Page 1 of 3 123 LastLast
Results 1 to 25 of 72
Thread: Storm G7 Proto
    Unoriginal Macho Energy
    Dec 2002
    Storm G7 Proto
    Heh, looks like Cathar got her done! I'm sure he'll post around soon, but check it out at OCAU:
    http://forums.overclockers.com.au/sh...d.php?t=407419
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Member
    Dec 2002
    Leics UK
    I hate the way that they wont accept hotmail, gmail or yahoo on OCAU.
    Means that I cant register as im a roving internet user and dont have a ISP email address.
    Can you steal a few pics plz nikhsub
    Dec 2002
    http://www.employees.org/~slf/g7/
    Hope you don't mind stew... you did post it on OCAU
    Jul 2005
    Atlanta, GA
    very nice. hopefully we will see a refined gfx block from cathar after he finishes this. we've reached the threshold of water block performance for CPUs. now hopefully he can do the same for the GPU. ^_^
    "premature optimization is the root of all evil" - Donald Knuth
    <('_'<) <('_'^) (^'_'^) (^'_')> (>'_')> OMG ITS T3h POWER RANGERS!
    -150c Club Member
    May 2005
    Northeast, USA
    What seems to be the difference other than the dual port connection cut?
    If you have a cooling question or concern feel free to contact me.
    Dec 2002
    almost 3x more jets... oring around intlet.. lots of changes
    Mar 2005
    notts uk
    The number of jets , size of jets and spacing between them.
    the swiftech storm has 35 jets this g7 has over 110 jets almost in the same area.
    Asus P6T Dlx Palm , Core i7 920 , 3gb OCZ DDR3 1600 , 9600gt , cosmos 1000.
    Jun 2005
    PNW
    Wow... where do I sign up? Looks good to me. I second the notion for the better GFX block.
    Apr 2004
    Socal
    very nice
    ASUS Maximus VI Hero
    Intel 4770K Delidded @ 4.7GHz
    Swiftech DDC w/Petras Top
    EK Supremacy Direct to Die/MCW80 GPU
    XSPC 120.4
    2x8GB G.Skill
    MSI 6950 2GB 975/1400
    Samsung 830 2x128GB RAID0/WD 2x3TB RAID1
    Corsair 800D with AX850W PSU
    Dell U3011 30" LCD
    Jul 2005
    NY, USA
    man, it just keeps getting better!
    Feb 2005
    Oregon
    I think you would definitely need an inline filter with this bad boy or the smallest gunk would clog it up.
    Mar 2005
    Isn't having that many jets going to affect performance? The amount of water going through stays the same, but has more places to go through, so it would seem to me that the pressure would be less and flow would slow down a bit?
    Please correct me if I'm wrong. Regardless, I'd pick one up anyways...top notch blocks. Too bad they cost your first born child.
    AMD64 3000+ Winchester [0449 MPM]
    Thermalright XP-90 w/ Panaflo 92MM
    DFI LanParty Ultra-D nF4
    Patriot 1GB[512x2] PC3200 XBL
    ATI X800XL PCIe 256MB w/ VF-700Cu
    Antec NeoPower 480W
    Member
    Dec 2002
    Leics UK
    I think that the effect or more smaller nossles is better then fewer bigger ones.
    Cathar can probably explain the specifics of why.
    Mar 2005
    alexandria
    and I just bought a Storm..........................
    Lian-Li V2000 - OCZ PowerStream 520W
    DFI NF4 SLI DR EXPERT (E704-BT BIOS)
    Opteron X2 175 CCBWE 0530 TPMW- Mushkin redline XP4000 2X1GB
    WD Raptor SATA 74GB *2 (raid 0)
    Plextor 716 SATA DVDRW - Samsung 160GB SATA
    MSI 6600GT
    Thermochill 120.2 - Laing D5 pump - HDPE Reservoir - Swiftech STORM
    PolarFlo TT GPU block - vantec fan controller - SANACE 103CFM fans
    May 2004
    Montreal
    Looks a lot less restrictive than the G4 !
    The basplate pins look really low profile
    Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
    Evga GTX285, Raptor 150GB, Corsair HX620
    Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
    Win Vista Premium X64
    Jan 2005
    im in for two!!!
    Jan 2005
    i wish...rofl
  18. #18
    beefin' it up!
    Dec 2004
    WPI
    that... is... so... sexy... holy crap. cathar, you never cease to amaze.
  19. #19
    Feb 2005
    Oregon
    Ok, that's it, I need to make a block. I thought of an internal design like the Swiftech 600(2) about a year and a half ago and look where that got me....
    I guess I need to go to the metal shop on campus and do whatever is needed to get certified to use there equipment
  20. #20
    Xtreme Legend
    Nov 2002
    Melbourne, Australia
    Quote Originally Posted by n00b 0f l337
    For starters, it's a G7, rather than a G4/G5.
    G1 = 1 jet
    G2 = 7 jets
    G3 = 19 jets
    G4 = 35-37 jets (implemented G4 has 35 jets)
    G5 = 55-61 jets (implemented G5 has 59 jets)
    G6 = 85-91 jets
    G7 = 117-127 jets (implemented G7 has 117 jets)
    G8 = 155-169 jets (could only machine on aerospace quality equipment)
    As for the design improvements over the original base Storm design specification:
    • Increased jet inlet plenum area to lower pressure drop (thicker top-plate enables a more voluminous plenum so water can reach all jet inlets with minimal restriction - visible to eye))
    • Ported jet intakes to lower pressure drop (jet intakes are now all ellipse radiused using a custom manufactured tool - visible to eye)
    • Tweaked jet lengths to lower pressure drop (jet lengths are shorter - internal + external mod, middle plate is significantly thinner too)
    • Tweaked jet outlets to lower pressure drop (each jet outlet is chamfered around the outside of the jet tube to offer less restriction for flow exiting the cup structure - barely visible to eye)
    • Multiple flow path channels to outlet to both decrease pressure drop, and more evenly distribute jet flow and total base-plate cooling (self-explanatory and very visible to eye)
    • Base-plate bracing to boost structural strength for high-pressure CPU mounting (the 12 little posts that surround the jet area brace the base-plate and also serve as additional water turbulation for water outwash cooling effect over base-plate outside of main jetted area)
    • Improved top-plate strength for higher pressure mounting capability (just a thicker top-plate, which is offset by thinner middle plate)
    • Middle-plate bracing to improve jet/cup alignment when used with high-pressure pumps (additional consequence of the middle plate posts - reduces middle plate flexing meaning jets stay better focused with respect to their cup counterparts under very high pressure operation - meaning >>10psi)
    • Improved O-ring specifications to minimise assembly based warping (smaller O-rings and slightly wider O-ring groove dimensions, thereby meaning less clamping pressure required to seal minimising the amount of pressure that gets applied to the base-plate effectively eliminating base-plate flex on assembly)
    • Additional O-ring seal between inlet to middle plate plenum and outlet (this one's for the armchair waterblock critics - I never deemed it necessary but people often griped about the design needing one even though it doesn't, so I put it there to keep them happy anyway - may as well)
    • Improved cup/wall ratios for higher performance (minor ratio adjustments - added base-plate strength too)
    • Improved jet turbulators for higher performance (two prototypes being tested)
    • Improved base-plate characteristics for higher performance (adjusted base-plate thickness suitable for G7+silver)
    • Improved jet/cup ratios for higher performance (tweaked ratio adjustment)
    • Improved low-flow performance without sacrificing high-flow performance (micro-jetted efficiencies are much higher even with lower flow rates - also a consequence of turbulator modifications and jet/cup ratio adjustments)
    • Improved small bare-die performance (down to 7x7mm CPU dies) without sacrificing IHS performance. (simulated and tested adjustments to attempt to cover the widest possible variety of CPU types)
  21. #21
    -150c Club Member
    May 2005
    Northeast, USA
    Sounds like a lot of good engineering! THUMBS UP!
  22. #22
    Xtreme Legend
    Nov 2002
    Just added a picture for idea of scale. Shown is an Australian 10c, which is the exact same size as a US quarter (25c).
    http://www.employees.org/~slf/g7/g7-mid-coin.jpg
    The middle plate shown in the picture above is actually a faulty prototype and the jets on it aren't quite right, so if you see differences between that plate and the other middle plate pics, that's why.
  23. #23
    Jul 2005
    when will you start producing these so we can buy them also will there be a massive waiting time again and a rough price on them is.....
    phil
  24. #24
    I am Xtreme
    Dec 2003
    Thumbs up I don't even really need one and I'm
    (or it could just be the chocolate I just had )
    to THE MASTER!
  25. #25
    May 2005
    Rye, Ny
    go i want one
