Results 1 to 21 of 21
Thread: My 8RDA+ @ 230 fsb, low bandwith i think :(
    Sep 2002
    Gorontalo - Jakarta
    At 230 FSB (AXP 1600+ @ 8.5*230), Dual Channel, 5-2-2-CL2 i only get :
    I think that's a little low for that fsb/timing, what's the best bios for 8RDA+ ??
    Oct 2002
    germany
    8rda+ has a performance bug with multiplier under 10!!!
    try multi 10 or higher.
    with 225 dc and multi 10 i have 3500 mb's!!!
    Nov 2002
    Plano, TX
    Henry, would you consider those score about right if they were 5% higher? You take about a 5% hit on memory performance for having the multiplier set below 10. That may be your problem.
    As far as what's the best BIOS for the 8RDA+, can't say since I have a non-plus.
    BTW, nice oc of the FSB.
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
    Jul 2002
    For the best BIOS out, I have found the newest one to be the best. I have prettyy much tested them all and the newest one has given my the best stability and best memory bandwidth.
    8RDA3129.BIN
    *Still has the issue when using 10.5x and below though, just not as bad as the previous BIOS's*
    Asus (Native) ROG Rampage Formula
    E6400 ()
    TRU 120 Extreme w/Scythe 120mm 110CFM
    2x1G Ballistix DD2 (D9GMH)
    Sapphire Toxic HD 3870
    Diamomd Viper HD 3850
    600w OCZ GameXstream
    Sep 2002
    Gorontalo - Jakarta
    Hmmm......so < 10 multiplier is the problem. Time to buy a new Tbred B i think
    Thanks guys !!
    Jul 2002
    actually...10.5x and below...
    E6400 ()
    Sep 2002
    Gorontalo - Jakarta
    IC, thanks glock19owner
    Jun 2002
    Sep 2002
    Gorontalo - Jakarta
    Yeahh...i know that bandwith is low, even with KX7 @ 215 i can get :
    Time to buy Tbred B
    Feb 2003
    :: ItaLY ::
    Aug 2002
    NJ
    You guys are forgetting something as to why his score is lower than yours....
    SisoftSandra's Memory benchmark is heavily CPU dependant...
    His chip is at 1955mhz.... While the other guys are in the 2500mhz range
    I know this because before I got my XP2100B I was running at 1925mhz and had around 3055/2800.... Now I'm running at 2354mhz and my score jumped to around 3150/2900....
    Same FSB, same timings... Only thing that changed was the CPU speed and also the lower multiplier has an even greater hit on memory performance...
    213x9 2.5,3,3,6
    213x11 2.5,3,3,6
    Intel i5 3570k || Sapphire HD 7870 OC CrossFireX || Asrock Z77 Extreme4 || 8GB DDR3 G.SKILL || Seasonic X750
    Intel Core2Duo E8400 || PowerColor HD 5450 || Gigabyte P35-DS3L || 4GB DDR2 G.SKILL || Enermax 431W
    Jun 2002
    Bulgaria
    Re: My 8RDA+ @ 230 fsb, low bandwith i think :(
    Well, Henry, here's my Epox @ 230MHz SC DDR :p ...
    (BIOS : 3117)
    | T-Bred 1700+ @ 2663MHz (12x221.9) (JIUHB 0310 "9") | Epox 8RDA+ (C1 NB) | 2x 256MB TwinMos PC3700 | Asus V8420 128MB 3.3ns Deluxe | Enermax EG465AX-VE(G)(FMA) PSU | TT XaserII modded case | Homemade Waterblocks, 2000l/h Champion Pump, AC Radiator 400x280x45mm, 8l res, 80W Pelt |
    3DMark 03 : 2030pts | PCMark 2002 :CPU : 8003 | Mem : 6279 | SuperPI 1M : 39 sec
    Feb 2003
    :: ItaLY ::
    X Men SS great result!!
    It's rock solid?
    Nov 2002
    MA.
    Are you sure you have the ram in the correct slots?
    1+2 or 1+3 are for dual.... 2+3 are not.
    <10 ( or 10.5 I forget) def. has a bug in it.
    Zen2 Has brought AMD back!
    Sep 2002
    Gorontalo - Jakarta
    muzz : Yup, alredy tried 1-2 and 1-3, same result
    X_Men : Nice bandwith there
    But check out spaceboy bandwith :
    spaceboy : 11 x 233 ----> 3638/3448
    X_Men : 10.5 x 230 ----> 3519/3252
    100+ / 200+ mb different with only 3 mhz higher fsb ??
    10.5 multi bug ? or coz higher cpu clock ??
    Jun 2002
    Bulgaria
    It's rock solid?
    It's rock solid @ 225-226MHz ...
    SuperPI, PCMark2002, 3DMark03 all run w/o a problem ... and the NB is still cooled with the stock crappy alu heatsink + 50mm fan ... vDDR @ 2.88V
    Thanks, Henry ! You definitely need T-Bred "B", my friend ...
    Oct 2002
    germany
    xmen uses ss mode this is the reason!!!
    the bug happens with multiplier under 10!!!!!!
  18. #18
    Jun 2002
    Bulgaria
    Maybe both ... Also he's running DC DDR which increses the Float score ...
  19. #19
    Nov 2002
    MA.
    Float defo. go's up with dual.....
  20. #20
    Sep 2002
    Gorontalo - Jakarta
    Yup, the bug is for multiplier under 10.
    My results (same memory timing : 4-2-2-cl2) :
    9.5 * 166 : 2463 / 2283
    10 * 166 : 2547 / 2391
    10.5 * 166 : 2564 / 2412
    11 * 166 : 2564 / 2420
  21. #21
    Feb 2003
    :: ItaLY ::
    Good!! 8RDA+ is great board...unfortunately without a lot of features
