Results 1 to 8 of 8
Thread: 9800SE mem voltmod
    Sep 2003
    denmark
    9800SE mem voltmod
    i need a guide how to make a memmory volt mod on a 9800se connect3d card i have made a GPU volt mod now its time for mem mod
    i have made the mod so that the card is now running at 1x8 pipelines and got 19600 in 3dmark 01 :P
    here is the link
    but why cant i get eny further then 360mhz on the memmory ??
    i have ram sinks on and great cooling ?
    here is a pic...
    Sep 2003
    denmark
    it would be great if someone knew where i could find an easy guide for me
    | 3.2EE @ 4.3 @ 1:1
    |Asus p4c800-e @ *Vdimm mod* *Vcore drop mod *
    | 2x512 muskin specieal *2225 @ 245fsb @ 3.3v*
    | X800pro connect3d FFS forsinket !
    | CPU colled By *Mach 2 ST*
    | super tornado 400W @ *3.3v mod 3.8v*
    If it doesn’t fit use violence – if it breaks it needed replace enyway
    Jul 2003
    Hmm, dunno about the SE it's only 128bit bus. You could take a look at the Macci one and see if the pcb's are the same.
    I wonder if a 9500Pro might be the correct pcb for you? So maybe look for one of those.
    And I don't think I would classify that as great cooling either. There really dosn't exist a good factory made GPU cooler.....that I have seen at least.
    Nice card huh? She took the softmod
    G H Z
    Sep 2003
    denmark
    no its not 128bit its 256 bit i can see it in RivaTuner
    | 3.2EE @ 4.3 @ 1:1
    Sep 2003
    denmark
    isent there enyone that knows how to do this...
    | 3.2EE @ 4.3 @ 1:1
    Jun 2003
    hmmm
    That version 9800SE is built on the 9700pro PCboard... so all the 9700pro vmds shold apply.
    Aug 2003
    Portugal
    Hi, I have a 9800 SE, also softmoded to 9800 PRO. I'm about to do the Vgpu, can u post how u did it on your card? Also i need to know where do u measure the Gpu Voltage.
    Regards,
    diogojcr
    Jan 2004
    Halifax, Nova Scotia
    sorry to dig up an old thread but I think the 128bit is the same as the 9500pro for gpu and mem volt mods
    as for the 256bit version. it is on the exact same layout as a 9700np/pro so volt mods should be identical.
    yay, first post
