Do you want to join the club? Then make a post and follow the rules:
- You must have at least 2GB of memory installed in the system.
(Update: 31 Jan, 2010) 3GB+ for: Core i5 7xx, Core i7 8xx, Core i7 9xx; 4GB+ for: Core i5 2xxx, Core i7 2xxx.- Screenshot must show a CPU-Z window with 4.5GHz+ frequency.
(Update: 3 Jan, 2011) Sandy Bridge owners - please only post 5GHz+ submissions. I am keen on preserving the challenge, so I will only add SB to the 5GHz club. Thank you for understanding.- Screenshot must show a LinX window (max memory settings, click "All" button or pick the last memory size option from the drop down menu, the "All" option is highly recommended) either running the 20th+ loop with no errors, or with 20+ successful passes.
(Update: 14 Dec, 2010) Please make sure that LinX is running / calculating (21st or higher number loop) when you're taking your screenshot (on at least one of your screenshots). You obviously want a CPU-Z window with 4.5GHz+ (5GHz+ for Sandy Bridge) frequency on the same screenshot, as well.
This rule will be enforced for all the new submissions.
Friendly reminder: use all the memory you've got. You don't need more than 1GB of memory for OS and applications. Enable Page File. Do a short LinX run to free up some RAM. I don't want to see 2GB LinX runs with 4GB of RAM installed any more.
Click here to download the latest version of LinX with updated Linpack libraries- List the motherboard you used.
- List the cooling you used (cooling type at least, such as: air / chilled air / water / chilled water / phase).
- List your full batch number (highly recommended, but not a must).
- Optionally, you could show us your voltages using a program coming with your motherboard, such as EasyTune, E-Leet, TurboV, etc.
(Update: 19 Feb, 2011) Concerning the AVX issue for Sandy Bridge:
According to the tests I've seen, Sandy Bridge at 5GHz+ frequency is able to output 100+ GFlops with AVX enabled with little effort.
To make sure that you have AVX used you need to do the following:
- install Windows 7 Service Pack 1;
- download and use the latest version of LinX (you can find the link above);
- either disable HT or tell LinX to run on 4 threads (for 4 core chips, etc.) if you have HT enabled (current Linpack is poorly optimized for Sandy Bridge [only] chips; telling it to run on the number of threads corresponding to the number of enabled physical cores doesn't just improve performance but also slightly increases stress levels).
(Update: 18 Apr, 2011) Run LinX on all the available threads (4 for HT off, 8 for HT on assuming all 4 cores are enabled) from now on. This is mandatory. It appears that the new Linpack libraries fix this bug.
Using AVX enabled LinX increases stress levels. To separate those using AVX from the rest, I am going to divide 5GHz Club into 2 categories: "Over 100 GFlops" and "Under 100 GFlops". This seems to be the only way of determining whether someone uses AVX or not for sure.
To make sure you get into "Over 100 GFlops" category, make sure that at least one of your loops has 100+ GFlops performance. Obviously, it has to be visible on the screenshot of your submission.
Also, please do not post images wider than 1280 pixels, use thumbnails / links if you have to. I strongly recommend cropping images instead of scaling them (stick to 100% scale). Thank you!
__________________
~ The list ~
5GHz Club <Over 100 GFlops> (Sandy Bridge and others)
Rank | User | Frequency and # cores + threads | vCore | Motherboard | Cooling type | Full Batch #
- newhit | Core i7 2600K [4C 4T] @ 5516.4MHz | 1.620 | Gigabyte P67A-UD7 | Single Stage | 3103B374
- lkozarov | Core i7 2500K [4C 4T] @ 5500.0MHz | 1.584 | ASUS P8P67 Pro | Single Stage | 3048A446
- newhit | Core i7 2600K [4C 4T] @ 5407.7MHz | 1.692 | Gigabyte P67A-UD7 | Water | L042B076
- TWK_OCZ | Core i7 2500K [4C 4T] @ 5341.9MHz | 1.608 | ASUS P8P67 Pro | Water | L051B314
- Bullu$ | Core i7 2600K [4C 8T] @ 5332.8MHz | 1.568 | ASUS Maximus IV Gene-Z | DICE | L039B470
- Yoshimura | Core i7 2600K [4C 4T] @ 5302.1MHz | 1.512 | Gigabyte P67A-UD4 | Water | L042B076
- Ace. | Core i7 2500K [4C 4T] @ 5300.0MHz | 1.568 | ASUS P8P67 WS | Water | L047B217
- aznsniper911 | Core i7 2600K [4C 8T] @ 5200.0MHz | 1.528 | ASUS P8P67 Pro | Water | 3103B307
- TWK_OCZ | Core i7 2500K [4C 4T] @ 5157.1MHz | 1.528 | ASUS P8P67 Pro | Water | L041C119
- lkozarov | Core i7 2600K [4C 4T] @ 5153.5MHz | 1.548 | Gigabyte P67A-UD4 | Single Stage | L045B005
- kitfit1 | Core i7 990X [6C 6T] @ 5102.7MHz | 1.682 | EVGA Classified E760 | Single Stage | 3044B119
- l0ud_sil3nc3 | Core i7 2500K [4C 4T] @ 5100.6MHz | 1.440 | ASUS Maximus IV Extreme | Water | 3102C246
- st0ned | Core i7 2600K [4C 4T] @ 5100.2MHz | 1.416 | ASUS Maximus IV Extreme | Water | L042B076
- dragonhunter | Core i7 2600K [4C 4T] @ 5100.0MHz | 1.488 | ASUS P8P67 Deluxe | Water | L042B243
- beast200 | Core i7 2500K [4C 4T] @ 5088.8MHz | 1.456 | Asrock P67 Extreme 6 | Water | L046B582
- AUGieDogie | Core i7 2600K [4C 4T] @ 5076.0MHz | 1.456 | ASUS P8P67 Evo | Air | L041C106
- crossg | Core i7 2600K [4C 4T] @ 5022.8MHz | 1.416 | ASUS P8P67 Deluxe | Air | L038A660
- Mysterfix | Core i7 2500K [4C 4T] @ 5007.1MHz | 1.440 | Asrock P67 Extreme 4 | Water | L042B291
- Oggodatank | Core i7 2600K [4C 8T] @ 5006.5MHz | 1.568 | Asrock P67 Extreme 4 | Water | 3049A287
- Dumo | Core i7 2600K [4C 8T] @ 5004.8MHz | 1.368 | Gigabyte P67A-UD7 | Single Stage | 3103B306
- Cy4n1d3 | Core i7 2500K [4C 4T] @ 5004.0MHz | 1.424 | Asrock P67 Extreme 4 | Air | L041B789
- needforspeed | Core i7 990X [6C 6T] @ 5002.9MHz | 1.640 | ASUS Rampage III Extreme | Water | 3045B094
- C-N | Core i7 2500K [4C 4T] @ 5001.5MHz | 1.368 | Gigabyte P67A-UD5 | Water | L050A864
- scum | Core i7 2600K [4C 8T] @ 5000.8MHz | 1.464 | ASUS Maximus IV Extreme-Z | Air | 3105C253
- vafan13 | Core i7 2600K [4C 4T] @ 5000.6MHz | 1.360 | Asrock P67 Extreme 6 | Air | 3101A112
- The Nemesis | Core i7 2600K [4C 8T] @ 5000.5MHz | 1.512 | ASUS Maximus IV Extreme | Water | 3103B306
- Gunslinger | Core i7 2600K [4C 8T] @ 5000.3MHz | 1.480 | ASUS Maximus IV Extreme | Water | 3103B373
- jeanjean15 | Core i7 2600K [4C 8T] @ 5000.2MHz | 1.480 | ASUS P8P67 Evo | Water | L039B461
- l0ud_sil3nc3 | Core i7 2600K [4C 8T] @ 5000.1MHz | 1.488 | ASUS P8P67 Pro | Water | L042B208
- deachus | Core i7 2600K [4C 8T] @ 4999.9MHz | 1.456 | ASUS Maximus IV Extreme | Water | L042B243
__________________
5GHz Club <Under 100 GFlops> (Sandy Bridge and others)
- LASeR10 | Core i5 2500K [4C 4T] @ 5508.2MHz | 1.600 | ASUS Maximus IV Gene-Z | Single Stage | L051B314
- :banana::banana::banana::banana:_43 | Core i7 2500K [4C 4T] @ 5500.0MHz | 1.672 | ASUS P8P67 Pro | Water | L051B314
- TWK_OCZ | Core i7 2600K [4C 8T] @ 5304.4MHz | 1.584 | ASUS P8P67 Pro | Water | L108B128
- Ace. | Core i7 2500K [4C 4T] @ 5300.1MHz | 1.520 | ASUS P8P67 WS | Water | L050A863
- SBB | Core i7 2600K [4C 4T] @ 5254.6MHz | 1.512 | ASUS P8P67 Pro | Water | L040B165
- C-N | Core i7 2600K [4C 8T] @ 5202.0MHz | 1.512 | Gigabyte P67A-UD5 | Air | L040B307
- SteveRo | Core i5 655K [2C 2T] @ 5200.7MHz | 1.776 | Gigabyte H55N-USB3 | Cascade | L008B538
- SteveRo | Core i7 980X [6C 6T] @ 5200.2MHz | 1.728 | Gigabyte X58A-UD7 | Cascade | 3003B287
- Sauron_Vie | Core i7 2600K [4C 8T] @ 5200.1MHz | 1.568 | ASUS P8P67 Pro | Water | L039B470
- :banana::banana::banana::banana:_43 | Core i7 2600K [4C 8T] @ 5151.2MHz | 1.596 | Biostar TP67XE | Water | L042A969
- Daddyjaxx | Core i7 2600K [4C 8T] @ 5126.9MHz | 1.504 | ASUS P8P67 Deluxe | Water | L042B208
- Friday~13rd | Core i7 2500K [4C 4T] @ 5104.0MHz | 1.500 | Biostar TP67XE | Air | L041C119
- miahallen | Core i7 2600K (ES) [4C 8T] @ 5102.5MHz | 1.448 | ASUS Maximus IV Extreme | Air | ES
- miahallen | Core i5 670 [2C 2T] @ 5101.3MHz | 1.536 | Gigabyte H55N-USB3 | Water | L935B898
- Jor3lBR | C2D E8600 [2C] @ 5100.7MHz | 1.616 | ASUS Rampage Extreme | Phase | Q820A727
- coolhandluke41 | Core i7 2600K [4C 8T] @ 5100.2MHz | 1.480 | ASUS P8P67 Pro | Water | L040B671
- owikh84 | Core i7 2600K [4C 8T] @ 5100.2MHz | 1.536 | ASUS Maximus IV Extreme | Water | L048A937
- donmarkoni | Core i7 2600K [4C 8T] @ 5100.1MHz | 1.488 | ASUS P8P67 Pro | Chilled Air | L040B694
- skeyo | Core i7 2600K [4C 8T] @ 5088.7MHz | 1.428 | Gigabyte P67A-UD7 | Water | L038A660
- miahallen | Core i5 670 [2C 4T] @ 5050.5MHz | 1.536 | Gigabyte H55N-USB3 | Water | L935B898
- little_scrapper | Core i7 2500K [4C 4T] @ 5047.8MHz | 1.408 | ASUS P8P67 WS | Air | 3101A127
- twirlywhirly555 | Core i3 560 [2C 4T] @ 5025.6MHz | 1.520 | Gigabyte H55N-USB3 | Chilled Water | L013B634
- x-built-Stan | Core i7 980X [6C 12T] @ 5022.4MHz | 1.554 | ASUS Rampage III Extreme | Single Stage | 3032A343
- kazukun | Core i7 2600K [4C 8T] @ 5014.8MHz | 1.608 | Gigabyte Z68X-UD7 | Water | L102B549
- nijel | Core i7 2600K [4C 8T] @ 5011.6MHz | 1.404 | Gigabyte P67A-UD7 | Air | L041C108
- PolRoger | Core i7 2500K [4C 4T] @ 5006.9MHz | 1.336 | Asrock P67 Professional | Air | L041C123
- kitfit1 | Core i7 975 [4C 8T] @ 5004.2MHz | 1.552 | EVGA Classified E760 | Single Stage | -
- PolRoger | Core i7 2600K [4C 8T] @ 5002.8MHz | 1.416 | Biostar TP67XE | Air | L041C106
- the_real_7 | Core i7 2600K [4C 8T] @ 5001.8MHz | 1.391 | Gigabyte P67A-UD7 | Water | L040B705
- tnc99 | Core i7 2600K [4C 8T] @ 5001.7MHz | 1.452 | Gigabyte P67A-UD7 | Water | L041B213
- C-N | Core i7 2500K [4C 4T] @ 5001.5MHz | 1.445 | Gigabyte P67A-UD5 | Air | L041B517
- OC Nub | Core i5 660 [2C 2T] @ 5000.7MHz | 1.552 | Gigabyte P55A-UD6 | Water | L935B896
- KURTZ | Core i7 2600K (ES) [4C 8T] @ 5000.3MHz | 1.416 | ASUS P8P67 | Water | ES
- The Nemesis | Core i7 2600K [4C 8T] @ 5000.1MHz | 1.520 | Maximus IV Extreme | Water | L042B243
- famich | Core i7 2600K [4C 8T] @ 5000.1MHz | 1.448 | ASUS P8P67 Deluxe | Water | L041B213
- SimpleTECH | Core i7 2600k [4C 8T] @ 5000.0MHz | 1.440 | Asus P8P67 Pro | Water | L040B208
__________________
Core i7 (Gulftown & Westmere-EP, 32nm)
- newhit | Core i7 980X [6C 6T] @ 4918.0MHz | 1.623 | EVGA Classified E760 | Phase | 3003B287
- donmarkoni | Core i7 990X [6C 6T] @ 4903.1MHz | 1.554 | ASUS Rampage III Extreme | Water | 3026A486
- kone | Xeon DP (ES) [4C 8T] @ 4830.1MHz | 1.536 | Gigabyte X58A-UD7 | Water | ES
- crossg | Core i7 990X [6C 6T] @ 4828.8MHz | 1.456 | ASUS Rampage III Formula | Air | 3045A752
- wiener007 | Core i7 970 [6C 12T] @ 4812.9MHz | 1.515 | ASUS Rampage III Extreme | Water | 3009F989
- zinsco | Core i7 980X [6C 6T] @ 4812.8MHz | 1.594 | ASUS Rampage III Extreme | Water | 3005F801
- :banana::banana::banana::banana:_43 | Core i7 980X [6C 12T] @ 4770.9MHz | 1.594 | ASUS Rampage III Extreme | Water | 3044B034
- crossg | Core i7 980X [6C 6T] @ 4752.3MHz | 1.448 | ASUS Rampage III Formula | Air | 3045A708
- The Nemesis | Core i7 990X [6C 12T] @ 4747.2MHz | 1.462 | ASUS Rampage III Extreme Black Edition | Water | 3101A239
- peanutskeeter | Core i7 980X [6C 12T] @ 4739.7MHz | 1.587 | ASUS Rampage III Extreme | Phase | -
- wibujo | Core i7 980X [6C 6T] @ 4727.7MHz | 1.552 | Gigabyte X58A-UD9 | Water | 3020A431
- BobyTT | Core i7 980X [6C 12T] @ 4713.7MHz | 1.494 | EVGA Classified E759 | Water | 3003B320
- skuldarin | Core i7 980X [6C 6T] @ 4710.6MHz | 1.556 | ASUS Rampage III Extreme | Water | 3013A540
- Mydog | Core i7 980X [6C 12T] @ 4710.5MHz | 1.508 | ASUS Rampage II Extreme | Water | -
- monteboy | Core i7 980X [6C 6T] @ 4703.6MHz | 1.472 | Gigabyte X58A-UD9 | Single Stage | 3013Bxxx
- donmarkoni | Core i7 980X [6C 6T] @ 4703.0MHz | 1.475 | ASUS Rampage III Extreme | Chilled Water | 3013A472
- Gautam | Core i7 980X [6C 12T] @ 4700.6MHz | 1.456 | ASUS P6T Deluxe | Water | 3003B466
- dr_dx | Xeon W3680 [6C 6T] @ 4650.1MHz | 1.520 | Gigiabyte X58A-UD7 rev2 | Chilled Water | 3013A739
- wibujo | Core i7 980X [6C 6T] @ 4640.2MHz | 1.472 | Gigiabyte X58A-UD9 | Water | 3020A431
- Leeghoofd | Core i7 990X [6C 6T] @ 4636.8MHz | 1.440 | ASUS Rampage II Formula | Water | 3045A596
- XeL_NaGa | Core i7 980X [6C 12T] @ 4636.6MHz | 1.495 | ASUS Rampage II Extreme | Water | 3020A431
- LennyRhys | Core i7 970 [6C 6T] @ 4625.1MHz | 1.440 | ASUS P6X58D-E | Air | 3012B113
- The Nemesis | Core i7 980X [6C 12T] @ 4611.5MHz | 1.458 | EVGA Classified E760 | Water | 3006A442
- zoson | Core i7 970 [6C 6T] @ 4611.0MHz | 1.521 | ASUS Rampage III Extreme | Water | 3018A860
- Alka Holic | Core i7 980X [6C 12T] @ 4610.7MHz | 1.349 | ASUS Rampage III Extreme | Water | 3035B799
- ac001 | Core i7 990X [6C 6T] @ 4605.0MHz | 1.468 | ASUS Rampage III Black Edition | Water | -
- CobraXP | Core i7 990X (ES) [6C 12T] @ 4604.1MHz | 1.440 | Foxconn BloodRage | Water | ES
- kill_a_wat | Core i7 980X [6C 12T] @ 4603.8MHz | 1.448 | ASUS Rampage III Extreme | Water | 3003B242
- mitmot | Core i7 980X [6C 12T] @ 4600.4MHz | 1.472 | ASUS P6T Deluxe V2 | Water | 3003A957
- med1kl | Core i7 980X [6C 6T] @ 4600.4MHz | 1.496 | ASUS P6T Deluxe V2 | Water | -
- Krautmaster | Core i7 990X [6C 12T] @ 4600.1MHz | 1.440 | DFI LP UT X58-T3E8H | Water | -
- Hornetcup | Core i7 980X [6C 12T] @ 4567.6MHz | 1.468 | ASUS Rampage III Extreme | Water | 3013A531
- justin.kerr | Core i7 980X [6C 12T] @ 4565.8MHz | 1.446 | EVGA Classified E760 | Water | -
- kazukun | Core i7 980X [6C 12T] @ 4563.9MHz | 1.435 | EVGA Classified E760 | Water | 3003B396
- Shadow0001 | Core i7 980X [6C 12T] @ 4560.4MHz | 1.504 | Gigiabyte X58-UD5 | Water | -
- Salamndar | Core i7 980X [6C 12T] @ 4546.2MHz | 1.446 | EVGA Classified E760 | Water | 3013A525
- crossg | Core i7 980X [6C 12T] @ 4537.9MHz | 1.448 | ASUS Rampage III Formula | Air | 3036C076
- thobel | Core i7 980X [6C 12T] @ 4536.8MHz | 1.475 | ASUS Rampage III Extreme | Water | -
- xpatar | Core i7 980X [6C 12T] @ 4530.5MHz | 1.408 | Gigabyte EX58-UD4P | Water | 3003B320
- McDown | Core i7 990X [6C 12T] @ 4525.4MHz | 1.389 | ASUS Rampage III Extreme | Water | 3045A643
- mbreslin | Core i7 980X [6C 12T] @ 4521.5MHz | 1.424 | Gigabyte X58A-UD7 | Water | 3003B396
- tomb18 | Core i7 980X [6C 12T] @ 4520.0MHz | 1.435 | ASUS Rampage III Extreme | Water | 3003B288
- JoeChuo | Xeon W3680 [6C 6T] @ 4518.8MHz | 1.435 | EVGA Classified E759 | Water | -
- Lu523 | Core i7 980X [6C 12T] @ 4515.0MHz | 1.423 | EVGA Classified E760 | Water | 3020A437
- owikh84 | Core i7 980X [6C 6T] @ 4514.0MHz | 1.399 | EVGA Classified E760 | Water | 3041A489
- zoson | Core i7 970 [6C 6T] @ 4512.7MHz | 1.515 | ASUS Rampage III Extreme | Water | 3016B246
- splmann | Core i7 980X [6C 12T] @4512.5MHz | 1.424 | ASUS Rampage III Extreme | Water | -
- Sanousie | Core i7 970 [6C 6T] @ 4512.5MHz | 1.520 | ASUS Rampage III Extreme | Water | -
- Olly_K | Core i7 980X [6C 12T] @4511.2MHz | 1.423 | EVGA Classified E762 | Water | 3003B396
- Shiranui Gen-An | Core i7 980X [6C 6T] @4511.0MHz | 1.435 | EVGA Classified E762 | Water | 3005F803T
- tompc3 | Core i7 980X [6C 6T] @ 4510.8MHz | 1.423 | EVGA Classified E770 | Air | 3032A340
- RRunner | Core i7 980X [6C 12T] @ 4510.5MHz | 1.376 | Gigabyte X58A-UD7 | Air | 3040B404
- tool_462 | Xeon DP (ES) [4C 8T] @ 4510.2MHz | 1.376 | Gigabyte EX58-UD5 | Water | ES
- sniper_sung | Core i7 980X [6C 6T] @ 4509.0MHz | 1.388 | EVGA Classified E760 | Air | 3013A524
- psygnosi | Core i7 980X [6C 12T] @ 4504.9MHz | 1.442 | ASUS Rampage II Extreme | Water | 3003B475
- CryptiK | Core i7 990X [6C 12T] @ 4504.8MHz | 1.336 | ASUS Rampage III Extreme | Water | -
- radaja | Core i7 970 [6C 12T] @ 4504.2MHz | 1.364 | EVGA Classified E760 | Water | 3012B129
- cq842000 | Core i7 980X [6C 12T] @ 4504.1MHz | 1.517 | EVGA Classified E762 | Water | 3020A477
- Decky | Core i7 970 [6C 12T] @ 4500.9MHz | 1.496 | ASUS P6X58D-E | Chilled Air | 3014B194
- _AntLionBR_ | Core i7 (ES) [6C 12T] @ 4500.5MHz | 1.392 | Gigabyte X58A-UD7 | Air | ES
- initialised | Core i7 (ES) [6C 12T] @ 4500.4MHz | 1.592 | ASUS P6T Deluxe V2 | Water | ES
- xarot | Core i7 980X [6C 6T] @ 4500.4MHz | 1.368 | ASUS P6T6 WS | Air | ES
- Leopold Butters | Core i7 970 [6C 12T] @ 4500.3MHz | 1.432 | ASUS P6X58D Deluxe | Water | 301B122
- RRunner | Core i7 980X [6C 12T] @ 4500.3MHz | 1.312 | Gigabyte X58A-UD7 | Water | 3041B300
- RRunner | Core i7 980X [6C 12T] @ 4500.2MHz | 1.392 | Gigabyte X58A-UD7 | Air | 3003B288
- angelreaper | Core i7 970 [6C 12T] @ 4500.2MHz | 1.376 | Gigabyte X58A-UD7 | Air | 3013A652
- fallwind | Core i7 980X [6C 6T] @ 4500.2MHz | 1.376 | Gigabyte EX58-DS4 | Water | 3003B331
- 00011011 | Core i7 980X [6C 6T] @ 4500.2MHz | 1.408 | ASUS P6X58D Premium | Water | 3003B288
__________________
Core i5 & i7 (Lynnfield, Bloomfield & Gainestown, 45nm)
Rank | User | Frequency and # cores, threads | vCore | Motherboard | Cooling type | Full Batch #
- zsamz_ | Core i7 920 [4C 4T] @ 4985.5MHz | 1.529 | EVGA Classified E760 | Phase | 3849B018
- lkozarov | Core i7 920 [4C 4T] @ 4855.5MHz | 1.360 | Foxconn Bloodrage GTI | Single Stage | 3918A495
- Sniper | Xeon W3520 [4C 4T] @ 4851.2MHz | 1.488 | Gigabyte X58-Extreme | Chilled Water | -
- OC Nub | Core i7 920 [4C 4T] @ 4828.4MHz | 1.600 | MSI Big Bang-XPower | Chilled Water | 3937B785
- Anth Seebel | Xeon W3520 [4C 4T] @ 4825.8MHz | 1.440 | ASUS P6T Deluxe V2 | Single Stage | 3845A935
- PiLsY | Core i7 950 [4C 4T] @ 4811.6MHz | 1.552 | Foxconn Bloodrage | Water | 3910A470
- lowfat | Core i7 920 [4C 8T] @ 4811.2MHz | 1.312 | EVGA Classified E760 | Single Stage | -
- zsamz_ | Core i7 920 [4C 4T] @ 4777.5MHz | 1.520 | ASUS Rampage II Extreme | Water | 3849B018
- Sniper | Core i7 920 [4C 4T] @ 4767.3MHz | 1.440 | Gigabyte EX58-Extreme | Water | 3848A352
- radaja | Core i7 920 [4C 4T] @ 4755.4MHz | 1.470 | EVGA Classified E760 | Water | 3849B018
- newhit | Core i7 950 [4C 4T] @ 4738.0MHz | 1.520 | Gigabyte X58A-UD7 | Water | -
- Romir | Core i7 920 [4C 4T] @ 4734.3MHz | 1.505 | EVGA Classified E760 | Chilled Water | 3849B018
- PiLsY | Core i5 750 [4C 4T] @ 4725.1MHz | 1.536 | Gigabyte P55-UD5 | Chilled Water | -
- justin.kerr | Core i7 920 [4C 4T] @ 4713.3MHz | 1.458 | EVGA Classified E760 | Water | -
- acebmxer | Core i7 920 [4C 4T] @ 4704.2MHz | 1.488 | Gigabyte EX58-UD5 | Water | 3927A440
- :banana::banana::banana::banana:_43 | Core i7 930 [4C 8T] @ 4693.7MHz | 1.606 | ASUS Rampage III Extreme | Water | 3005F577
- needforspeed | Xeon W3565 [4C 4T] @ 4681.2MHz | 1.475 | ASUS Rampage III Extreme | Water |3847A987
- Enzo78 | Core i7 920 [4C 4T] @ 4662.0MHz | 1.392 | Gigabyte EX58-Extreme | Water | 3912A859
- nickless | Xeon W3520 [4C 4T] @ 4651.5MHz | 1.422 | ASUS Rampage III Extreme | Water | 3845A935
- dejanh | Core i7 920 [4C 8T] @ 4650.5MHz | 1.611 | EVGA Classified E759 | Water | 3849A832
- Sniper | Core i7 920 [4C 8T] @ 4641.2MHz | 1.408 | Gigabyte EX58-Extreme | Water | 3848A352
- famish99 | Core i7 920 [4C 4T] @ 4630.4MHz | 1.512 | ASUS Rampage II Gene | Water | 3849A866
- johnksss | Core i7 920 [4C 8T] @ 4629.7MHz | 1.599 | EVGA Classified E760 | Water | -
- antiacid | Core i7 920 [4C 8T] @ 4620.2MHz | 1.408 | Gigabyte X58A-UD7 | Water | 3849B018
- LASeR10 | Core i7 930 [4C 4T] @ 4620.2MHz | 1.568 | Gigabyte X58A-UD7 | Water | -
- mattgmann | Core i7 920 [4C 8T] @ 4620.1MHz | 1.392 | Gigabyte EX58-UD5 | Water | 3849B018
- OC Nub | Core i7 930 [4C 4T] @ 4620.0MHz | 1.440 | Gigabyte X58A-UD7 | Water | 3004B176
- SimpleTECH | Xeon W3520 [4C 4T] @ 4620.0MHz | 1.328 | Gigabyte X58A-UD5 | Water | 3845A935
- owikh84 | Core i7 920 [4C 4T] @ 4608.4MHz | 1.423 | EVGA Classified E760 | Water | 3914A113
- shadewither | Core i7 920 [4C 8T] @ 4606.6MHz | 1.384 | ASUS Rampage III Extreme | Water | 3912A835
- playground | Core i7 920 [4C 4T] @ 4606.5MHz | 1.568 | ASUS Rampage III Extreme | Water | 3922A423
- zasadek | Core i7 930 [4C 4T] @ 4606.4MHz | 1.455 | ASUS Rampage III Extreme | Water | -
- rge | Core i7 950 [4C 8T] @ 4600.0MHz | 1.456 | Gigabyte EX58-Extreme | Water | 3847B005
- Bullu$ | Xeon W3540 [4C 8T] @ 4600.0MHz | 1.552 | Gigabyte X58A-UD7 v2 | Water | 3846B017
- ]siNNer[ | Core i7 920 [4C 4T] @ 4598.9MHz | 1.472 | Gigabyte X58A-UD3R | Air | 3945A927
- johnnymossville | Core i7 930 [4C 4T] @ 4573.7MHz | 1.488 | ASUS P6X58D Premium | Water | -
- uranium | Core i7 920 [4C 4T] @ 4566.5MHz | 1.458 | EVGA Classified E760 | Water | -
- Major | Core i7 920 [4C 8T] @ 4557.3MHz | 1.472 | Gigabyte X58A-UD5 | Water | -
- needforspeed | Core i7 920 [4C 4T] @ 4552.2MHz | 1.528 | ASUS P6X58D | Water | 3938B023
- SteveRo | Xeon W3520 [4C 4T] @ 4535.9MHz | 1.584 | Gigabyte X58A-UD7 | Water | -
- iTravis | Core i7 920 [4C 4T] @ 4524.9MHz | 1.541 | EVGA Classified E760 | Water | 3912B168
- kimandsally | Core i7 920 [4C 4T] @ 4524.8MHz | 1.388 | EVGA Classified E760 | Water | -
- cky2k6 | Core i7 920 [4C 8T] @ 4524.7MHz | 1.458 | EVGA Classified E760 | Water | 3946A169
- trn | Core i7 920 [4C 8T] @ 4524.7MHz | 1.482 | EVGA Classified E760 | Chilled Water | -
- cstkl1 | Core i7 920 [4C 4T] @ 4524.7MHz | 1.388 | EVGA Classified E760 | Water | 3847A765
- deachus | Core i7 920 [4C 4T] @ 4523.8MHz | 1.382 | ASUS Rampage III Extreme | Water | 3913A330
- AceBaran | Core i7 920 [4C 4T] @ 4523.6MHz | 1.462 | ASUS Rampage III Extreme | Water | -
- nickless | Xeon W3520 [4C 4T] @ 4523.5MHz | 1.521 | ASUS Rampage III Extreme | Water | 3919A657
- famich | Xeon W3520 [4C 8T] @ 4523.3MHz | 1.316 | ASUS Rampage III Extreme | Water | 3848A352
- maximus0206 | Core i7 920 [4C 4T] @ 4523.3MHz | 1.504 | ASUS Rampage II Gene | Water | 3844A716
- mattkosem | Core i7 920 [4C 4T] @ 4522.2MHz | 1.456 | EVGA Classified E760 | Water | 3849A895
- neonatas | Core i7 875K [4C 4T] @ 4521.3MHz | 1.440 | ASUS Maximus III Extreme | Water | L004B840
- SteveRo | Core i7 965 [4C 4T] @ 4521.1MHz | 1.568 | Gigabyte EX58-Extreme | Chilled Water | -
- kill_a_wat | Core i7 950 [4C 8T] @ 4519.9 | 1.336 | ASUS Rampage III Extreme | Water | -
- donmarkoni | Xeon W3540 [4C 4T] @ 4519.7 | 1.449 | ASUS Rampage III Extreme | Water | 3851A257
- wiener007 | Core i7 950 [4C 8T] @ 4519.7 | 1.303 | ASUS Rampage III Extreme | Water | 3849B099
- PolRoger | Xeon W3570 [4C 8T] @ 4519.6 | 1.312 | ASUS Rampage III Formula | Air | 3847A987
- PolRoger | Xeon W3540 [4C 4T] @ 4519.6 | 1.416 | ASUS Rampage III Formula | Air | 3845B010
- doz | Core i7 920 [4C 8T] @ 4517.0MHz | 1.418 | Intel DX58SO | Water | -
- sRHunt3r | Core i7 920 [4C 8T] @ 4515.2MHz | 1.360 | Gigabyte X58A-UD7 | Water | 3938b024
- radaja | Core i7 920 [4C 8T] @ 4515.0MHz | 1.376 | Gigabyte X58A-UD3R | Water | 3845B027
- beast200 | Core i7 920 [4C 4T] @ 4515.0MHz | 1.392 | Gigabyte EX58-UD5 | Water | -
- andressergio | Core i7 920 [4C 4T] @ 4515.0MHz | 1.472 | Gigabyte X58A-UD3R | Water | -
- siyah | Core i7 960 [4C 4T] @ 4515.0MHz | 1.392 | Gigabyte X58-UD5 | Water | 3901B769
- killerxp100 | Core i7 930 [4C 4T] @ 4514.9MHz | 1.424 | Gigabyte X58A-UD3R | Air | 3951B054
- angelreaper | Xeon W3520 [4C 8T] @ 4514.8MHz | 1.344 | Gigabyte X58A-UD7 | Air | 3845A935
- l0ud_sil3nc3 | Core i7 920 [4C 8T] @ 4514.7MHz | 1.424 | Gigabyte X58A-UD7 | Water | 3949A372
- OC Nub | Core i7 870 [4C 4T] @ 4512.0MHz | 1.408 | Gigabyte P55A-UD6 | Water | L926B294
- melnd | Core i7 920 [4C 4T] @ 4510.5MHz | 1.344 | ASUS P6T SE | Air | 3938B020
- imo | Core i7 920 [4C 4T] @ 4510.4MHz | 1.336 | ASUS P6T Deluxe | Air | 3849B056
- LostHawk | Core i7 920 [4C 4T] @ 4510.3MHz | 1.368 | ASUS P6T Deluxe v2 | Water | -
- vodka3dg | Xeon W3520 [4C 4T] @ 4510.3MHz | 1.472v | ASUS P6TD Deluxe | Water | -
- gregregg | Core i7 920 [4C 4T] @ 4510.3MHz | 1.392 | ASUS P6X58D-E | Water | 3913B007
- managerman | Core i7 920 [4C 8T] @ 4510.2MHz | 1.464 | ASUS P6T Deluxe V2 | Water | -
- C-N | Core i7 930 [4C 4T] @ 4510.2MHz | 1.504 | DFI LP UT X58-T3E8H | Air | 3951A722
- OC Nub | Core i7 950 [4C 4T] @ 4508.3MHz | 1.456 | MSI Big Bang-XPower | Water | 3002B430
- OC Nub | Xeon W3550 [4C 4T] @ 4508.1MHz | 1.464 | MSI Big Bang-XPower | Water | 3949B156
- sacoolza | Core i5 750 [4C 4T] @ 4507.8MHz | 1.592 | ASUS Maximus III Gene | Water | L006C024
- C-N | Core i7 950 [4C 4T] @ 4507.8MHz | 1.376 | Gigabyte X58-UD3R Rev 2 | Air | 3020A998
- Mobsters | Core i7 920 [4C 4T] @ 4507.8MHz | 1.517 | EVGA X58 SLI E758 | Water | 3931A219
- slaveondope | Core i7 920 [4C 8T] @ 4504.5MHz | 1.432 | ASUS Rampage II Gene | Water | 3938Bxx
- spoolindsm127 | Core i7 920 [4C 8T] @ 4504.5MHz | 1.396 | ASUS Rampage III Extreme | Water | 3949A372
- JoeBar | Core i7 920 [4C 4T] @ 4504.5MHz | 1.482 | ASUS Rampage II Extreme | Water | -
- CryptiK | Core i7 920 [4C 8T] @ 4504.4MHz | 1.320 | ASUS Rampage II Extreme | Water | 3849B018
- usz | Core i7 920 [4C 4T] @ 4504.3MHz | 1.416 | ASUS Rampage II Gene | Water | -
- xdave | Core i7 920 [4C 4T] @ 4504.0MHz | 1.388 | EVGA Classified E770 | Water | 3912A859
- Paradoxxx | Core i7 920 [4C 4T] @ 4503.9MHz | 1.435 | EVGA Classified E760 | Water | 3844A759
- The Nemesis | Core i7 920 [4C 8T] @ 4503.8MHz | 1.458 | EVGA Classified E760 | Water | 3849B028
- miahallen | Core i7 920 [4C 8T] @ 4503.7MHz | 1.505 | EVGA Classified E760 | Water | 3851A231
- mwlhr | Core i7 920 [4C 8T] @ 4503.6MHz | 1.470 | EVGA Classified E760 | Water | 3925A260
- kup | Core i7 920 [4C 8T] @ 4501.7MHz | 1.360 | ASUS P6X58D | Water | 3912B185
- PolRoger | Core i7 920 [4C 4T] @ 4501.7MHz | 1.329 | EVGA Classified E760 | Chilled Air | 3849B018
- Vinas | Core i7 860 [4C 4T] @ 4501.4MHz | 1.544 | Asus Maximus III Gene | Water | L925B479
__________________
Core i3 & i5 (Clarkdale, 32nm)
- tonzakung | Core i3 530 [2C 2T] @ 4950.3MHz | 1.680 | Gigabyte H55M-USB3 | Water | L001B346
- pet168 | Core i3 540 [2C 2T] @ 4937.1MHz | 1.544 | ASUS Maximus III Gene | Air | 3039B092
- OC Nub | Core i5 655K [2C 2T] @ 4900.5MHz | 1.584 | Gigabyte P55A-UD6 | Water | L008B538
- tonzakung | Core i3 530 [2C 4T] @ 4862.4MHz | 1.632 | Gigabyte H55M-USB3 | Water | L001B346
- l0ud_sil3nc3 | Core i5 650 [2C 4T] @ 4800.5MHz | 1.456 | Gigabyte H55N-USB3 | Air | 3942A600
- l0ud_sil3nc3 | Core i5 655K [2C 4T] @ 4727.2MHz | 1.488 | Gigabyte H55N-USB3 | Air | L009B514
- LASeR10 | Core i3 530 [2C 4T] @ 4725.6MHz | 1.568 | Gigabyte H55N-USB3 | Air | L004B690
- Ace. | Core i5 661 [2C 4T] @ 4701.1MHz | 1.399 | EVGA P55 SLI E655 | Water | L939B616
- charlie | Core i3 530 [2C 2T] @ 4625.9MHz | 1.416 | Biostar TH55B HD | Water | L939B
- OC Nub | Core i3 530 [2C 4T] @ 4620.4MHz | 1.424 | Gigabyte P55A-UD6 | Water | 3943A849
- Sommer | Core i5 650 [2C 4T] @ 4613.5MHz | 1.416 | ASUS P7H55D-M Evo | Air | L945B745
- SimpleTECH | Core i3 540 [2C 4T] @ 4611.6MHz | 1.400 | MSI P55-GD85 | Water | 3944B043
- eF_godlike | Core i3 540 [2C 4T] @ 4600.4MHz | 1.568 | Gigabyte H55M-D2H | Water | L028B490
- [XC] 4X4N | Core i3 540 [2C 4T] @ 4600.3MHz | 1.376 | Gigabyte P55-UD6 | Air | -
- PiLsY | Core i3 550 [2C 4T] @ 4598.3MHz | 1.552 | Gigabyte P55-UD5 | Air | -
- toptakachi | Core i3 530 [1C 2T] @ 4557.7MHz | 1.536 | Gigabyte H55M-S2H | Air | -
- gondezz | Core i3 530 [2C 4T] @ 4557.3MHz | 1.392 | Gigabyte H55N-USB3 | Air | L004C090
- PiLsY | Core i3 530 [2C 4T] @ 4522.9MHz | 1.456 | Gigabyte P55-UD5 | Air | -
- rlkd82 | Core i3 530 [2C 4T] @ 4509.9MHz | 1.470 | EVGA P55 FTW E657 | Air | 3001B039
- l0ud_sil3nc3 | Core i5 655K [2C 4T] @ 4509.4MHz | 1.376 | Gigabyte H55N-USB3 | Air | L008B537
- sniper_sung | Core i3 540 [2C 2T] @ 4508.5MHz | 1.408 | Gigabyte H55N-USB3 | Corsair H50 | L024B960
- 0Ro! | Core i5 661 [2C 4T] @ 4500.1MHz | 1.328 | Gigabyte P55A-UD6 | Air | L008B537
__________________
Core 2 Quad
Rank | User | Frequency and # of cores | vCore | Motherboard | Cooling type | Full Batch #
- OLDcomer | C2Q Q9650 [4C] @ 4707.1MHz | 1.424 | Gigabyte EP45-UDP | Water | L826B006
- Jor3lBR | C2Q Q9650 [4C] @ 4680.0MHz | 1.408 | Gigabyte EP45-Extreme | Water | -
- andressergio | Xeon X3380 [4C] @ 4500.2MHz | 1.376 | Gigabyte EP45T-USB3P | Water | L834B623
- Hoss331 | C2Q Q9650 [4C] @ 4500.0MHz | 1.344 | Gigabyte EP45T-UD3P | Water | L827A945
- radaja | C2Q Q9650 [4C] @ 4499.9MHz | 1.376 | Gigabyte EP45-UD3P | Water | -
__________________
Core 2 Duo
- dragonhunter | C2D E8400 [2C] @ 4698.0MHz | 1.504 | ASUS Rampage Extreme | Phase | -
- adadk | C2D E8700 [2C] @ 4600.5MHz | 1.440 | ASUS P5E | Air | -
- tom23 | C2D E8400 [2C] @ 4530.5MHz | 1.408 | Gigabyte EP45-UD3R | Water | -
- ToxicWk | C2D E8500 [2C] @ 4519.1MHz | 1.480 | ASUS P5E | Air | -
- Dekara | C2D E8600 [2C] @ 4510.4MHz | 1.312 | DFI P45-T2RS Plus | Air | Q820A606
- Telo | C2D E8600 [2C] @ 4505.8MHz | 1.329 | Foxconn BlackOps | Water | -
- Elloquin | C2D E8700 [2C] @ 4505.7MHz | 1.392 | ASUS Rampage Extreme | Water | -
- cheapseats | C2D E8600 [2C] @ 4504.1MHz | 1.392 | ASUS Rampage Extreme | Air | Q820A606
- hellper | C2D E8500 [2C] @ 4502.8MHz | 1.360 | Gigabyte P35-DS4 | Air | -
- Nr2 | C2D E8400 [2C] @ 4500.3MHz | 1.296 | Gigabyte P35-DS3L | Air | -
- OLDcomer | C2D E5200 [2C] @ 4500.1MHz | 1.504 | Gigabyte EP45-UDP | Water | Q831B293
- PatRaceTin | C2D E8400 [2C] @ 4500.0MHz | 1.368 | ASUS P5Q-E | Water | Q842B072
- radaja | C2D E8500 [2C] @ 4500.0MHz | 1.440 | Gigabyte EP45-UD3P | Water | -
- OC Nub | C2D E8400 [2C] @ 4499.9MHz | 1.456 | Gigabyte EP45-DQ6 | Water | -
__________________
If you spot an error, or have some issues / concerns (such as missing or incorrect entries), PM me!![]()
