Page 13 of 125 FirstFirst ... 3101112131415162363113 ... LastLast
Results 301 to 325 of 3724
Thread: AMD Cayman info (or rumor)
Hybrid View
    Mar 2005
    Rotterdam
    doesnt anyne else find this 32 rops number too low?
    Gigabyte Z77X-UD5H
    G-Skill Ripjaws X 16Gb - 2133Mhz
    Thermalright Ultra-120 eXtreme
    i7 2600k @ 4.4Ghz
    Sapphire 7970 OC 1.2Ghz
    Mushkin Chronos Deluxe 128Gb
    Banned
    May 2006
    Brazil
    Quote Originally Posted by Dimitriman View Post
    me.. I hope it doesnt hold back cayman.
    at least 2Gb framebuffer is confirmed
    Jan 2008
    Quote Originally Posted by -Sweeper_ View Post
    Hope this is for 6950. They didn't wanna show their cards on that slide listing only the Power for both.
    Feb 2009
    VLIW4
    New architecture anyone?
    Anyone has the original source (says there expreview on all 3 photos).
    By the way, there is absolutely no indication of how big Cayman is on that photo, in case someone is claiming "THAT CHIP IS HUGE!!one".
    Jul 2010
    Looks almost as big as a GF100. If AMD can keep up their perf/mm^2 this thing will surpass GTX 580 easily.
    "No, you'll warrant no villain's exposition from me."
    Xtreme Cruncher
    Jun 2006
    If this thing is indeed VLIW4 and has 1920SP,it's game over for any GF1xx chip,no matter if it has full 512 CUDA cores and high clock. With Cayman XT on the market,Cypress is going to be lowered in mid-high class and GTX480 as well.Antilles will be uber high end,in a class of its own,in line with Chuck Norris comments we already saw.
    Jan 2008
    Quote Originally Posted by informal View Post
    Can you educate or expand on VLIW4 I'm not familiar with this.
    Sep 2007
    Jakarta, Indonesia
    The box shape in the middle of the PCB isn't the chip itself, but the substrate/packaging size with its corresponding pin out. The chip itself would be rotated 45 degree in orientation, just like Cypress and Bart, and if you look further behind, R600. I still believe the chip won't be bigger than 400 mm^2, with TDP no higher than 230 w.
    Jul 2010
    Yeah now that I look the pcb doesn't seem that much longer than a 6870.
    Rop count seems a bit low, but who knows how it works with the VLIW4 architecture. 2 GB reference is nice though.
    Feb 2006
    La La Land.
    8 phase power on stock pcb. yum!
    Primary Rig
    Intel Xeon W3520 @4200Mhz 24x7, 1.200v load (3845A935)
    Gigabyte X58A-UD7
    Patriot Viper II DDR3 2000 CL8
    Tagan BZ1300
    DeepCool Gamer Storm with 2x120mm DeepCool fans.
    MSI GTX 470 Twin Frozr II
    Zotac GTX 470 AMP edition.
    GPU collection : http://www.xtremesystems.org/forums/...5&postcount=64
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    2GBx2 Corsair DDR3 1333
    Tagan tg500-u37
    Arctic Cooling Freezer 7 Pro Rev.2
    XFX 9600GT
    Dec 2008
    Raleigh, NC
    Whooa, looks sweet!
    So educate me on what VLIW4 is...
    Jul 2010
    Do you remember all the 4D instead of 5D shader rumors for the HD68xx? If I'm not mistaken, it's that. Charlie wrote a bit on it here:
    http://www.semiaccurate.com/2010/09/...thern-islands/
    But, as we already know, it didn't turn out true for the HD68xx cards.
    Xtreme Mentor
    Jul 2008
    Shimla , India
    For people who dont know AMD used 5 way design's for most of the cards till now including the 68xx now VLIW4 is different in several ways.
    The easiest way to tell the difference is that VLIW4 is suppose to use 4 medium sized units where as the old 5 way design used 1 big and 4 small units.
    Coming Soon
    Apr 2008
    Lansing, MI / London / Stinkaypore
    ^ Evergreen had OCP so Furmark didn't use more than board power.
    WXYZT turns to WXYZ with T probably done in emulation (WXYZ or T for GPGPU).
    The penultimate reason for this is die size. And yet Cayman is still big. Makes you wonder.
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Jul 2007
    Quote Originally Posted by Macadamia View Post
    I disagree about die space. Reducing the width of the SP increases the ratio of logic per SPU. Without knowing more specific architectural details I'd guess 5D->4D is ambiguous or detrimental to die space.
    Apr 2008
    Quote Originally Posted by Solus Corvus View Post
    Hm? How does logic go up? Logic should go down (minorly, 10-15% die size would be fortunate) and perf-logic ratio should get boosted just slightly less.
    Unless it's WT-XT-YT-ZT which might be what you mean. That'd be quite an increase actually, but the ratio's way overdone.
    I'm thinking of WXYZ + logic in the SIMD blocks that allows transcendentals to be performed through looping or such.
    Jul 2007
    Quote Originally Posted by BrowncoatGR View Post
    Iirc to take advantage of all the the SPUs per SP certain scheduling conditions have to be met that makes it very difficult to even get close to the theoretical max performance with real world code
    Which might be exactly the reason for a change from 5D. Theoretical power going unused only drags down energy efficiency. Higher real utilization of units will increase overall power usage, but will also increase performance/watt - maybe to a greater proportion.
    Quote Originally Posted by kadozer View Post
    What about low ROPs listed? Wouldn't that still be a bottleneck?
    Maybe, but we don't know if they are directly comparable to current rops anyway.
    First off we are assuming that they didn't increase the size of the register file, complexity of the branch predictor, size of the texture units, size of the L1 cache, amount of shared memory, and complexity of the controlling logic - if they did then every SP and SIMD would have an increased ratio of logic to SPUs. Even if they kept it the same we are talking about 25% more SPs for the same number of SPUs (400 SPs vs 320 SPs). But they seem to be increasing the SPU count to 1920 if the rumors are true. So that's a 50% increase in the number of SPs (480 SPs vs 320 SPs). And if 16 SPs per SIMD is the same then it will be a 50% increase in texture units, L1 cache, shared memory, and controlling logic (30 SIMDs vs 20 SIMDs).
    This may be a very powerful chip.
  18. #18
    Aug 2010
    Athens, Greece
    Can we have 32 SPs per SIMD with 4 Texture Units ??
    Something like 16x2 SPs with 4-way VLIW 128 Shaders with 4 Texture Units
    Intel Core i7 920@4GHz, ASUS GENE II, 3 x 4GB DDR-3 1333MHz Kingston, 2x ASUS HD6950 1G CU II, Intel SSD 320 120GB, Windows 7 Ultimate 64bit, DELL 2311HM
    AMD FX8150 vs Intel 2500K, 1080p DX-11 gaming evaluation.
  19. #19
    Oct 2009
    That ~10-15% number was also my estimate. It's of course dependent on the actual code running. It will be possible to construct cases were Cayman will be slower than Cypress (if Cayman doesn't have significantly more than 1920 SPs). But generally, it will gain the most in situations where the VLIW5 architecture fared worst in comparison to nvidia.
    Actually it is already known how the VLIW4 units will be organized. The codepath for that arch in the driver is functional since Catalyst 10.4, I've posted some stuff about that over at B3D 10 days ago.
    The transcendental functions are done by the xyz units working together (just like it is done for double precision already now, only that it takes 3 slots), so 3 of the 4 slots of the VLIW unit are used to calculate a transcendental. The fourth slot (w) does not take part in that and is still free to use in the same cycle. That means a good part of the t unit got split up in three parts and is distributed to the x, y and z units.
    Another function of the t unit was doing format conversions and roundings. This functionality got replicated to all subunits. That means for this kind of stuff Cayman will fly.
    24bit integer arithmetics are now fully supported by Cayman and can be done in all 4 slots (Evergreen had only partial support which was not really used).
    A 32Bit integer multiplication will unfortunately block all 4 slots (could be done by the t unit with the xyzw slots free for use by other instructions in Evergreen), but this is probably the price to pay to get some transistor savings from the change.
    All other integer instructions can again be done in all 4 slots (as before).
    Double precision instructions behave the same way as in Cypress. Everything involving a multiplication (MUL, FMA) takes 4 slots while the other stuff (like ADD and conversions) takes 2 slots. That means the DP:SP ratio is 1:4.
  20. #20
    Feb 2009
    Quote Originally Posted by Gipsel View Post
    I just realized that's your first post ! Yet a good one!
  21. #21
    Xtreme Cruncher
    Jun 2006
    Effectively,Cayman could have 50% more SP resources than Cypress,taking into account the grouping per SIMD. If the clocks stay in the range of Cypress,this thing will be the fastest single GPU card on the market,hands down. Now,how will they manage to put two of those monster for Antilles card and keep "reasonable" TDP is another question.
  22. #22
    Xtreme Mentor
    Jul 2008
    Shimla , India
    There are three possible ways to do that:
    1. Decrease clock
    2. Decrease number of SIMD
    3. Using a new spin of the silicon with other enhancements/modifications.
    Since cayman is a 4 way design i would think so will Antilles...
    Coming Soon
  23. #23
    Jun 2005
    Quote Originally Posted by ajaidev View Post
    1. Decrease clock
    What I would like to see is an implimentation of AMD's "Turbo Core" on their dual GPU solutions. What this would mean for cards like Antilles is that on games that can use more than one GPU, the chips would clock down slightly and run in Crossfire configuration. However, in games that DON'T have a Crossfire profile or aren't optimized to run on multi-GPU solutions, one of the cores would overclock to the full speed of a Cayman XT card and run on only one GPU core while the other GPU core is essentially turned off.
    This would be an intelligent solution much like the Turbo-mode that intel implements on their i3/i5/i7 CPU's, only it would apply to GPU's. This would also allow them to intelligently keep Antilles within the 300 watt PCIe spec while in dual-GPU mode and it would allow the card to perform very well on games that only utilize one GPU. They've already got the technology implemented in their cards (notice the 17watts of power consumption at idle). Now they just need to expand upon it and add intelligent power gating to the mix. It could probably be done via software.
    That would be a win-win design. However, it's probably wishful thinking to hope for something like that.
    PII 965BE @ 3.8Ghz /|\ TRUE 120 w/ Scythe Gentle Typhoon 120mm fan /|\ XFX HD 5870 /|\ 4GB G.Skill 1600mhz DDR3 /|\ Gigabyte 790GPT-UD3H /|\ Two lovely 24" monitors (1920x1200) /|\ and a nice leather chair.
  24. #24
    Jan 2008
    In Cypress (and back to R600) there were 5 SPUs (Stream Processing Units) per SP (Streaming Processor).
    Like in the first image here: http://www.anandtech.com/show/2841/4
    Now there will be 4 SPUs per SP. And as ajaidev points out, there may be a different arrangement of simple and complex units within the SP instead of 4+1.
    If they keep a grouping of 16 SPs per SIMD, and there are 1920 SPUs, then Cayman will have 30 SIMDs per chip.
    The reason for such a change might be to increase utilization. It could have good results if one or two of the units in your 5 wide design are usually sitting idle. That's why RV770 and Evergreen had such a huge difference between low utilization (games) and high utilization (furmark) in terms of power-draw and heat output.
    They have had a 5-wide design for a while now. Why assume that's never going to change? Especially on a generational change?
  25. #25
    Jun 2007
    Thessaloniki, Greece
    If it is indeed a 4 port VLIW architecture this will be very expensive for AMD as i speculate they will have to recoup the R&D costs for moving the SI design from it's initial 28nm target to 40nm using just one derivative. This of course will allow them to finalize the design on a well known process before they move it to the murky waters of 28nm and therefore lower risk. I suspect we will see a 5770 replacement as a 28nm test vehicle as soon as the process is ready for production.
    Seems we made our greatest error when we named it at the start
    for though we called it "Human Nature" - it was cancer of the heart
    CPU: AMD X3 720BE@ 3,4Ghz
    Cooler: Xigmatek S1283(Terrible mounting system for AM2/3)
    Motherboard: Gigabyte 790FXT-UD5P(F4) RAM: 2x 2GB OCZ DDR3 1600Mhz Gold 8-8-8-24
    GPU:HD5850 1GB
    PSU: Seasonic M12D 750W Case: Coolermaster HAF932(aka Dusty )
