Hey all.
I planning on doing away with my barbs and clamps as their ugly (IMO) and want to replace them with some 1/2" 3/4" compression fittings.
Problem is I have a Heatkiller 3.0LC which will not accommodate two compression fittings side by side (not enough space between the inlet and outlet holes)
So I thought at first to go with some 45 degree rotary adapters which would solve the problem, however I've read a fair few horror stories about leaking rotary fittings, It seems you have to be extreme careful with them and as I move my PC around at the weekends it just won't be practical.
So are there any alternatives?
Here's an image of my current setup
Thanks for reading, I would really appreciate any help![]()
