Page 1 of 4 1234 LastLast
Results 1 to 25 of 78
Thread: "OCZ RevoDrive looks to shake up SDD market"
    Jan 2008
    Puerto Rico
    OCZ has introduced the RevoDrive; a new take on the not so humble SSD. The RevoDrive - due for release sometime in July - is essentially a pair of Sandforce equipped SSDs mounted to a PCB in a RAID array. The PCB uses a 4x PCI-E interface which OCZ claims allows the RevoDrive to "move beyond the bottleneck of SATA II".
    Claimed speeds are similarly dramatic with read speeds of up to 540MB/s and write speeds of upto 480MB/s - more than double what we saw in our recent SSD group test.
    You'd think all this performance would come with a hefty price tag, but OCZ has done a good job of keeping the price down with the 120GB RevoDrive costing £335 - only £25 more than the same capacity Vertex 2
    The drive also comes in a 240GB flavour which is priced at a rather more wallet melting £600, but again is within touching distance of the same size Vertex drive.
    OCZ even has the ability to increase performance in the future if needs be as the PCI-E to SATA controller chip used actually has the ability to handle four 3Gbps drives; leading to a 4-way RAID array. This will of course increase the price again as each individual drive still requires its own controller chip but we cant help drooling at the possible speeds available if OCZ ever develops a four drive version.
    Granted, you could buy two smaller SSDs and set them up in RAID yourself and end up with largely similar performance but the RevoDrive offers a more simple option and a truck load of bragging rights to boot. It also frees up two internal hard disk bays, which could be a key motivation for anyone looking to mod a case extensively.
    Source: Bit-Tech
    Apr 2007
    It's bootable.
    With those write speeds, that price, and bootable, OCZ can put me down for one.
    Mar 2005
    Trinidad and Tobago
    looks damn good
    i can imagine the price
    Rig 1 Asus ROG Strix B550-F WiFi, R7 5800x, 64GB Vengeance LPX 4*16GB, Zotac GTX 1070Ti, X-Fi Titanium, Enermax Revolution D.F. 850w, SSDs 768GB, HDD 3TB, CM 912HAF, NH D-15 Black.cr
    Rig 2 Asus Maximus VI Hero, i7 4770K@4000, 32GB Ballistix VLP 4*8GB, Gigabyte GTX 970, eVGA G3 850, SSD 512GB, HDD 2TB, TT Element-T, NH D-14.
    Jul 2006
    Montreal, QC
    It uses 2 SandForce SF-1600 controllers in AID-0
    Anand has a preview over this:
    http://www.anandtech.com/show/3788/o...dable-pcie-ssd
    Seems like it doesn't quite hit the advertised speed (but it's still f* awes0me). And there is no TRIM support (yet). It really could become quite an attractive piece of hardware if they can keep the cost down and add TRIM support.
    Jan 2008
    Puerto Rico
    Quote Originally Posted by BigDisk View Post
    although does others OCZ sandforce drives support TRIM correct? (Vertex 2 & Agility 2)
    Mar 2005
    Quote Originally Posted by Blacky View Post
    no trim on this guy or garbage collection. The article claims its a sata to pci-e controller, but in reality it's a pci-e to pci-x converter and the raid controller is pci-x not PCI-E. Also its the SF-1200 controller not SF-1600
    my info is from: http://www.anandtech.com/show/3788/o...dable-pcie-ssd
    Quote Originally Posted by Manicdan View Post
    real men like the idea of packing lots of stuff into a very small space, which is what the mac mini is
    Quote Originally Posted by Baron_Davis View Post
    PS. I'm even tougher IRL.
    Xtreme X.I.P.
    Apr 2005
    Yes. So far TRIM is not supported on RAIDed drives.
    Jan 2007
    ...i dont get it...why should people prefer these instead of a "normal" SSD
    ...its not like people have space to waste in their cases...with all the double slot cooler gfx cards,cable management,air flow...etc
    im very,very happy that every good motherboard these days comes with the ethernet chip integrated so we dont have to have a separate pcie card for the internet connection
    ...dunno maybe server farms or such...
    "Generally speaking, CMOS power consumption is the result of charging and discharging gate capacitors. The charge required to fully charge the gate grows with the voltage; charge times frequency is current. Voltage times current is power. So, as you raise the voltage, the current consumption grows linearly, and the power consumption quadratically, at a fixed frequency. Once you reach the frequency limit of the chip without raising the voltage, further frequency increases are normally proportional to voltage. In other words, once you have to start raising the voltage, power consumption tends to rise with the cube of frequency."
    1st
    CPU - 2600K(4.4ghz)/Mobo - AsusEvo/RAM - 8GB1866mhz/Cooler - VX/Gfx - Radeon 6950/PSU - EnermaxModu87+700W
    2nd
    TRUltra-120Xtreme /// EnermaxModu82+(625w) /// abitIP35pro/// YorkfieldQ9650-->3906mhz(1.28V) /// 640AAKS & samsung F1 1T &samsung F1640gb&F1 RAID 1T /// 4gigs of RAM-->520mhz /// radeon 4850(700mhz)-->TRHR-03 GT
    3rd
    Windsor4200(11x246-->2706mhz-->1.52v) : Zalman9500 : M2N32-SLI Deluxe : 2GB ddr2 SuperTalent-->451mhz : seagate 7200.10 320GB :7900GT(530/700) : Tagan530w
    I am Xtreme
    Dec 2007
    i think this takes up more space than 2 SSDs.
    why not do the same exact thing, but make it SATA6gbs, and 3.5" that would shake up the SSD industry too. and fit better too, since most oem machines use mini atx, and dont have that many expansion slots, but almost always have 4-6 HDD racks.
    Dec 2004
    United Kingdom, South East England Kent
    mhmm, people who'd want this likely have SLI and won't be able to fit this in lol. But at least they'll have an super extended ATX sized case with empty drive bays.
    Sep 2007
    can it boot off the pci-e drive?
    Apr 2007
    Quote Originally Posted by geo View Post
    Yes.
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    The way this thing looks reminds me of those ginormous cache cards of yesterdecade. The hallmark of any still-forming technology is a vast array of some type of chips. In ten years you'll look back and laugh at how this card looks. heh
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Xtreme Cruncher
    Jul 2007
    @ the computer
    does this have any real advantage over 2 sandforce drives in RAID0? looks almost the same to me, except the interface. i prefer to plug drives in two SATA slots rather than take up a pci-e slot.
    [SIGPIC][/SIGPIC]
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Renton WA, USA
    i want mobo companies to put like 30gb superfast SSD on the mainboard for boot drive
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    Someone let me know when SSD;s are $1/GB and arent so high maintence
    Mar 2008
    川崎市
    Quote Originally Posted by slaveondope View Post
    1$ per GB won't happen for a while, but high maintenance? there is absolutely no maintenance involved as long as you get one with Trim and stay away from Raid.
  18. #18
    Aug 2006
    Hold on to your hats, this summer OCZ is going to set the world alight with the new OCZ RevoDrive. It's two ssds smacked together and takes up one of your pci slots. Is it faster than 2 raided ssds... no. Is it cheaper than 2 raided ssds... no. What's the point... it's got a swanky name and saves clutter from building up in your hard drive bay. Ok goodbye...
  19. #19
    Mar 2005
    Quote Originally Posted by NKrader View Post
    One of ocz pci-e SSD's has what looks like laptop memory dimms, except they are MLC flash. Now imagine if the motherboards came with 1-3 slots that supported such dimms so we could maybe add our own 30-60gb of solid state storage on the motherboard.
  20. #20
    Banned
    Nov 2005
    Acreageville, Alberta
    Quote Originally Posted by tdream View Post
    QFT. If anything wait for the Sandforce SATA6 Gbps interface to lose SATAII bottleneck and not lose a PCI-E slot. Or get a Crucial C300 RAID 0 and be faster....
  21. #21
    Jan 2007
    Over the mountains and down in the valley
    All of those chips make me wonder about latency.
    using a OCed quad for torrenting is like robbing your local video store with a rocket launcher.
  22. #22
    Jul 2006
    i think the major benefit of this is that its only supposed to be $20 more than a standard 120GB SSD, and yet offers improved performance over a single SSD.
  23. #23
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    if my agility indi drive were to be replaced or i got a new ssd i think that i would definantly try to rma for one of thees or pick one up. it would be so nice to use more than 1 of the 4 slots on my board and it would get my ssd some ware reasonable as now i have it sitting on top of my dvd that is never used except for windows installs and the occasional dvd rip or burn, this would look awesome and it would be securly mounted (i have no HDD mounts i had to convert 5.25" as the HDD bays were replaced with rads in my p180.)
    just imagine how nice it would be for liquid remove all bays get one of thees, an estata storage and usb dvd
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
  24. #24
    Mar 2005
    North USA
    I can't believe how pedestrian this thread feels. Is nobody impressed by any effort to provide a definitively faster storage solution than otherwise available in the price bracket? Not very "xtreme"... you can wait for any period of time in this industry and get something faster for cheaper, but this is set to be available in a couple weeks.
    I think this looks promising; I'd love to get an update from OCZ as to the likelihood that a TRIM tool will/can be created.
    Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
    6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
    Sapphire 5870 @ 985/1245 1.2v
    X-Fi "Fatal1ty" & Klipsch ProMedia Ultra 5.1 Speaks/Beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
    WD 150GB Raptor (Games) & 2x WD 640GB (System)
    PC Power & Cooling 750w
    Homebrew watercooling on CPU and GPU
    and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
    Windows 7 Utimate x64
  25. #25
    Feb 2008
    America's Finest City
    Just curious, what's an SDD
    Quote Originally Posted by FUGGER View Post
    I am magical.
