XG WarCat 6.10
WarCat 6.10 has finally made it through.
Since the WarCat driver is about gaming and benchmarking, we'd like to introduce with this set the Games Profiles. This will improve your gameplay in certain games. The driver was optimized and designed to run those games at full potential.
Also, we have enabled the new AA technique: Alpha to Coverage which improves quality when having Anti-Aliasing Enabled.
XG WarCat 6.10 driver for ATI video cards .
This version of the driver does not include any of the following : Control Panel, WDM .
This version includes the driver, the Control Center .
PLEASE UNINSTALL YOUR OLD DRIVER BEFORE INSTALLING THIS ONE .
IT'S VERY IMPORTANT THAT YOU DO IT OR YOU WON'T BE ABLE TO SEE ALL THE CHANGES .
Based on the release of Catalyst 6.10, The Wild Side of TRU made XG WarCat 6.10 .
Changes in XG WarCat 6.10:
-Updated installer to version 3.1;
-Rendering technique reworked :
-Smoother frames;
-Alternate rendering frames added and enabled, which resulted in an
increased rendering speed over the previously WarCat drivers.
-Now, the video card gives maximum acceleration potential when running 2D and 3D applications;
-An extra kick of performance for people that with AGP based Radeon cards;
-Improved IQ while in Windows : Enabled Hardware support for icons and mouse cursors;
-Ingame IQ improvements;
-Updated the tweak root;
-With this set we introduce you the new Anti-Aliasing Technique : Alpha to Coverage which improves quality when having Anti-Aliasing Enabled.
!There is no option to enable or disable this feature, not even in the Control Center.
This feature is enabled by default.
-Since the WarCat driver is about gaming and benchmarking, we'd like to introduce with this set the Games Profiles.
For this release :
-World of Warcraft;
-Need for Speed Carbon;
-Neverwinter Nights 2;
-Marvel Ultimate Alliance;
-Need for Speed Most Wanted;
-Doom 3 and expansion;
-Prey;
-Warcraft III;
-F.E.A.R;
-Prince of Persia;
!NOTE: There are no features regarding the profiles or options to change, since it's done by the driver itself. The driver
was designed and optimised to give a boost when running those games.
If you have suggestions for more games, let us now.
Download XG WarCat 6.10
For people with Radeon x1950 video cards: here you can download a patch for WarCat 6.10 in order to add support for your video cards.
Download XG WarCat 6.10 Patch
NOTE: You need WarCat 6.10 installed on your system !
- You may not post replies
- You may not edit your posts
Forum Rules
