i don't know a things...the blackviper change only some valour on the regedit, true?
or it do other things too?
thanks
thanks
Through regedit you can do all of the stuff (like enabling/disabling services, faster kill of processes...)Originally Posted by lupacchiotto
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
Thanks D_o_S...
yup verry helpfull info, thnx mate
CPU: Phenom II X4 955 @ 4800Mhz
Mobo: Gigabyte GA-MA790FXT-UD5P < Died
GFX: Asus ATI HD6970
Ram: OCZ 2x8gb corsair vengeance 1600
PSU: Corsair HX650w
HDD Crucial M4 SSD 128gb, 1tb spinpoin and WD green 1TB
Thanks for the tweaks, really appreciated :thumbsup:
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
hey guys i don't want to offend D_O_S but it's kristos who collected all the info about the superpi tweaks.
D_O_S made a nice sticky of it, not that i don't appreciate it![]()
Back in the phase change world
I did some testing of Ramdisc.
while the improvement isn't drastic, it's definatly worth taking a look at if your looking for your absolute best possible score.
my test method was simple.
I use the Anticheat version.
run the test 4 times. then reboot.
do it another 4 times.
then I did the ramdisc install, and redid it all again.
the best scores, of 8 runs each, show up here.
its a small difference, but well worth doing, cause it requires so little effort, and will give you a good chance at a better score then running from your hard drive alone.
every little bit helpsnice find kunaak, testing appreciated
PSU: Corsair HX650w
what OS should I use for the 2M calculation ?
2k3Originally Posted by massman
and maxmem=104
1M: maxmem=104
2M: maxmem=104
4M: maxmem=secret![]()
8M: maxmem=secret![]()
16M: maxmem=secret![]()
32M : maxmem=dunno
I love XS
Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
I want a Penryn 3.33G 12MB & quad sli Nvidia G92
are you sure ?
with my xp tbred I was two seconds slower then my high score on a fully tweaked winxp pro
And why is it secret?Originally Posted by cpulloverclock
Intel FTW!
Beanna
try to find them before giving u the solutionOriginally Posted by NiCKE^
I love XS
would win2k give a better result ?Originally Posted by massman
Then one more time, I got a lifeOriginally Posted by cpulloverclock
Intel FTW!
Beanna
No, win2k is slower than XP and win2k3 in Super Pi. 2k is worth for Super Pi benchesOriginally Posted by massman
win2k in much faster with this tweak: link
but, i prefer windows 2003
learn![]()
learn A.K.A JP
shutting down the explorer.exe didn't make any difference on my Spi time![]()
sometime it does sometime it doesn't, every system is different![]()
does anybody have any usefull win2003 superpi tweaks, beside the ones mentioned in this post.
i cut down from 32s to 29s 1M spi
good job here!
trying to get the most out of windows xp tweaking for super pi but I have a question...a simple one & maybe dumb, but here it is:
how do I delete page files?
While I'm asking, what's the optimum virtual memory setting for 1GB RAM?
Lastly, where can I download BlackViper's registry patch? (site's under construction or something)
Thanks for the help!
AMD Athlon FX57
DFI NF4 Expert
Crucial Ballistix Tracer (2x1GB) PC4000
Mushkin Redline XP4000
850 SSI PSU
Hi!
me too, i'm looking for blackviper, but i can't find them... any mirror??
thanks
Copy-waza is the best tweak i've used so far for SuperPi.![]()
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Ok, I have tried MAXMEM so far in Win2k, WinXP and 2K3 server, on A64's, Dothans, and P4's. No matter what the combo is, it does absolutely nothing for me other than create a nice chunky page file on my hard drive. It doesn't help times in the slightest. Is there something I am doing wrong here?? Some other tweak associated with it that I'm not enabling?
