Results 1 to 4 of 4
Thread: What switch do I really need?
    Mar 2007
    I'm setting up a surveillance system. I have to use a P2P bridge between 2 buildings at 2 different sites. The bridges I'm using are a Ubiquiti bridge. When I was on another forum that dealt with cameras, many said that I should make my whole system Ubiquiti. Well, that may be great for some, but I already have a new $200 + router, and would like to keep it instead of switching to a Ubiquiti one. I am in the need of several switches though. I need ones that are PoE, and will be able to supply enough power to a couple of PTZ cameras. At one site there will be 4 cameras, but 1 or 2 may be PTZ. At the other site, there will be 8 cameras, and 1 or 2 may be PTZ. Do I really need a Ubiquiti switch at those sites. 1- 4 port, and 1- 8 port?
    What are your thoughts on this?
    What would be a good switch? I'm just looking for a recommendation.
    Thanks.
    2-VIOTEK FI24D V2 24-Inch QHD Gaming Monitor with IPS Technology, ASUS ROG STRIX B550-A GAMING AM4 AMD B550, CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) DRAM DDR4 3200, MSI GeForce GTX 1660 Ti 6GB GDDR6
    AMD RYZEN 5 3600 6-Core 3.6 GHz, Asus BW-12B1ST Internal Blu-ray Writer SAMSUNG 830 Series 2.5" 256GB SATA III , HITACHI Deskstar 2TB, 2 - Western Digital Black -2 TB HDD
    Super Flower Leadex III 650W 80+ Gold, AMD AM4 Wraith Prism LED RGB Cooler Fan, Windows 10 Professional Retail, Fractal Design R4 case
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    If these sites on the same ISP you can request a subnet with business services.
    Amazon has many choices for POE, I have no suggestions.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2007
    I have opted for a TP-Link switch. Maybe it is not the best, but I went with an enterprise quality because of the semi harsh environment it is going in.
    I am just about ready to buy one of the Jetstream switches TL-SG3428MP or TL-SG2428P. One has the console port, and more watts of PoE. How important is the console port to you if you have one of these switches? It may be overkill, but for the price, and the watts it gives, there was nothing that came close. Thanks for your help.
    Mar 2007
