Page 1 of 25 123411 ... LastLast
Results 1 to 25 of 602
Thread: ***Official nFORCE2 Bandwidth Thread!***
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    Since alot of us have nforce2 boards, and OPP mentioned that a new bandwidth thread should be started up, I thought I'd go ahead and get one goin.
    Keep in mind, this is strictly for nforce2 based motherboards and just the sisoft sandra memory benchmark. And let's keep it in sync and dual channel (if you can). Feel free to list your mods, your bios, etc, so that we can all learn from each other
    ______________
    I'll start it off by posting what I think will most likely be max FSB attainable with my A7N8X.
    A quick overview of mods, 1.9v on the chipset, 3.12v on the memory, 1002.001 beta bios, cpu_fsb jumper @ 100, new battery, 85w peltier + chilled water on the core (-5 to -8C temps). My PSU is also vmodded and gives me 5.15V under load approximately (not sure if that affects the high clock.) Memory is 2 sticks of XMS3500 (winbond -5ns) in DC 100% sync.
    EDIT: Timings were 2.5-7-3-3 @ 240mhz. 2-6-2-2 @ 236mhz
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Feb 2003
    :: ItaLY ::
    Great!!!!
    mine compliments!!!
    The system running rock solid?
    There's a tutorial for modding A7N8X?
    Aug 2002
    nice bandwith sys, what are ya timings?
    Intel Core i5 2500k @ 4.7GHz
    Gigabyte Z68X-UD3H-B3
    8GB Corsair DDR3-1600
    MSI GTX 680
    XFX 750W Black Edition
    Corsair Carbide Air 540
    Jan 2003
    your wardrobe
    Here's mine @225, no vmods, DC100% sync'ed, 2x512mb Corsair XMS3500c2. vcore@1.85v, vmem@2.8v, 3dmark benchable but not that stable. 2700+ unlocked. Will push it further with my newly arrived Prometeia very soon
    Jun 2002
    HÂ¥percUbe: I'll have a guide up soon on how exactly I did everything on my site, Maximum OC. And as for rock solid, I could bench sandra, I could do most things in windows, I didn't try PCMark2002 but I will give that a shot eventually. Speaking of PCMark I scored 6464 @ 232 2-6-2-2.... was just testing.
    Drozdov: Silly me I forgot to put it in... 2.5-7-3-3. 236mhz I can do 2-6-2-2 though. (I will edit my post w/ this info.)
    Feb 2003
    :: ItaLY ::
    Okkk. Thankz!!
    i'd like to view PCmark & 3DMark screenshot
    Jun 2002
    Originally posted by HÂ¥percUbe
    Okkk. Thankz!!
    I'll upload em tomorrow, heading to bed now
    Aug 2002
    Pearland, TX
    Can you post an unbuffered sandra bench at the low timings.
    wolfdale e8400
    Corsair Dominator 6400c4 4x 1gig
    rampage formula
    evga 88000gtx
    x-fi platinum
    ocz powerstream 520
    Jun 2002
    Bulgaria
    Here's my bandwith @ 10.5x230 ...
    And here's my PCMark2002 score @ 225MHz, both sync and SC DDR ...
    CPU : 7604
    Mem : 6300
    http://service.futuremark.com/compare?pcm=1109227
    | T-Bred 1700+ @ 2663MHz (12x221.9) (JIUHB 0310 "9") | Epox 8RDA+ (C1 NB) | 2x 256MB TwinMos PC3700 | Asus V8420 128MB 3.3ns Deluxe | Enermax EG465AX-VE(G)(FMA) PSU | TT XaserII modded case | Homemade Waterblocks, 2000l/h Champion Pump, AC Radiator 400x280x45mm, 8l res, 80W Pelt |
    3DMark 03 : 2030pts | PCMark 2002 :CPU : 8003 | Mem : 6279 | SuperPI 1M : 39 sec
    Jun 2002
    here's mine by now
    on 8rda vdd modded
    2.84vdimm is a POS
    Feb 2003
    :: ItaLY ::
    Good Result,
    it's rock solid?
    Jun 2002
    Good Result,
    it's rock solid?
    wellÃ:banana: Ciao
    yes it's rock solid and 3dmarkable 233 dual channel, till 228 is quite easy
    i'd better go with NF7 1.2 or 8RDA+ then A7N8X ,altought Sys got an impressive fsb with that
    Jun 2002
    Slovenia
    Kingston Hyperx 3500 2*256 MB/s cas2.5 6,2,2 vdd 1,98V vdimm 2.86V, this all with normal watercooled NB in warm room, no xtreme mothods, I'll try those soon
    Like Spaceboy wrote POS Vdimm. I'm thinking of modding but can't decide if it's worth it, oh yeah Epox 8RDA here with 3117 bios, btw Spaceboy that helped a lot. With my previous latest bios, I got BSOD loading windows even at 230 in normal room temperature conditions
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    That is really, REALLY nice morphling1. Congrats on a fine workup!
    The plural of "anecdote" is not "data."
    Jun 2002
    I think I'm gonna lower my resistance a smidget (slap on a smaller resistor rather) and try for some higher fsb... not sure if that'll do it but it's worth a shot.
    Nov 2002
    California
    2x Corsair PC3500 XMS running dual channel in timings 4, 2, 2, 2 Vdimm 2.77V
    Vdd @ 1.60 not Vdd moded "yet"
    Abit IC7 @300FSB Bios 28
    P4 2.4C@3.6Ghz
    ATI 9700 Pro @ 445/710 Vgpu modded
    Corsair XMS PC 3500 256mb x2
    Liteon 52x24x52 CDRW
    WD 40GB 7200RPM x2
    Enermax EG465P-VE(FCA)
    Chevy Chevette Heater Core
    MCW50-T
    Eheim 1048
    Prometeia Mach I
    Lian Li PC65B
    Overclocking Guru
    May 2002
    SoCal, USA
    Dual Kingston HyperX 3500s,, 256Mb sticks,, 3.1V,, 7-2-2 CL 2.5
    Epox 8RDA,, Chipset voltage at 1.9V
    OPP
Name:	dads boat and misc. 030.jpg
  18. #18
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    heres mine.. Not great at all..
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
  19. #19
    Xtreme Cruncher
    Aug 2002
    Michigan
    Corsair 3500 2-7-3-3 @2.7v on a NF7. VDD@1.8v.
  20. #20
    Jun 2002
    Slovenia
    Wow huge score there OPP, let me see if I can get anything more out of my mem. with chilled water on NB
  21. #21
    Jun 2002
    we need Vdimm Morph
  22. #22
    Jun 2002
    Slovenia
    LOL yes we desperatly do I just bough trimmers today so if I wont' be able to get higher with chilled water, I'll do the mod this weekend.
  23. #23
    Jun 2002
    i don't like to do extreme Vmod on POS mobos
    my KX7 was a rock so i did 3 mod and still works great but i'm afraid that this 8rda could die on me anytime
  24. #24
    Jun 2002
    Slovenia
    Hehe ,as they say: if you wanna make the omelet, you need to brake some eggs
  25. #25
    Jun 2002
    Belgium
    Thumbs up OPPAINTER
    Nice your the man
    Great bandwidth goodness, makes me wanna void my warranty
    24 core Xeon:
    2x Intel Xeon Q3QS 'ES' @ 4.1GHz (folding@3.8GHz) - (flakey) EVGA SR-2 - 2x Antec Kühler 620 - 6x 4GB Corsair Vengeance 1600MHz CL8 - MSI GTX580 Twin Frozr II/OC - Thermalright Shaman - 2x Intel X25-M 80GB RAID0 - Silverstone Strider 1200W Gold - Lian Li PC-P80
