 2005
    Belgium
    Lp Primoz
    seems to great difference between the APMW's , going till 3.1ghz@1.56V till 2.9ghz@1.57V etc..
  8. #3558
    Oct 2005
    CABNE 0530 @ WC 3000Mhz@1.39v
    Ultra-D (704-2BTA)
    PI 32MB
  9. #3559
    May 2004
    Netherlands
    why won't my opty do 270x10, 280x10, or 290x10 stable? it BSOD's after a couple of minutes in Prime95, no matter what CPU voltage i select. My mem can do up to let's say DDR630 1:1. Also, i read in this topic a little and found out that a lot of users who want 2900 are using the 9x multi. I also have a lot of problems using 10x multi, but 9x is fine. How come?
  10. #3560
    Dr. / Professor
    Apr 2004
    Phoenix,USA
    Some initial info on the 148 0543 FPMW's that seem to be coming from multiple retailers as of late: [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] I did not try a 32m with the 2905 speed. These were to be thumbnails I thought.
    8 hrs Prime @ 4500 (9x500) DDR-1200
    9.59 32m Pi @ 4810 (8.5x566)
    9.59 32m Pi @ 4gb DDR 1248
    700 Club @ 7 x 585 CPU-Z Val
    Prime @ 542 x 7 (4 hrs 1.28v)
    32m 5006 (9.48)
    OC Formula 3770k-dl G.Skill 2666 C10 Galaxy 660Ti 3gb Apogee HD PlextorM5P xfx p850
    MVF 3770k Team 2600 C10 xfx 7850 2gb xspc RayStorm HyperX 3k Hyper 730
    Gigabyte EP45-UD3P e8500 Crucial 8500 khx9600 evga 9800gtx PCP&C 610 H20 by Coop
  11. #3561
    Dec 2003
    Slovenija
    Here is my 4 new toys.
    ASUS P5B Dlx; 2 x 1024 MB Crucial Tracer
    Xeon 3110@4000 MHz 1.296V Seasonic 600W,
    8800 GT
  12. #3562
    Xtreme Mentor
    Nov 2004
    Elma, NY
    Here is my 148...
    ASUS P8P67 LGA
    GTX 680 1300/7000
    Lian Li PC V-2000
  13. #3563
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by shimmishim
    no probs here with 146 CAB2E 0540FPMW and 2x 512MB XMS3500C2v1.1 BH-5 using
    3100mhz at 1.536v and ram @258mhz 2-2-2-5 at 3.44v
    3000mhz at 1.44v (can do 1.392v but high vdimm upped vcore) and ram @250mhz 2-2-2-5
    Using
    System
    Opteron 146 CAB2E 0540FPMW @3000mhz
    DFI NF4 Ultra-D 704-2BTA
    2x512MB XMS3500C2v1.1 BH-5 @250mhz 2-2-2-5
    74GB Raptor OS
    160GB Seagate 7200.7 NCQ
    510W PC Powercooling SLI PSU
  14. #3564
    Aug 2004
    rutgers
    is anyone here using anything other than a DFI board? im using a epox 9nda3+ (nf3 ultra) and was wondering if it could be holding me back some? Ill probably be upgrading when the next ati/nvidia refresh occurs.
  15. #3565
    Banned
    May 2005
    i am using MSI
  16. #3566
    Aug 2004
    Huddersfield UK
    Guys could you help?
    Any of you using phase change cooling?
    When does the cold bug kick in on average with Opteron chips?
    If any of you have found a work around for the Cold Bug with these chips and single stage please post.
    ASUS M4E
    2600K @5.1 24/7, 1.45v
    8GB G.Skill RipJaw 2133mhz
    580 GTX Tri SLI @925, 2400
    Silverstone Strider 1500w
    OCZ AGility Raid 0 OS, Corsair GT's Raid 0 for data.
    Win 7 64 Bit Sp1
    ASUS R4E
    3690x 5.125 24/7 0901 or 0083b
    32GB G.Skill Ripjawz 2133mhz cas 9 or 2333mhz cas 10 or 16gb 2400mhz cas 9
    Win 7 64 Bit sp1
    "Only the strong will survive!" -Pazza316 when commenting on training with him!!
  17. #3567
    Banned
    Feb 2005
    Colorado
    Things you could try. get your voltages set to where you want them for your OC. Then be sure to have A64 tweaker and Clockgen allready downloaded on your rig and ready to run. I would also recomend a program that will put a lil load on the CPU when you fire it up. This will put some heat in the chip and help against cold bug.
    So when you boot into windows run (i use Super PI 32meg) program for load. I would recomend doing this at about -24 to -25 celsius for boot up. Then using Clockgen change your values of FSBand Multi to where you want them for OC set in place and then tune your mem timmings with A64 Tweaker. if you prefer to do A64 tweaker first thats fine. Try that to see if that helps.
  18. #3568
    Jun 2005
    Bangkok
    Quote Originally Posted by pazza316
    This is with a stock Vapo LS
    Inital run up
    http://www.xtremesystems.org/forums/...postcount=2720
    340x10
    http://www.xtremesystems.org/forums/...postcount=3162
    The chips run hot once they get going so no Cold-bug at 'stock' LS temps from what I see
    EDIT:
    Quote Originally Posted by kemist
    Here is the same chip on an Asus A8N SLi - Deluxe .. limitation is the MB as Mx HT is 320 & 2T - then SATA controller drops the RAID.
    VapoChill LS [AC] / QX9650 / X6800 / E8500 / Q6600 / CF-3870x2 / 8800 GTS G92 512 / XFX 7950GX2 (H20) / GeIL PC2-8500 C5 / PC2-6400 C4 / SilverStone OP1000 / ST75ZF
    Abit IP35-Pro | 3DM06 - 18,264 | PCM05 - 23,577 | PCMVA 13,063
    DFI 680i LT | 3DM06 - 24,602
    Abit X38 QuadGT | 3DM03 - 120,337 | 3DM06 - 28,176
  19. #3569
    Jan 2005
    NYC- USA
    LOL I'm using an EPOX 9NDA3J with a 144 Opty but damned if I can get mine past 283HTT locks after that. So If you figure anything out let me know,
    Opteron 144
    EPOX 9NDA3J with XP-90C
    XFX 6600GT Zalman VF700ACLU
    Patriot PC 3200 LL 1.5 GB PC3200 2.2.2.5
    WD 120GB, 40GB HD's
    Thermaltake Silent PurePower 420W
  20. #3570
    Aug 2004
    rutgers
    Ive had it up into the 300's, have you tried upping the board volts? I was asking mainly cuz i was wondering if the board could hold you back in general. In the anandtech reviews they make it seem like some of the boards allow higher overclocks than others all other things being equal. Basically im asking if anyone went from something like an epox or msi and saw better clocks and if thats common or not.
  21. #3571
    Sep 2005
    The Netherlands
    @GUFY:
    Are those 0540 FPMW's or do I read it wrong
    Epox 9NPA+ Ultra - Opteron 146 0530 APMW
    Infineon BH-6 2x256mb - Tagan 480W-U22
    Gainward 6600GT Vmodded - Kingston HyperX BH-5 2x256mb
    Infineon BH-6 280MHz 2-2-2-5 @ 3,77V - 3602MHz - PhCh mem Project
  22. #3572
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    Apmv
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
  23. #3573
    May 2004
    Quote Originally Posted by TEDY
    Apmv
    APMW
  24. #3574
    Dec 2004
    Gorssel, The Netherlands
    hi I'd like to know when AMD is going to start selling more opteron 939's BECAUSE THEY ARE ALL OUT OF STOCK EVERYWHERE!!!!!!!!
    C2D E6300 @ 3.5ghz | 2x1GB ADATA "Micron D9" @ 500 4-4-4-12 2.3v | Asus P5B-E Plus C2 | Sapphire X1900XT 512MB | Tuniq Tower 120
  25. #3575
    Sep 2005
    Germoney
    Next Year in January perhaps Eduard.
    X2 3800 0608BPMW 2x3050Mhz by 1.35Vc Dual Prime 25.1 Custom Testing 146CABNE 0530APMW 3050Mhz at 1,36VCore 2 Hours 2800Mhz@1,2320Vc Prime Custom 24Hours
    DFI LP UT D 2xBlack Ice Extreme II Radiators, Laing DDC Pro, Cape Coolplex 25, Tygon R3603 11,2/8mm, Lics MII CPU Cooler.4x Silenx Ixtrema 120mm Fans 14dB at 12V
    Thermaltake Armor Alu Case,PSU Seasonic S12 500W, Sapphire X1950XTX
    2Gb Teamgroup xtreem DDR500 Samsung UCCCs
