I can run my E6300 @ 2800MHz with 1.225v Stable ( 0.1v under 1.325 default) can it cause problem for my CPU?? like shorter lifespan or etc?
less volts means less heat, means longer life![]()
Core i5 760 | Corsair H70 |Gigabyte H55N USB3 | 2x2gb GSKill Ripjaws 1600mhz C9 |ATI Radeon 4890 1GB | OCZ Vertex 2 120gb | Samsung Spinpoint F4 2TB | Silverstone SG05 450BB
My Heat
http://heatware.com/eval.php?id=25800
Yea, most of the processors have overkill voltages. I can do 3200 @ 1.275v Stable .... so imagine what it would be if it was less. With EIST and C1E enabled, you can even do 2700 @ 1.075V ... but it's on small loads which is still pretty good.
careful, people blew things up by undervolting
and also... plz stop using my avatar...
My Rig:
i7 3770k
Sabertooth Z77
MSI GTX680 reference
2x8gb Mushkin Redline 8-8-8-18 @1600
Corsair Neutron 256gb
2x Toshiba 7200rpm 3TB(Raid 0)
Corsair 600T White
Corsair HX750
Asus PCE-AC66
Hanns-G 27"
This is my baby:
Stability: 4hours Dual Prime95 v24.14 + Dual Super-Pi
CPU name: E6300
OC: 2800MHz
Stepping: 6 B2
Week: L626
Code: A687
Vcore: 1.09V (BIOS Set: 1.1375V) !!! (Board droop makes this go so low)
Cooling: AIR
Cooler brand/model: Arctic Cooling Freezer 7 Pro (FREEZER7PRO)
Motherboard: ASUS P5B Deluxe WiFi-AP (Intel® P965) (90-MBB4E0-G0EAY) REV. 1.03G
Bios Version: 0614
RAM brand: A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
RAM rated speed: 6400
RAM actual speed: 6400 @ 1.90 V
Latency: 4-4-4-8-4-35 Sub: 3-10-5-13
Validation: http://valid.x86-secret.com/show_oc?id=120877
Originally Posted by HamidFULL
looks like a golden chipis it a week 26?
Under volting the CPU really cant do much harm![]()
i lost two amd 939 chips to undervolting... certainly these chips are much different, but i always run +volts even at stock on all of my cpu's just to be safe...![]()
undervolting is probably more of a problem if you are using a pos mobo though.
Originally Posted by Silvermirage
How do you figure that? Or did you just make it up?
I'm testing 2700mhz 1.2v actual atm...
Cpu max is 3.5ghz 1.6v actual.. it sucks comparatively tbh..
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
Impressive, I wish my aw9dmax could undervolt... doesn't have any vcore setting below 1.325
As far as I know theres no lower vcore setting under 1.325 on the aw9dmax... I'm just curious to see if I can undervolt and see if my cpu is stable. Though hamid, with C1E, its going to show vcore ranging from 1.19v to 1.36v... if you turn it off it'll stick at 1.36v. At least thats how my board is, set to 1.325, and shows 1.36v in uGuru utility. Also turn off EIST
Originally Posted by TheDro
I see, i guess i just dont understand it, why not just see how far it goes on stock volts? Its not like they run hot at stock.
Yeah I know, its just curiousity... though you're right I should just focus on seeing how far it gets with stock volts.
