Thought I would share a little project I'm working on. I decided to make a few evaporators and mounts, but as always with a little more xtreme.First the evaporators are made from 2" diameter copper and heights range from 1 7/8" to the "big mama" 2 1/4". The design of the evaporator is for refrigerant to enter from the bottom and make a full circle and step up to the next level and continue to circle the evaporator and exit at the top. I call it the Crossflow...after the low temp water blocks I made for Goliath. Also, the temperature probe will be at the bottom and center of the evaporator to get the most accurate temperature reading.
I've had this design on the table for awhile, but just now getting time to make the evaporators. I will be making universal mounts for these evaporators, but I have little surprise with the design.
What do you guys think?
can't wait to see the mounting. ive played around with similar ideas but they would have taken to long for me to make on my small mill. id try to make a brazing ring on them... after lots of attempts with slide over its just a pain to have to re-surface the base after brazing.
I know the size might be overkill...but these babies shouldn't have any problem with removing heat and mantaining low temps.
... I think you will like the design. By the way, can forget about insulation around the evaporator too!
![Send a message via AIM to [XC] gomeler](images/misc/im_aim.gif)
is the remedy
