OCZ Unveils PC2-9000 Ti Alpha DFI Edition
The new OCZ PC2-9000 Titanium Alpha VX2 DFI Special is optimized for our new LANParty UT NF590 SLI-M2R enthusiast board, and together these two premium components will push your overclocking milestone beyond any other motherboard and memory solution.
As a member of the proprietary Voltage eXtreme family, the PC2-9000 VX2 DFI Special is designed to operate at a high voltage in order to increase the speed while maintaining stability that is usually unobtainable when conventional modules are pushed to run at a higher voltage. At DDR2-1120, the Ti Alpha VX2 supports ultra-low timings of 5-5-5 at 2.4 volts without any adverse affects to stability whatsoever. OCZ and DFI exclusively developed these modules for the extreme enthusiast to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and overclockers.
Link
Intel C2E QX6850 @ 3.33GHz, ASUS P5K Premium, OCZ 8GB PC2-6400, eVGA 8800GT, OCZ ModXStream 720W, Thermalright Ultra-120
Seagate 500GB, 750GB & 1TB, Samsung 20x DVD-RW, ASUS Xonar D2X, Antec P182, Ultrasone PRO 750, Dell 2408WFP, Gentoo 2008.0
"Life without knowledge is death in disguise." - H.P. Baxxter
Techgage.com Editor in Chief | Profiles: Last.fm | Xbox Live | Steam
- You may not post replies
- You may not edit your posts
Forum Rules
