Page 13 of 349 FirstFirst ... 3101112131415162363113 ... LastLast
Results 301 to 325 of 8711
Thread: The Maximus Formula Thread - Help/OCing/Guide/Rampage conversion
  1. #301
    Dec 2007
    My CPU temps are 20C+ below actual, but the core temps seem to be accurate with the 0709 bios.
    I have needed the following settings to get 3.6GHz, 1800MHz FSB and 1200MHz ram. Is the reason I need 1.63v's on the Northbridge due to my FSB and ram speed? Seems like my v settings on the NB are the highest?
    Orthos running just to show temps under load:
    [IMG]http://[/IMG]
    This is on air
    [IMG]http://[/IMG]
  2. #302
    Oct 2006
    AU
    Quote Originally Posted by kup View Post
    How strange!
    I'll leave it as is in the first post until I get a few more people report the same thing.
    I'd go straight to bios 0903 as it does seem to be best for the majority of users now.
    My non SE is REV 1.02G as well.
  3. #303
    The Doctor Warboy's Avatar
    Oct 2006
    Kansas City, MO
    Quote Originally Posted by BulldogPO View Post
    Weird thing hapened yesterday, I upgraded latest forcewares to my 64bit Vista, and shutdown took forever.
    Than it did not boot at all and no picture on screen, I tought what the hell.
    I did CLR CMOS atleast 4 times and no difference.
    Tried other GFX card, no difference.
    LCD Poster showed that DET DRAM all the time.
    Then I removed RAMīs, no differecne.
    Then I tried those OCZ momory modules one by one, and one bootted fine.
    Then I tried other and same thing GFX cards fan blowed 100% and no picture on screen.
    I thought that other memory died.
    But after few hours I tried them again both installed and everuthing worked fine.
    I just dont understand what caused this and why?
    I also lost photos from 4GB PNY SD card that was in USB card reader.
    I also had that problem when I upgraded to 169.28 a few hours ago, It wouldn't post and I was so close to using my P5K, I had my maximus on a box testing it and it finally worked, so I cleaned up my chassis and then put it back in, Now I got a 5% better air flow because of the cleanup i did.
    My Rig can do EpicFLOPs, Can yours?
    Once this baby hits 88 TeraFLOPs, You're going to see some serious $@#%....
    Build XT7 is currently active.
    Current OS Systems: Windows 10 64bit
  4. #304
    Feb 2004
    Denmark
    Quote Originally Posted by Leeghoofd View Post
    Seems reservoir to pump tubing is kinked
    Gonna try to build a loop in my Antec P160 next week with only Nb and CPU in the loop with 2 rads ( one 120mm and a dual 120mm )
    Keep you guys posted
    here you can see my old antec p160 H2O rig.
    http://www.tweak.dk/newtweak/casemod.php?caseid=114
    i relly mis that rig .
    *Asus Maximus Formula SE*Intel q6600*PowerColor HD 3870*Corsair Crucial 4x1 GB 6400*
    *WD Raptor 2x 74gb raid 0*Creative X-FI XM*Samsung DVD*Antec p182*
    *H2O cooling on CPU and VGA*
  5. #305
    HWGurus
    Mar 2006
    Could somebody post some chipset temp on default and let say on 400 fsb...And what is max fsb you can achieve
  6. #306
    Nov 2007
    Hello!
    Would somebode tell me BIOS settings for 0907, I would like to get 450x8, I copied some settings from this forums, but they didnt worked for me. When I tried to boot from 450x8 to windows poster wrote "DET DRAM". It works fine with 400x8 but that isnt enough for me =)
    My rig:
    Q6600 (1.25 VID) G0-stepping
    ASUS Maximus formula SE
    Transcend aXeram 1066mhz
    EDIT: Okay it works now with 9x400 FSB, I'll drive prime95 now.
    EDIT2: D'oh Fatal error, I'll go check volts
    EDIT3: I raised CPU volts, Self test 768k begins now.
  7. #307
    Banned
    Nov 2007
    Quote Originally Posted by Azz View Post
    Hello!
    My rig:
    if you get the "det ram" hang try changing the transaction booster,
    425x8 I set it to enabled /level 0 but if I set 450x8 and leave it like that I get the same problem. "det ram"
    450x8 transaction booster set to auto and I boot just fine
    It dosent hurt ram speed any or anything you can notice anyways
    425x8 @1133MHZ /400 strap
    Read = 9500 : Write = 7740 : Copy = 8308 : Latency = 52.1ns
    450x8 @1080MHZ /333 strap
    Read = 9587 : Write = 8207 : Copy = 8642 : Latency = 52.0ns
  8. #308
    Nov 2007
    Quote Originally Posted by Grnfinger View Post
    Okay I'll try, I got it now at 9x400, It gives error usually at 896k. 9x seems not like to be stable at lower volts (1.375v - 1.4v) I'll drive 3Dmark06 now.
  9. #309
    I am Xtreme
    Jul 2005
    photos of the Formula vs the Extreme
    [SIGPIC][/SIGPIC]
  10. #310
    Dec 2007
    beyond good and evil
    Quote Originally Posted by quake6 View Post
    my temps when idle (default) NB 40 C
    SB 35 C
    MB 32 C
    CPU 20 C
    Bios version 0903
  11. #311
    May 2007
    Oke some quick Questions before I start to setup this board along with a Q6600. What ram should I use for the sake of ease for starters on this new board: 2x1GB Ballistix PC8500 tracers, or the 2x2GB G.Skill PQ8000. The ballistix I used for my P5K deluxe , was running a nice 1200mhz 5-5-5-12 @ 2.05v. The G.Skill I didnt test it yet it is still new in the package, along with a new Q6600. So I try to run 400x9 at first. What Bios are u guys suggesting? 0903/ 0907? Thanks!
    • DFI Lanparty LT X48-T2R
    • Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
    • eVGA 8800GTS (G92) 512MB {stock}
    • Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
    • Lian Li PC-V1000 {modded}
    • Corsair HX 620W
    • Creative X-FI ExtremeMusic
    • Western Digital Raptor X 150GB
    • Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
  12. #312
    HWGurus
    Mar 2006
    Quote Originally Posted by Notechis View Post
    SB 35 C
    MB 32 C
    CPU 20 C
    Bios version 0903
    Maybe load?
  13. #313
    Jul 2005
    I've hit a wall and have no idea why
    Extreme Tweaker
    Ai Overclock Tuner : Manual
    OC From CPU Level Up : AUTO
    CPU Ratio Control : 8.0
    - Ratio CMOS Setting : Manual 8x
    FSB Frequency : 443
    FSB Strap to North Bridge : 400
    PCI-E Frequency: 110
    DRAM Frequency: DDR2-1173
    DRAM Command Rate : 2T
    DRAM Timing Control: Manual
    CAS# Latency : 5
    RAS# to CAS# Delay : 5
    RAS# Precharge : 5
    RAS# ActivateTime : 15
    RAS# to RAS# Delay : AUTO
    Row Refresh Cycle Time : AUTO
    Write Recovery Time : AUTO
    Read to Precharge Time : AUTO
    Read to Write Delay (S/D) : AUTO
    Write to Read Delay (S) : AUTO
    Write to Read Delay (D) : AUTO
    Read to Read Delay (S) : AUTO
    Read to Read Delay (D) : AUTO
    Write to Write Delay (S) : AUTO
    Write to Write Delay (D) : AUTO
    DRAM Static Read Control: DISABLED
    Ai Clock Twister : STRONG
    Transaction Booster : DISABLED RELAX 0
    CPU Voltage : 1.475
    CPU PLL Voltage : AUTO
    North Bridge Voltage : 1.54
    DRAM Voltage : 2.14
    FSB Termination Voltage : 1.54
    South Bridge Voltage : AUTO
    Loadline Calibration : ENABLED
    CPU GTL Reference : .63X
    North Bridge GTL Reference : .67X
    DDR2 Channel B REF Voltage : AITP
    DDR2 Controller REF Voltage : DDR2_REF
    SB 1.5V Voltage : AUTO
    NB LED Selection : NB Volt
    SB LED Selection : SB Volt
    CPU LED Selection : CPU VOlt
    Voltiminder LED :
    Advanced CPU Configuration
    CPU Ratio Control : Manual
    - Ratio CMOS Setting : 8
    C1E Suppport : Disabled
    CPU TM Function : Disabled
    Vanderpool Technology : Disabled
    Execute Disable Bit : Disabled
    Max CPUID Value Limit : Disabled
    USB Configuration
    USB Functions: Enabled
    Legacy USB Support : Disabled
    I've tried bumping the voltage up on the cpu, memory, NB, SB cpu PLL etc etc and I can not get past 443FSB. My temps only hit 48 on the core's and the cpu temp around 20 with prime going. If I try 450FSB my system wont even post. Any ideas on what I can try, with my temps being this low I wouldnt mind trying to hit 500x7.
    E6750 @ 3.4GHZ (425FSB) @ 1.44V - Asus Rampage Formula (conversion) Bios 0403 - 2X2GB Corsair Dominator (CM2X2048-8500C5D) @ 566mhz @ PL 6 2.18V 5-5-5-18 - EVGA 8800GTS 640MB SSC - 1X WD RAPTOR 150 - 1X WD RAPTOR 74GB - LOGITECH Z5500S - ACER P221W
  14. #314
    Banned
    Nov 2007
    I'm still testing this setup 9 hours on prime no errors yet
    so try this for 450x8
    Extreme Tweaker
    FSB Frequency : 450
    FSB Strap to North Bridge : 333MHZ
    DRAM Frequency: DDR2-1080
    CAS# Latency : 5
    RAS# Precharge : 5
    Ai Clock Twister : Strong
    Transaction Booster : Disabled
    -Boost Level 0
    CPU Voltage : 1.525 ( you may need to adjust)
    CPU PLL Voltage : AUTO ( yes damit AUTO!) ( dont argue with what works )
    North Bridge Voltage : 1.6.1 ( will lower after prime test passes)
    DRAM Voltage : 2.0
    South Bridge Voltage : 1.050
    CPU GTL Reference : 0.63x
    North Bridge GTL Reference : 0.67x
    DDR2 Controller REF Voltage : DDR2-REFF
    SB 1.5V Voltage : 1.5
    Voltiminder LED : Enabled
    USB Configuration
    Legacy USB Support : Enabled
  15. #315
    Feb 2004
    Denmark
    i have a stupid problem
    if i use a dual core cpu i hit fsb wall ad 460 mhz
    if i use a quad core i hit fsb wall ad 430 mhz.
  16. #316
    Banned
    Nov 2007
    Maybe load?
    here are NB and SB under full load for 30 mins
  17. #317
    Dec 2007
    UK
    Hi guys, this is my first post here. Normally spend my time on a less extreme OCing board . Have been lurking around the Maxumus threads for a while, learning about OCing the Maximus Formula. Finally got a really decent stable clock so i thought I'd give something back by posting my BIOS setting. I know I got lucky with the CPU but the setting may help.
    Specs:
    CPU: Q6600
    Revison: G0
    FPO: L745A817
    Clockspeed: 4095 Mhz
    Vcore (under load in windows): 1.544v (1.5500 BIOS)
    Vid (core temp): 1.2000v
    Motherboard: Asus Maximus Formula Non SE
    Cooling: Custom water
    Thermal paste used: Artic Silver 5
    CPU Temp: 77/77/68/71 - I need a new rad, + the IHS probably needs lapping, Core#3 is always much lower than the rest.
    BIOS 903
    Extreme Tweaker
    - Ratio CMOS Setting : 9
    FSB Frequency : 455
    PCI-E Frequency: 100
    DRAM Frequency: DDR2- Auto
    CAS# Latency : 4
    RAS# to CAS# Delay : 4
    RAS# Precharge : 4
    RAS# ActivateTime : 12
    RAS# to RAS# Delay : Auto
    Row Refresh Cycle Time : 42
    Write Recovery Time : Auto
    Read to Precharge Time : Auto
    Read to Write Delay (S/D) : Auto
    Write to Read Delay (S) : Auto
    Write to Read Delay (D) : Auto
    Read to Read Delay (S) : Auto
    Read to Read Delay (D) : Auto
    Write to Write Delay (S) : Auto
    Write to Write Delay (D) : Auto
    DRAM Static Read Control: disabled
    Transaction Booster : disabled
    (voltage are actual)
    CPU Voltage : 1.55v
    CPU PLL Voltage : 1.70v
    North Bridge Voltage : 1.67v
    DRAM Voltage : 2.12v
    FSB Termination Voltage :1.6v
    CPU GTL Reference : Auto
    North Bridge GTL Reference : Auto
    DDR2 Channel A REF Voltage : ddr2_ref
    DDR2 Channel B REF Voltage : ddr2_ref
    DDR2 Controller REF Voltage : ddr2_ref
    SB 1.5V Voltage : auto
    Voltiminder LED :
    CPUZ http://valid.x86-secret.com/show_oc.php?id=286539
    Asus Maximus Formulae x38, D-Tek FuZion CPU & XSPX H2O NB blocks, Q6600 'G0' @ 4095 MHz (455x9) Prime Stable, @3825 MHz (425x9)- Everyday, 4Gb Balistix PC8500 @ 1:1, BFG watercooled 8800GTX, Seagate 7200.11 500Gb, Galaxy 850w, Del 2407, Alphacool Ext Display,Silverstone TJ07 http://i136.photobucket.com/albums/q...ers/4095-4.jpg http://valid.x86-secret.com/show_oc.php?id=286539 .
  18. #318
    Dec 2007
    UK
    Quote Originally Posted by X.T.R.E.M.E_ICE View Post
    Same here, Non SE REV 1.02G
  19. #319
    Dec 2005
    Cinci OH
    Anyone know were there is a listing of *stock* volts for NB, SB, etc on this board? Just because it runs at x on auto, doesn't mean that's stock. Just wondering where the "safe" range is for each. Anandtech partially discusses some of these in the link in the OP.
    Intel i7 3770k
    ASUS Z87-Pro
    Corsair Vengeance 4x 4GB
    Corsair 1000HX
    ASUS GTX 780
    Samsung 840 EVO 500GB SSD
    Corsair H100i H20 Cooling
    SB X-Fi Titanium Fatal1ty
  20. #320
    HWGurus
    Mar 2006
    @grnfinger:Thank you very much
    Is this mbo capable for let say 550mhz fsb with dual core?
  21. #321
    Dec 2007
    what is the max temp for NB and SB ? 24/7 use.
    one more thing:
    with this settings i run orthos blend in 10h and past also memtest.
    but the computer stop responding sometimes for a few seconds. sometimes
    someone who have some idea to dissolve this problem ?
    BIOS 0903
    Extreme Tweaker
    FSB Frequency :356
    FSB Strap to North Bridge :333
    DRAM Frequency: DDR2-1140
    CAS# Latency : 5
    RAS# Precharge : 5
    Row Refresh Cycle Time : Auto
    DRAM Static Read Control: Disable
    Ai Clock Twister : Auto
    Transaction Booster : AUTO
    CPU Voltage : 1.4250v
    CPU PLL Voltage : 1.52v
    North Bridge Voltage : 1.36v
    DRAM Voltage : 2.24v
    FSB Termination Voltage : 1.36v
    South Bridge Voltage : 1.05v
    DDR2 Controller REF Voltage : 0 mV
    SB 1.5V Voltage : 1.5v
    Voltiminder LED : ENABLED
    Asus Maximus Rampage Formula non-SE rev. 1.03g (bios 219)
    E6600 7638A761 Cooler: Noctua UH-12
    4x1GB Crucial Ballistix PC8500 (5-5-5-15)
    HIS Radeon 3870 IceQ 3 512 MB
    1x500 GB Seagate.10
    2x500 GB WD
    1X320 GB Seagate.10
    Creative X-FI XtremeGamer
    Crosair HX 620
    LG 204 (1680x1050)
    Logitech MX518
    Lian-Li V1000 Plus 2
  22. #322
    Jan 2007
    Los Angeles, CA
    So guys, I just got my Maximus today, got it installed and am working on my OS right now...
    No overclocking, just stock and my NB temps are at 42-45 idle... this seems a bit high. Any advice on how to drop this? I'm in a case w/great airflow, so short of hard mounting a fan on the NB (no idea how I'd do that) I'm at a loss.
    what to do???
    2600k @ 5ghz / z68 Pro / 8gb Ripjaws X / GTX 580 SLi
    2x Inferno raid 0 / WD 1TB Black / Thermaltake 1200w
    Dell 3008 WFP / Dual Loop WC MM UFO
  23. #323
    Banned
    Nov 2007
    Quote Originally Posted by sonofander View Post
    what to do???
    I reseated my fuzion block with AS5 and temps droped 5 -7 celcius
    I'm on water and full load the NB hits 45 celcius
  24. #324
    Banned
    Nov 2007
    Quote Originally Posted by Exentler View Post
    one more thing:
    BIOS 0903
    Extreme Tweaker
    FSB Frequency :356
    CAS# Latency : 5
    RAS# Precharge : 5
    Not sure if this is your issue but check this out, it might help you.
    http://downloadcenter.intel.com/filt...4&submit=Go%21
    devilhood had this issue I think and the dl resovled it for him
    http://www.xtremesystems.org/forums/...160945&page=88
    he talks about it here and a few pages back
  25. #325
    Feb 2004
    Denmark
    can anyone help me get over my fsb ?
