i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
hey guys, what are all the good VID's and batch numbers with the Q9550's. the E0's. I've done lots of reading on what I have, the Q9650. but I just built a rig for a friend and I installed a Q9550 E0. it's a L847C Batch and I got lucky and got a 1.18 VID I think, Win 7 is loading right now. It showed 1.15 in BIOS, but in MIT page it read 1.18v set to auto, so I'm thinking thats the vdroop and I've got a 1.18 VID. and it's idling at 28c so looks like it's a solid chip.
I have it under a UD3L so we'll see. I'll run tests in a while. but if it's an amazing chip, I'll take it for myself and replace it. haha!
Thanks for any info on VID info for these Q9550's. or are all the E0's basically good OC'ers just like all the Q9650's are?
Project HAF 932 Water-Cooled
__________________
New OC Validation
- Q9650 4.0 Ghz For Now -
- GTZ, Feser 360, D5 Vario, EK Multi-Option -
- eVGA 750i FTW! -
- eVGA GTX 480 H20 & GTX 295 -
- 2x2GB Dominators PC2-8500C5D -
- WDCaviar Black 640GB AALS x2 (Raid0) -
- FreeAgent Pro 500GB Ext x2 -
- Enermax Revolution 85+ 1050w PSU -
- X-Fi XtremeGamer -
- CM HAF 932 H20 -
- Dell U2410 IPS LCD-
- Logitech G11 & MX-518 /G9 -
- Sony 24x Optical w/ LightScribe -
- BOSE Companion 3 -
- ATH-AD900 Cans & UE Triple.Fi 10 Custom IEM's -
- Nikon D40 w/18-105mm & 55-200mm VR's -
The one im using is a 1.200 vid, batch no, L844C01, currently clocked at 3.8ghz on 1.21875v in bios, 1.200 idle and 1.216 at load.
i7 920do, asus p6t deluxe v2, TRUE 120, 6gb ocz reaper 1600mhz c7
xfx gtx 280 xt, benq fp241w, lg blu ray drive, saitek eclipse 2, logitech g5
thermaltake toughpower 750w, akasa eclipse 62.
I've run IBT again, and, I has succeeded ! I've installed chipset drivers for W7, today, I'm gonna try to lower the voltages.
Also, I'm thinking I might need to do a reseat of my Cooler.
I got the Xig Dark Knight, the S-1283V and Installed it with the stock fan, and some MX-2 and my Q9550 is sitting at stock voltage of 1.1875v and stock speed and my temps are 39, 40, 40, 35 and I'm in the desert so they will drop when it gets colder, it's 79F inside the house. Almost 80. So thats what. 26c
I'm thinking at stock speeds it should be more around 33c idle, but then load is more important right, maybe I should try with less MX-2, or go back to my Shin Etsu
__________________
New OC Validation
- eVGA 750i FTW! -
- CM HAF 932 H20 -
Those temps look good to me. almost dead on mine. i have 41, 38, 38, 40. and my room temp is around 79f also. i have the OCZ Vendetta 2 on top of my CPU ive had it on for a couple weeks and ihave seen a big drop in load temps the longer it is on. at first running IBT i hit 68c and 63c on pr95. on IBT now im barely hitting 601c and on PR95 54c it max. i wouldnt change out the cooler just yet. let it work its magic for a week or so.
i have had my Q9550 for a few weeks now maybe 3. here is my Batch
#L846B715
i have it running at 3.83ghz(yup i got a hemi) had it at 4.01? but not stable due to my ram. ive seen this batch and the L847C's oc real well.
EDIT:
Sweet HAF. thats next once i get my new mobo...lol
GA-EP45-UD3P 1.6rev
Q9550 @ 3.77ghz SLB8V
1.325vcore in bios
Batch #L846B715
Kingston HyperX KHX8500D2K2/4G @1066
OCZ Vendetta 2 with 120mm fan
Corsair HX650w PSU with a 120mm fan
PNY 8800GTS
HAF 922 2 200mm red led fans 1 200mm black fan 1 120mm rear fan
ya.. but see yours is running my same temps with 1.26v and overclocked to 3.8 Ghz, mine is stock.. 2.83 Ghz. my 3.0 Ghz Q9650 ran cooler than this.. and does at 4.0 Ghz with a TRUE.
I think it was the mount, and the wait a few weeks only matters when the Thermal paste needs to cure, like AS5, but I used MX-2 and it doesn't have a cure time, but I'm thinking I'm going to try out my Shin Etsu again as it's working perfect on my sig rig under the GTZ
__________________
New OC Validation
- eVGA 750i FTW! -
- CM HAF 932 H20 -
good point there didnt take into the fact your not OC'd yet..lol guess i should have kept my mouth shut...lol
i didnt use AS5 this time. tried some of the OCZ freeze. i think it along the same lines as the MX-2 ive been told it dont need the cure time like AS5. IMHO i think after some run time they all preform better.
GA-EP45-UD3P 1.6rev
1.325vcore in bios
Batch #L846B715
PNY 8800GTS
well I do agree that after a little run time all tim performs a little better, This is of course because the Thermal Paste gets heated up, and cooled down, and do this a few times. Run prime, then shut off the PC. after a week or 2. it's melted and cooled over and over and it gets into all the microscopic cracks and stuff of that sort.
After a few runs it spreads better and probably gets better temps, but whatever. and the Sticker on the bottom of the Dark Knight left tons if VERY sticky residue on the bottom of the Cooler, I was worried and not even 91% alcohol would remove it, I ended up using goo-gone, and my fingernails to get it off. So at least it's looking ok.
Stock speed, stock voltage, Q9550 with Dark Knight 25 Mins of Prime95 I'm sitting around 51c on first 3 cores, and 46 on last.. little high for stock speed load temps
__________________
New OC Validation
- eVGA 750i FTW! -
- CM HAF 932 H20 -
What's your VID ?
Guys, I've run many stress tests ("Prime95 small FFTs, OCCT, IntelBT, LinX"), I don't want to run all of theses tests whenever I try others settings. So, what are the useless tests among the last ones quoted ?
I've tried to try 5 times IBT again, with 1.225V and it has worked ! I've tried 1.2125V, and It have still worked. Afterward, I've run LinX 20 times, It has succeed. All of these tests have run on Windows 7 64. Weird, for 1.225V, even LinX has failed, I've just installed the drivers of the chipset, lan, and audio. Perhaps, I can still lower the vcore, but don't want to run tests again.
My news settings :
Vcore : 1.2125V (LLC still disabled, 1.18V idle, 1.16V load)
Vnb : 1.22V
Vfsb : 1.22V
http://valid.canardpc.com/show_oc.php?id=676275
Should I run OCCT or Prime to check well the stability ?
Ok I just got mine at MC and I got the L847C219 that Tool got but, mine has a VID of 1.225 as you see in my screen shot below. I just plopped her in didn't have to clear my CMOS or anything but, I had to tweak the 8 multiplier that my Q9450 had to 8.5 and turned up the voltage one notch to 1.3v to be safe and saved and booted right into to windows!! What What!. I sold my old Q9450 for $120 on Ebay today. Very happy. I don't honestly think my MB can push any further then 480 but, I will mess around later after stability testing it. My temps are super low!
_____________________________________________
Rig = GA-P67A-UD3P Rev 1.0 - 2600K @ 5.2~GHz 1.5v~, 1.489~v Under Load - Swiftech Water Cooling - 2 X 4GB Corsair DDR3 2000Mhz @ 1868MHz~ 9,10,9,27 @ 1.65v~ - Asus 6970 @ 950MHz / 1450MHz - 3x Western Digital RE3 320Gb 16Mb Cache SataII Drives in Raid0 - Corsair HX 850w Power Supply - Antec 1200 Case - 3DMark 11 Score = P6234 - 3DVantage Score = P26237
Update for my Epeen.
485 x 8.5 = 4122.87GHZ
http://valid.canardpc.com/show_oc.php?id=677719
+ MY 2 4870 1GB Cards in crossfire @ 860 / 925 1.34v
+ 3DVantage = 17520
http://service.futuremark.com/compare?3dmv=1361969
I just wonder if my P45 Chipset is bottle necking now or not. I seen a few people in here that live around me, any one have a X48 Chipset to test with me? I seen a really good write up at some site where dude compared X48 with P45 and two 4870 cards and the P45 came out ahead but, I might be pushing the limit a little more then that guy was. I would have to find it again to see what he was clocked at with the cards and CPU.
Maybe I was wrong about my MB. I am on 490FSB and just tested 485 stable.
http://valid.canardpc.com/show_oc.php?id=677815
Edit: Take that back I don't think it was stable I think it was just acting stable. I honestly think this motherboard is holding me back at 480ish FSB wise. I fought with this thing that whole time changing this and tweaking that in the BIOS and it seemed as if the more I slowed down the motherboard the little more stable it would act.
well i was trying to tinker a little more... yea i know im at my max right now wit hthis mem. but i have to try..loljust wont do much of anything over 425fsb. putting mem at 850mhz so that s where im running at now. ran all the norm test passed fine. running prime95 now and it is only showing 1 core???? do i have a setting wrong or the wrong version for a C2Q?
i thought i got a version of prime95 from here that worked for me. just dont know where i got it at and where i saved it..lol
yup i found it..lol
also heres a shot of LinX
i dropped it down to 3.61ghz 425fsb no sence in burning up the mem i do have..lol
GA-EP45-UD3P 1.6rev
1.325vcore in bios
Batch #L846B715
PNY 8800GTS
Hi All
Finally Got The PSU And Giga EP45
And Now Time To Test For Few Minute Take This:
More Test Comming Soon![]()
Asus Crosshair IV Formula
AMD FX-8120
ATI HD5750 Silent+ATI HD5770
Kingston 1333 2*2GB
GP1035B
Zalman CNPS 10X Extreme
Sorry For My Great English
I've tried : Vcore 1.20V (instead of 1.2125), VTT 1.20V (insteal of 1.24V), 10 times of IBT (max memory), 20 times of Linx (max memory as well) have succeeded. I'm sure OCCT for 3h will succeed but I don't want to run it, don't wanna waste my time.
http://valid.canardpc.com/show_oc.php?id=683878
(idle : ~1.16V)
This Mobo It's Amazing For My Quad
Look That:
Yestrday Got The PSU And Run OC In First Time OC With That Mobo And I Can Say It's Awesome For Quad
My Old Mobo DFI P45Very Bad For Q9550 It's Never Up 515FSB
Some Test And Some Record
And Next Run Benching![]()
AMD FX-8120
Kingston 1333 2*2GB
GP1035B
impressive results VIVID
keep the hard work![]()
You on water ViVid ? or Phase ?
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
AMD FX-8120
Kingston 1333 2*2GB
GP1035B
